Dec 19, 2011 19:43:55 GMT
Last Edit: Dec 19, 2011 19:59:44 GMT by sierra1off
Dec 28, 2011 21:38:31 GMT
Fabricated the tinwork for the sierra radiator in the boot floor Still to make a plenum to duct the air to the rear panel and fit a mesh insert behind the number plate, but need to make a new section of boot gutter rail first.... then weld all in place. twin fans will also make an air scoop below the rad facing forward , but will wait till its on 4 wheels at ride height before i do this so its not too low, probably be a bit lower than the original fuel tank
Dec 28, 2011 21:46:08 GMT
Ah, so you have a history of fitting monster engines into unsuitable cars? Truly astounding the lengths you are going to in getting that engine to fit. Good luck!
I've got Rovers.
Guilty as charged sam very early example 3L V6 in Mk1 Cortina anyway Made a support frame for the fuel tank front strap bolts through panel over inner wheel arch rear support strap will be bolted to an angle framework which will also allow a cover panel to be fixed to it Need to find a nice small flush filler cap now to to let into the panel between the rear screen and boot lid
Jan 11, 2012 20:06:21 GMT
Not found a small flush lockable filler cap and neck yet so fitted a 9 inch fan to the chargecooler rad in the front. had to weld litle tabs with studs in to the rad itself, cut off an original fixing lug and alter the bonnet release lightly Anyone suggest a source for a flush lockable petrol filler cap and steel filler neck ??
Jan 11, 2012 23:30:40 GMT
not sure if the neck is steel but fiat panda (original one) & cinq have a small locking cap
theres more to life than mpg & to much power is just enough.
Jan 12, 2012 12:52:09 GMT
Cinq ones are domed, although still quite flush, but mounted upright it'll jam worse than it would in a Cinq. Shame it's not a round rear light model else I'd have suggested a mk1 Fezza cap to echo the rear lights img.photobucket.com/albums/v53/sp_69/10112009224.jpgMk4 Escort caps were nearly flat and locked and lifted out by the key? You'd have to recess it in though.
Jan 12, 2012 18:05:55 GMT
Will look into those options, cheers I need to sink the cap in so its flush as the bootlid would hit it in the open position As the panel is only flat for 75mm any cap i french in will have to be undone and lifted out with the key Underneath the panel the pipe (32mm) will have to turn 90deg into the side of the tank
mikeymk
'85 Polo Coupe S 1.6 16v
Jan 12, 2012 19:13:09 GMT
You don't get more flush than Rover Metro/100 filler caps (not Austin), think there's a slight profile curve to them, though.
Jan 12, 2012 21:03:57 GMT
just scanned the 11 pages of this and i gotta say awesome car, awesome engine, awesome fabrication you ticked all my boxes with this one, only thing that i find a little worrying is the bench seat haha, good luck keeping your ass in the right position with that monster under the bonnet throwing you around! i'll check back for a proper read later on, top job.
Jan 13, 2012 18:23:01 GMT
Not done the filler cap yet, been looking at wheels, plus ....Brakes i have sorted the wheels, 6x15 Peugeot. With 195x50x15's these are a smaller overall diameter than the rostyles with 165 13's now to find bigger brakes. Whats the options for bigger vented discs on an escort leg with 15 inch wheels ??
smeden
"Full throttle until you see God,then shift to second"
Capri 2.8 I, If you go for 16 inch then try out focus st 170 They are 300 mm on the usual 4 stud pattern.. (mondeo mk 3 kalibers)
Jaguar xj6 S1 swb manual VW Bay Camper Audi A3 1998 1.8 VW Beach Buggy (sold) Ford Mondeo mrk I RS Celebration (written off) Ford Escort Mrk II RS 2000 (rust in peace)
diff
Cheers guys, I have opted for a pair of Peugeot discs 305mm dia. which like the renault ones will have to be redrilled for it to fit on the back of the escort hub. Cossie calipers sit proud of the end of the disc by 30mm making an overall dia of 365mm I just measured inside my 15 inch steel wheel........366mm If i don't paint the calipers they should fit inside the rim
Last Edit: Feb 8, 2012 10:36:28 GMT by EssexRich
Chops
Don't touch me I've been somewhere
Club RR Member Number: 36
Feb 15, 2012 22:39:58 GMT
If I don't paint the calipers they should fit inside the rim Legend
Feb 24, 2012 20:11:03 GMT
Well not done the filler neck or got the brakes sorted but the discs look neat Have won a pair of Porsche Brembo calipers on E-Bay , so once the discs are redrilled its down to make some Brackets to hold them
Thanks Essex Rich I did consider a bike filler but the diameter is too large for the space i have available I got a Saab filler neck and after market cap Just had half hour and made a ring to countersink into the panel under the rear window hit it hit it some more done Just have to cut a hole the right size in the car panel and don't distort it when i weld it in
Mar 10, 2012 21:22:16 GMT
Got myself a pair of porsche 944 Brembo calipers only to find they don't fit over the disc which is 28mm thick Another bit of searching and I got another pair of Brembo's which will fit on a 28mm disc from an Alfa Romeo only thing is they are MASSIVE 270mm long Cortina,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,Porsche,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,Alfa Will try them on the disc on the car before I decide if I am keeping them
Last Edit: Mar 15, 2012 19:02:16 GMT by sierra1off
