jikovron
mechanical chaos
Sept 17, 2008 19:33:17 GMT
a colleague off mine wants to build a sort of street sleeper out of a nissan k10 ,,,the idea is to buy a clean cheapie and fit a larger engine from a primera or almera 1.6/2.0 (will it fit without modded driveshafts and body chopping) pics are poo but couldnt find many of modded k10's take a well cared for micra either tune or wip this out and possibly bolt this in for instant power increase what other small hatches can be modded this way (like bolting 2.0 passat engine into breadvan polo's etc) thanks in advance
Sept 17, 2008 19:51:23 GMT
Cherry turbo transplant reasonably straight forward. CA18 (from S13 200SX) will fit if you use a Bluebird or Sunny ZX coupe gearbox. Fitting Primera/Almera/Pulsar engines can (and has been) done but it isn't straight forward at all.
Sept 17, 2008 20:06:21 GMT
Fiat Uno Turbo/Renault 5 turbo with the bodykit removed and the boost turned up is probably most simple.
Matt
Sept 17, 2008 20:28:51 GMT
Buy a crashed Saxo VTS/106 GTi and an old Citroen AX or 106 base model, swap the engine and suspension over and leave most of the interior out.
Without much aggro you will have a very capable sleeper - 0-60 in low/mid 7s, and brilliant handling, the only downside is the VTS engines are the most powerful thing you can bolt into a 106/ax without lots of fabrication, and they are expensive to extract more than 130bhp out of.
rtlkyuubi
Low and Slow
Sept 18, 2008 0:38:11 GMT
to fit the sr20 or ca18 engine into a micra you need custom driveshafts. micra at the hub and primera at the gbox.
or you could drop the engine out of the k11 into it. 1.3 16v with mods will go well in a stripped k10 (700kg - 800kg)
Last Edit: Sept 18, 2008 0:39:49 GMT by rtlkyuubi
Sept 18, 2008 5:51:15 GMT
what about getting a figaro engine? thats based on a micra but its turbocharged, mate it to the normal micras manual gearbox and then wind the boost up
rtlkyuubi
Low and Slow
Sept 18, 2008 8:58:05 GMT
what about getting a figaro engine? thats based on a micra but its turbocharged, mate it to the normal micras manual gearbox and then wind the boost up the ordinary gearboxes are made of cheese and fiagro and ST engines are like poor quality wobbly children's play pony poo.
Sept 18, 2008 15:08:04 GMT
1.3 16v engine and turbo it with a t25 from an s13,hks manifold from a cube turbo kit and low comp pistons and fancy internals,stand alone management and custom mapping,fmic etc should see 150bhp at the wheels. i know as my mates building one.
jikovron
mechanical chaos
Sept 18, 2008 15:45:09 GMT
thanks for the input,,i had an inkling that the k10 was not a parts bin car (driveshafts can be chopped and bobbed cheaply ,,,,,bit of tube over the outer dia then welding and doweling should do it)
the candidates are so far : micra with various engines renualt 5 campus with a 2.0 engine (plus 480 turbo bits added) vw polo breadvan with 2.0 passat motor (or whatever bolts in) fiat panda with fiat twincam ford fiest with zetec 2.0 fitted
we hope to use engine out of scrapyards (i can get them for next to nowt) then over a weekend bolt it in (fiddle with brackets/exhuasts/wiring) to whatever lightweight is aquired
a micra weighs 645kg in base trim/all the other cars weigh this too exept the renualt at 795kg so stripping these may get them under 550kg (compared to modern superminis being rarely under the ton
LAndy
Sept 18, 2008 15:49:36 GMT
its easy to get 130+ out of a VTS engine, a 4-2-1 mani, induction kit, better ignition leads and plugs and exhaust system will sort that out np.
cams and bike carbs will easy see 140 brake then its down to remapping.
