Dec 31, 2008 19:11:47 GMT
kilroy
i totally forgot about getting panhard rod brackets cut befor chrimbo,same as the front shock towers. tried to get as much as possible done but sometimes you need to start building befor you can design the next peice. all those bits plus exhaust brackets will get designed and installed in a couple of weeks.
2009 I'm gonna start a couple of new cars later in the year.one for my wive and one for a local bloke. both will be better than anything ive done so far.far more trick and totally different.
find the more you build the more you learn and the more my imagination grows ;D. one thing with this car and the mini is ive set the front ends up slightly different. because I'm still learning about front suspension its kinda trial and error until there on the road and i can get feedback. both owners know this and understand their cars may need to come back for final tweeking.
a good 2009 to you. still 08 here at the mo.
prostreetpop. shoot me a pm or email through my profile
Dec 31, 2008 19:29:49 GMT
Email sent
Excellent work and progress! PM sent
James
owners round first thing to mock up body. then back on my own. measured slightly wrong on this piece so had to do it twise. still sticks into the windscreen area a bit but no other option as we wouldnt be able to lift the body of if we go wider
Nice job there wayne cutting the frame for the exhaust has given the car good ground clearance. Its also nice to see a pop with standard rear arches
managed a few hours after work today to do a bit more on the cage
wayne you just carnt sit still for more than 5 mins can ya!!!! looks the nuts see you in the morning
Cars looking real good there Lee I take it the 4 brackets on the spreader bar are for the flip front ?
Cars looking real good there Lee I take it the 4 brackets on the spreader bar are for the flip front ? you got it mate, wayne being wayne always thinks 10 steps ahead ! there be moved to suit when the fronts being fitted
Cars looking real good there Lee I take it the 4 brackets on the spreader bar are for the flip front ? you got it mate, wayne being wayne always thinks 10 steps ahead ! there be moved to suit when the fronts being fitted Yeah I find it hard to belive what vision Wayne has he does seem to be able to plan weel in advance. There are a lot of builders out there that cant do this and to progress with the build they are working on start hacking about the new work which is a shame as then its never the job it could have been
Inspiring !!
Ace work there Wayne.
Jan 10, 2009 18:21:10 GMT
day 11 half day today narrowed steering rack pic shows it held in place on a temp jig. bump steer gauge is hooked up to right hand hub just need to mount the rack brackets now
lae
Jan 10, 2009 18:53:15 GMT
Wicked stuff there, hopefully inspiration for me to get on with a proper project
Currently: Mk1 Focus blandmobile
Formerly: 1969 MG Midget 1972 Avenger GT 1981 Datsun Cherry 1989 Corolla 1979 Mercedes W123 200D 1995 Ford Falcon 1996 Ford Telstar (bet you had to google that one)
Jan 10, 2009 22:26:32 GMT
How does that bump steer gauge work? Or is it beyond a few lines in a forum?
You never know when a mohican vintage car enthusiast will come in handy.
Jan 11, 2009 17:29:11 GMT
Wayne how do you go about shortning the rack ? as it looks like you have shortend the center section.
Jan 11, 2009 19:55:32 GMT
How does that bump steer gauge work? Or is it beyond a few lines in a forum? bolt the plate up to the hub. plate has measurments on it. put rack in the place you think it should go. wind up suspension and read the dial gauge to see how much the front toes in or toes out. alter rack possition till you get it spot on. prostreetpop. inner centre section is narrowed. do that first as its lengh is determined by the ball centres of the arms with the rack in the right place for no bump steer. then the outer arms were lenghtened. then jig back up with the casing on . move wheels so they don't hit anything on full locks(mot failure) and shorten outer casing to suit. you have to be carefull because if say you took 4" out the inner bit you may only need to take out 3" from the case. you could build youre front end round a standard rack that way it wouldnt need narrowing but all the pivot point have to line up correctly. you need a few tools as well. used for rack narrowing,chopsaw,lathe,grinder,press,tube jig,tig welder,centre punch,drill and assorted odds plus the jig i use for determining the correct rack height and width.
Jan 11, 2009 20:52:56 GMT
Hi Wayne,
Well, all i can say it looks great, your work and engineering skills are top notch. I wish i had your garage as a base for my mini.
love the fabrication work, i hope to see the lee`s mini along at one on the mini shows this year.
Andy
andy-leach.piczo.com
Jan 17, 2009 17:53:16 GMT
cheers andy off the jig today. way off with spring rates so fronts sitting on a bit of wood for mock up. front shock top mounts fitted.adjustable to give 3 ride heights. on the floor exhaust brackets all done now. panhard rod installed what you see if you looked under the rear
Jan 17, 2009 21:10:27 GMT
VERY smart... i like your work .... fancy doing another one, for another 55 pop, only this time for free? ;D haha. just kidding keep it up dude... love it!!
1955 Ford Popular 1989 VW Polo
Jan 17, 2009 22:55:58 GMT
Wayne may I ask what bushes did you fit in the engine mounts ? also when are you gettig back on the Mini ?
Cheers
