The Doctor
Club RR Member Number: 48
tire questionThe Doctor
@thedoctor
Club Retro Rides Member 48
Dec 12, 2008 21:29:01 GMT
strange question maybe, but should I be able to see the differance in width between a 195/45/13 and a 175/50/13 tire from the same manufacturer and model (Conti Sportcontact). They have the some rolling radius, so they must be equal in height, but I must be able to see the 2cm difference in widt? because I placed my tires next to my wheels and saw this: I know about stretchen and it being dangerous etc. etc. but i've seen an 195/45/13 on a 9J wheel before and it didn't looked as dangerous as it does like that on my pic. I have a strange feeling that i, even though I ordered 2 different sets (and it says 195/45/13 on the label AND tire itself) I received 4x 175/50/13? //edit: fixed big pics
Last Edit: Dec 12, 2008 21:32:39 GMT by The Doctor
tire questionstealthstylz
@stealthstylz
Club Retro Rides Member 174
Dec 12, 2008 21:32:24 GMT
You should be able to see the distance? What do the sidewall markings say?
Matt
The Doctor
@thedoctor
Dec 12, 2008 21:33:29 GMT
sidewall markings say 195/45 on the 195/45 tire and 175/50 on the 175/50 tire, but when layed on the ground they are both the same width and sidewall height etc.
@stealthstylz
Dec 12, 2008 21:37:21 GMT
Try and get in touch with continental see if they've sent a dodgy batch out.
Matt
Dec 12, 2008 21:41:56 GMT
The heights will be very similar - 45% of 195 is 87.75 cm, 50% of 175 is 87.5 cm, so no problem there.... as for the widths, the photo is a bit deceptive, have you physically measured them, using common points, ie the outermost tread line?
The Doctor
@thedoctor
Dec 12, 2008 21:50:09 GMT
i haven't measured them, but i layed them next to eachother, and they are exactly the same then. I thougt a 2cm differance in width should be visible, right? maybe this picture is clearer:
Dec 12, 2008 21:55:09 GMT
Better photo - The one on the left there is definately wider in the sense that the tread extends further towards the edge. I would say once fitted it will have a wider footprint - it just needs to be "pulled" outwards, which the fitting will do. As for the stretch, The rear of this, (pinched from the ebay thread) is a 195 45 on a 9" rim...
Last Edit: Dec 12, 2008 21:55:43 GMT by dave21478
The Doctor
@thedoctor
Dec 12, 2008 21:58:32 GMT
yeah, about the stretch, I knew it would be possible with too many dangerous effects, but seeing the tire laying next to the wheel and they SEEMED to be the same in width as the 175/50s scared me But now I look at it again, you may be right, ah well, lets roll out the hairspray tomorrow! ;D
Last Edit: Dec 12, 2008 21:59:02 GMT by The Doctor