Previous retros: 92 AX GTi 92 Scirocco Scala 94 80 sport 87 Golf Cab GTi Current retro: 1965 Clark Cortez YouTube Website Instagram
Sept 18, 2008 15:51:06 GMT
How about a cheapo pov-spec Peugeot 306 with a Citroen XM Turbo engine? That could be a giggle...
rtlkyuubi
Low and Slow
Sept 18, 2008 16:26:37 GMT
thanks for the input,,i had an inkling that the k10 was not a parts bin car (driveshafts can be chopped and bobbed cheaply ,,,,,bit of tube over the outer dia then welding and doweling should do it) the candidates are so far : micra with various engines renualt 5 campus with a 2.0 engine (plus 480 turbo bits added) vw polo breadvan with 2.0 passat motor (or whatever bolts in) fiat panda with fiat twincam ford fiest with zetec 2.0 fitted we hope to use engine out of scrapyards (i can get them for next to nowt) then over a weekend bolt it in (fiddle with brackets/exhuasts/wiring) to whatever lightweight is aquired a micra weighs 645kg in base trim/all the other cars weigh this too exept the renualt at 795kg so stripping these may get them under 550kg (compared to modern superminis being rarely under the ton the cheapest would be the micra but as you said nothing is off the shelf, which if your doing it yourself will keep cost down! Micra's are incredably simple! But I don't think they weigh that little in standard trim, more like 900kg.
jikovron
mechanical chaos
Sept 18, 2008 17:11:57 GMT
the weights were looked up in the haynes manual for kerb weight a 850 kg car would include a mk1/2 escort or a hillman avenger ,,,,,,,,,1000kg car/volvo 340 or triumph dolomite 1850/ 1400kg car would be a rover p6 3500 or a volvo 240 just shows how wide a range there is in cars weights 550kg between saloons that are similar sized
a polo breadvan/metro feels lighter than they are considering you can lift it so both rear wheels are off the deck (its unervingly easy to do ,,hence why power to weight ratio even on 120 bhp would be high)
i'm hoping he gets micra because it's not a obviouse performance charriot ,,,,,,,,,,,,,more of a connieseures sleeper ,,,,,,,mmmm maybe abit tenuous
i like your (RTLKyuubi) micra ,just the right amount of lowerage and the blackboard bonnet makes it look rather cool
kee
Sept 18, 2008 19:20:04 GMT
you would struggle to get it down to 550kg, you'd struggle to get a mini to that, never mind a micra.
my fiesta is no doubt lighter than a micra at around 700kgs fully stripped.
a mk2 fiesta will take a zetec easily with only a couple of choice mods needed. plenty of power upgrades for the zetec and theres millions of the engines around.
berendd
Sept 18, 2008 19:33:00 GMT
passat engine in breadvan?
maybe in the back but it's absolutely not a p&P job
buy a suzuki swift Gti (MK1 or MK2 )and have fun with it!
rtlkyuubi
Low and Slow
Sept 18, 2008 22:40:39 GMT
the weights were looked up in the haynes manual for kerb weight a 850 kg car would include a mk1/2 escort or a hillman avenger ,,,,,,,,,1000kg car/volvo 340 or triumph dolomite 1850/ 1400kg car would be a rover p6 3500 or a volvo 240 just shows how wide a range there is in cars weights 550kg between saloons that are similar sized a polo breadvan/metro feels lighter than they are considering you can lift it so both rear wheels are off the deck (its unervingly easy to do ,,hence why power to weight ratio even on 120 bhp would be high) i'm hoping he gets micra because it's not a obviouse performance charriot ,,,,,,,,,,,,,more of a connieseures sleeper ,,,,,,,mmmm maybe abit tenuous I like your (RTLKyuubi) micra ,just the right amount of lowerage and the blackboard bonnet makes it look rather cool hehe thanks, just don't steal my idea of sr20det + rwd + Micra
Sept 19, 2008 7:29:45 GMT
I don't think you'd get a Micra to 550kg without a lot of fibreglass panels. My Uno comes in at 690kg as it is, and there's not a lot to remove once the seats and dash are gone.
Matt
Tefal
Sept 19, 2008 9:45:03 GMT
get a rover 100 metro poverty spec one and put an 1800 in it
jikovron
mechanical chaos
Sept 19, 2008 14:16:33 GMT
i'm liking all the idea's thanks for the input a 1.8 metro really would be the the beans..... i was talking to the fella today and putting the point across that if it looks completely standard (except maybe wider steely wheels) then taking something expensive at the lights would be more fun than doing it in a car thats expected to be fast (his gaze has been cast over hatches on the bay so these ideas should give some inspiration on what to buy)
ooh and rtlkyuuby i don't reckon we'll be making it rwd turbo powah armed with a few hundred quid and a weekend so no need to worry about mechanical plagiarism also i'm a A-B series/fiat twincam man so i wouldnt even know an RB26dett from a sr20det,,,,,,,or a rbx-gt2,,,,,,,,,,i will eventualy learn lmao
Sept 19, 2008 17:39:07 GMT
