After much tomfoolery this weekend I ended up chopping too much off the rear springs of the daily volvo. This was the result: My situatin is being resolved by means of the pruchase of replacement springs so I can chop less off Any one else feel like adding some of their own low cars?
MrT
Just who did Mr Hitler REALLY think he was kidding?
Back in the early to mid 09's I rolled in this 1430 powered beast: Afew years later I knocked up this 2.3 FD 'wagon: I didn't build this A60, but it's getting a very slow resto/kustom job in my garage at the moment - what you might call a 'long term' project: And fairly recently was this 1.8 Pissrat woodie I built 'just because I could': There have been many more, I just never get round to taking photos
BiAS
Insert witty comment here
Club RR Member Number: 147
That looks spot on to me Presumably 'too low' because it's on the stops? Shorter stops and shocks is the answer. too low = does not compute ;D
(car+wheels)-rideheight=WIN
i have got to have an fd one day
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
dan74
that's not too low! bring the front down another inch to compensate
Give it some Flannel
1962 Mercury Monterey
1964 Triumph Bonny Chopper
1972 Harley Davidson FX Superglide
1990 Tomos A3 MS
2001 VW T4
rtlkyuubi
Low and Slow
my old micra on choped springs: (thanks for the picture petesc ;D)
Looks perfect to me! The rear looks lower because the arch is lower than the front - the sill is perfectly parallel to the ground.
Unless the wheel is fouling something or it's sat on the stops, but there are ways around that! ;D
looks fine to me!
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
my old skoda jeeezzzz i miss that car !!!
A lot of these cars look lower than my car, but I have less ground clearance! Damn and blast the oddly shaped underside and arches of my Lupo!
standard - mine mine and benzboys
bazboy
Jetta - Its like a golf but better.....
Yes yes yes yes, do it dave, that looks so sweet, really annoyed i missed out on being around when this was done!!!
Dan
1986 - VW Jetta GT 16v 1986 - Volvo 340 1991 - Volvo 460
I had to make a ramp to get it out of the garage yesterday.
I think when I get bigger wheels it will look a little different. - and rasie the ground clearance a bit?
I'm now looking for harder shocks and springs for it. as its a bit on the bumpy side.
It is running on the bump stops on the rear.
Dan, It will still be like this on Saturday I should think.
chaseracer
If you have to ask why, you will never understand...
My Dyane is low- ish... ...low enough to cause a few scrapes underneath during the recent Salisbury Plain malarkey. Not as extreme as some in 2CVGB, though! ;D
No springs at all!
BiAS
That is such a good look What suspension set up does the imp have on it? Could you actually run an Imp that low?
Last Edit: Jan 4, 2009 17:41:38 GMT by BiAS
murran
mines a little lower that that now as its on 60 profile tyres insted of 70s
Bah, that's a whole fist of clearance! lol My Audi is the lowest I have pictures of... I could just about squeeze two fingers under the wishbone mount. My MS112 CROWN was much lower, I wore the downpipe into a C section and took about 1mm off the frame rails. Had to be very precise when changing motorway lanes, otherwise the catseyes would hit the chassis rails.
Last Edit: Jan 4, 2009 18:41:22 GMT by jettadeluxe
Seth
My A35 was the only car I've had with very cut springs. The sump used to bounce off the road occasionally. The Oxford will be lower, at least at the back though possibly a bit more on the front too, when it returns. Midway with the Hillman...
61stu
My daily down about 4 - 5"
