Jun 21, 2008 12:41:05 GMT
Oh yes, one thought that's just come back to me is that I seem to remember something about fitting the freight rover cover when retro fitting the NAD as it changes the position of the injection pump either higher or lower(can't remember which) for clearance.
Also avoid the TD version of the Land Rover 'red block' engine(2.5 NAD as per ebay unit). Basically it was a stock lump with a turbo strapped on and has a tendency to pressurise the crankcase and blow its own seals
2014 - Audi A6 Avant 3.0Tdi Quattro 1958 - Chevrolet Apache Panel Truck 1959 - Plymouth Custom Suburban 1952 - Chevrolet 2dr Hardtop 1985 - Ford Econoline E350 Quadravan 2009 - Ovlov V70 2.5T 1970 - Cortina Mk2 Estate 2007 - Fiat Ducato LWB 120Multijet 2014 - Honda Civic 2.2 CTDi ES
Jun 21, 2008 13:03:41 GMT
Is that NAD that I posted a good, cheap and quick way to get rollin' on oil? Bolt in jobbie?
My new Land Roverarthurbrown
@GUEST
Jun 21, 2008 13:12:51 GMT
Cheapest & easiest, not spectularly so. And you'll still want that OD.
Jun 21, 2008 16:41:44 GMT
If they're cheap enough I'm so getting overdrive. Anything that's cost effective to increase fuel economy and top speed on a run like that is worth having
alex
Jun 21, 2008 18:51:23 GMT
Cool Landie Stronger chassis on an ex-mod Landie? Hows that then - didnt realise that. Mine is ex-mod...but then 45 years or rust probably doesnt make any difference anyway (will be strong as nails after we have finished with it though ) Good thing about the ex-mod ones is the extra fuel tank (although like mine, a lot of them have been removed, but at least it has the outrigger). £375 is a good price for a runner. You sometimes see them go for a silly prices (partic if they seller gives it a quick going over with a paint brush for some odd reason!) LWB is deffo the more practical approach for long trips (hence going for a SWB lol)
1974 Rover P6 4.6V8. Land Rover Series 2A 2.25 "overland spec". RRC V8. Celica GT4 ST205 Garrett 3071R 366BHP.
alex
Jun 21, 2008 18:52:34 GMT
Oh and autohausdolby - a good way to increase fuel economy a bit and reduce noise is to fit an electric fan.
Regards
Alex
Last Edit: Jun 21, 2008 18:52:47 GMT by alex
Jun 21, 2008 21:30:49 GMT
I'm going to scrapyard one right up for it, probably with an override switch on the dash. I'm used to driving rear engined, front rad water cooled VWs, so I don't like to leave anything to chance ;D
alex
Jun 21, 2008 22:02:50 GMT
scrapyard is the way, far cheaper than Kenlowe! yeah I will have an over-ride too, makes sense just incase
Incidentally if you don't want to do a 200tdi conversion but fancy a diesel I have got an uber rare 2.25 turbo diesel coming out of a landy soon. (personaly I would do a 200tdi) I will talk to the co owners about price but i would imagine about 150ish, it needs a fuel pump as the previous owner ran it on veg oil and knackered it, however replace it with a bosch pump and fill one of the dual tanks with diesel and one with veg oil.
bstardchild
Club RR Member Number: 71
My new Land Roverbstardchild
@bstardchild
Club Retro Rides Member 71
Jun 22, 2008 10:03:16 GMT
Picture the scene - Last Sunday morning, Manchester airport. Autohausdolby buys a Land Rover magazine of some description. Fifi: When I get home, is there going to be a Land Rover sitting on the drive? AHD: No! Fifi: Course not, my car lives on the drive. Will there be one on the road in front of the house? AHD: That would entail buying a working one. Fifi: Will there be one in your workshop then? I've met you before.... This thread appears 4 days later! ;D AHD - Fifi has you totally nailed ;D
Jun 22, 2008 10:18:29 GMT
"Your mileage may vary" - another words, just because I didn't have any trouble with my OD it doesn't mean you won't! And what do they normally go for? Can't help there - we just got lucky and someone gave it to us (and a load of other LR stuff). I'd serious recommend posting on all the forums you frequent about this trip and the charities it supports, etc. You'd be amazed at what good fortune can pop out of woodwork
Jun 22, 2008 11:04:40 GMT
We have fitted fairy overdrives to all our 200tdi landies as it is essential for getting up to decent speeds, you can change the diff for a rangerover one which is a better ratio but not if you have the salsbury(sp?) axle which you should have on the ffr, the overdrives are reeeeeaaly easy to fit and all ours have been reliable although some are noisier than others suggesting different amounts of wear, they generally go for about 300pounds but make sure if you buy one you have all the parts such as the gear which bolts to the gearbox before you slot in the overdrive and the lever etc as although they are available they are expensive. The NA 2.5 diesel engines are low power but probably much better than the 2.25 (even with a turbo) I would probably go for that on a budget, they were also put into most military landies so will have been well looked after. Hope something there helps. if you want any more specific info let me know. no more time got to go.....
2.5 is it then
Jun 24, 2008 20:43:32 GMT
I have a twin Kenlowe fan and relay set from my old range Rover £20 if anyone wants it.Also have a set of 4 750x16 wheels and tyres,there all odd and ones on the limit but might get someone out of a fix £45.I know its abit cheeky of me to hijack the thread but i thought you guys might be interested
Jun 28, 2008 22:59:17 GMT
rtlkyuubi
Low and Slow
top buy! Ive got an electric fan you can have sat in my garage. 12v though :/ or is it just the auxillaries that are 24v? Ryan.
Last Edit: Jun 29, 2008 0:43:45 GMT by rtlkyuubi
Cheers fella - it's all 24 volt at the moment, but I suspect it won't stay that way for too long
Jun 29, 2008 21:02:44 GMT
Popped in to work today and rid the poor thing of the terrible yellow brushed on paint on the front bumper and the rear cross member. Photos soon
Jun 29, 2008 21:39:42 GMT
what ya got that then for...? whats up with that then...? your mad you are I assume squeeky's been for a nose? If not, have fun tomorrow morning ;D Should be over about mid day. Cant help but think you should change the badge to 'sand rover'
rtlkyuubi
Low and Slow
Jun 29, 2008 22:05:15 GMT
want me to bring that fan tomorrow or tuesday? I wanna come nosey ;D also do you want the temp switch and radiator?
Ryan.
