Mar 11, 2012 14:09:13 GMT
Out of curiosity I just weighed the units Unbelievable but the little cortina calipers are the heaviest at 4.4kg then the giant Alfa ones at 4.3kg and the Porsche ones are only 3.5kg
Last Edit: Mar 15, 2012 19:00:56 GMT by sierra1off
Mar 13, 2012 13:19:27 GMT
These should stop me OK
Mar 13, 2012 19:00:44 GMT
Their Massive ;D ;D
Mar 28, 2012 20:21:53 GMT
hey alan are them disc going to be ok,just that the mounting holes don't quite look like they line up with them lovely discs, and that nice big fuel tank will do you a wright treat, did you find out what it came out off as it looks like a vauxhall/gm tank they fitted to a late camero,but anyway it looks fab and will do the job. keep up the good work MATE.
dapper
Enjoying this one.
Well if yer gonna stuff that motor in there you might as well fit feckin GINORMOUS brakes too!! :-)
snug !!!
woodenspatulas
Retro in ways you can't imagine
The engineering involved with sqeezing this into place is mind boggling!
Looking forward to any more updates.
1999 Vectra Estate + 1995 Saab Engine = Good Times
Sept 18, 2012 21:41:57 GMT
Been driving and messing about with the Anglia so not much progress on the Cortna till this week Still not made the alli calliper brackets, I did cut them to shape then started drilling them out till a bit broke off, now i have to get them done in a machine shop properly Made a cardboard template, bought a sheet on zintec and took both to a man who makes ductwork to produce a pair of wheel tubs. came out quite good ;D Will have to offer them up and trim them to fit to the inside of the wing
Sept 24, 2012 23:14:46 GMT
before ( will cut the dotted line and joggle to the solid linefor the new arch to sit on) inner wings out lots of offering up and trimming to come
Davenger
It's only metal
Club RR Member Number: 140
Sept 25, 2012 0:52:44 GMT
Looking good!
Sept 26, 2012 11:31:44 GMT
Looks like the tubs are snaplocked ,Used to do ducting myself good idea ,Keep updates flowing pls
sowen
Club RR Member Number: 24
Sept 26, 2012 14:45:06 GMT
Wow That's one hell of a package in a small car ;D
Sept 26, 2012 23:03:46 GMT
Trimmed a bit here and there till the tub fitted inside the wing. The old shock mount has to go eventually, but at the moment its tying bits together Still loads to trim off yet when i get the chance and its not to late in the evening
Sept 28, 2012 21:26:16 GMT
Got a profesional with the right equipment to make a pair of caliper brackets based on my MDF templates They will be fitted tomorrow
Sept 29, 2012 9:57:02 GMT
Nice looking Brake caliper brackets and great to see some more updates on this awesome project-Cant wait to see more.
69 Herald 13/60 with Turbo 1600 MX5 engine, Lexus 5 link rear end, 17in wheels,300mm ventilated disc's and subaru 4 pot calipers
Sept 29, 2012 21:30:27 GMT
Back on the arches, Bit more trimming, in and out a dozen times and it is ready to weld to the chassis and bond to the outer wing, But need to sort out rust issues in adjacent areas New inner cill section with a little joggle along the bottom Got to see whats behind here next
Well whats under the patch was a hole,,, no suprise really, Cut the plate and half the chassis section and fould another hole made a template then a new steel section Make the outer section tomorrow
Chops
Don't touch me I've been somewhere
Club RR Member Number: 36
Excellent work as always :-)
