Mar 15, 2008 21:03:19 GMT
well, some of you willl have seen some sneaky preveiw pics on the day I got it, others weren't so lucky. so I thought I'd best start a thread that I can lose its the first car I've ever brought of ebay, I got it after getting all deflated. I got chatting to a guy about a 1948 ford f-1 pick-up (dream vehicle for me) and took his number. but he wrote his number down wrong, ARRGH! after some efforts to get it straight and failing, i spied this and gave the bloke a ring. I won it on the friday, and trailered it back from leicester on the sunday with help from spacekadett. the car is a 1982 wartburg knight in the 353 body style, sometimes the 353 designation being used instead of knight. it was white and has been badly and hastily painted brown. while I like brown, i don't like that brown. really obscure (for anything other than what originally had it) paint will be applied before registering it . it was brought over from hungary for the warner brothers film Mrs Ratcliffe's revolution which starred Catherine "something about pre-politariate europa" Tate. never seen the film or even her sketch show, which means I have no commitments to keeping it anywhere near standard ;D ;D its unregistered so i have that little hurdle to get over, however the windscreen presents more of an obstacle to me. want some pics? look at those 4J steels, wow! photoshop anyone? positive camber?!?!?! no way.... cool feature^^ wartburg emblem embossed into the front rubberised carpet section more in a sec......
Mar 15, 2008 21:14:08 GMT
there's the 2 stroke 992cc engine in all its glory. job 1 was have a look at this little lot- the conneting pieces of the column change. its pretty easy, easier than the floor shift version! I've made it so all the gears are now "gettable" but its not right. suspension wise, this is the rear. semi trailing IRS with some convinient coilover mounts and new shoes!! this is the front end. double wishbone, discs and four pots. you can see the dual line master cylinder in that shot. had a look at fitting these today. just too much offset for me. you can see my laser tool shining up the wheel well and the very outer pice of the arch. if they were 8j maybe you could stretch some 165's on to get some clearance but they're only 7's. they look good, but comprimise the stance being out that far IMO. when it drops, the wishbone will push it out by another 15mm or more to boot but they do look teh secs!!!! end of updates for now, enjoy!
Mar 15, 2008 21:29:34 GMT
A bloke on the railway had an estate version of one of them - painted it red oxide and polished it........ Anyhooo, he ran out of petrol on the way into the carpark one day, so mixed up some lamp oil (paraffin), trico111 (solvent) and diesel and ran it on that. It started, ran, but put out so much smoke the carpark disappeared! Nevertheless, he drove across Norwich, topped up with 4-star and carried on as if nothing had happened. Bloody bombproof!
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
Mar 15, 2008 21:37:42 GMT
;D estate is called a tourist this ones had too much oil put in the tank, kinda smokey ;D they should run 40:1.
Mar 15, 2008 21:49:50 GMT
I know of a VERY sad RHD one of these - it's about two miles from my house. Quite a long way beyond rat-look and parked up outside many, many years ago just because the brakes needed some work.
Mar 15, 2008 21:51:33 GMT
Never seen one before.... didn't expect to see disc brakes, or double wish bones.
I'd rater push my retro Toyota than drive anthing else....
I know of a VERY sad RHD one of these - it's about two miles from my house. Quite a long way beyond rat-look and parked up outside many, many years ago just because the brakes needed some work. OOOOOH! might that be up for grabs in exchange for some wonga? that would be V handy, speshly if the windscreen's good. could you enquire please, mate?
Seth
Looking forward to watching this on Edd - it really is bonkers! Also wasn't expecting discs but then I guess by this late its not that suprising. Does it have a free-wheel? That would alse explain decent brakes. I find it amazing looking at the engine shot that it really is no different in layout to a pre-war DKW or something! I think you need to find a triple throat Weber for it
Mar 16, 2008 10:14:27 GMT
^ is that it? ^
Mar 16, 2008 10:15:55 GMT
Mar 16, 2008 10:30:05 GMT
wickedly ugly but loving it
loving the dub
1982 wartburg knightmilfordcubicle
@GUEST
Mar 16, 2008 10:38:45 GMT
They make the most wonderful noise, nice buy.
1982 wartburg knightstealthstylz
@stealthstylz
Club Retro Rides Member 174
Mar 16, 2008 11:16:35 GMT
Are these made of plastic? That red version is oooooof bar the panel gaps lol. Gonna be cool whatever you do to it.
Matt
Mar 16, 2008 11:22:07 GMT
Good lord Ed......double back flips over here in excitement. Whats the PCD ! !?!?!
street
6.2 ft/lbs of talk
Mar 16, 2008 11:38:24 GMT
Woah, this was unexpected!! Excellently obscure purchase, glad its in good hands and cant wait to see what you do with it
Mar 16, 2008 16:53:29 GMT
right, Q&A time, I don't know how to multi quote-sorry . yes it has a freewheel, but its switchable. ie. you don't have to use it! it has only got 7:1 compression though so not much engine braking for the moment. early ones were drum allround same as the 311 and 312. geuss they went to discs at the same time they rallied the 353w-rc- mid seventies? that made 90kw in the power stakes don't think that one is it rmad, but I don't know. black interior by the looks of it and the faked plate is wrong. the plate mine sports was knocked up by the film crew you see, so its unlikely they hung 2 false ID's on it. the red one on smoothies, haven't seen that one before its a water cooled polo based one tho. they facelifted and changed the running gear about '87 AFAIK. no it ain't plastic. its all steel construction on a separate perimeter chassis. trabants were duraplast body panels, made by the same people as the wartburg (IFA) I believe. PCD is 4x160, so this and trabant really I can get adapters at 380 euro a pair think i'll get some knocked up, hence trying to fit cookie cutters. the plan at the moment is to find a screen. I tried an e30 which is the right width, too high although it could be cut. completely wrong curvature to even think about grafting in an apperture. and yes, I would go as far as grafting in another screen apperture in if I could find a screen close enough. then get it mot' and reg'd.
Mar 16, 2008 17:05:47 GMT
can you not get a new screen shipped in through the owners club. i had two new trabbi windscreens sent over. maybe oldbus can help as he,s over there. anyways you're car is so ugly its cool. looking at you're pics wartburg didn't like to change much over the years. Ive got a stock 1956 311 here and the engine is exactly the same as in youres
Mar 16, 2008 17:25:23 GMT
yeah, I think i ought to join the owners club. if there's a laminate "competition" version, I'd certainly spring for that. they surely can't use a toughened 'screen in a rally car?!?! you've got a 311? FANTASTIC I spoke to a guy at the classic motor show about his tuned 311, apparently its pretty fast, quicker than most of the club wanted to go anyway ;D and while photobucket is open, have this- inspiration
Mar 16, 2008 17:45:45 GMT
you may be lucky on the screen. mine that came over were laminated which was a nice surprise as the original decided to shatter into millions of pieces.
car in the picture looks sooooo much better for being lowered.
tuned 311!!! mines going to be tuned.6.3 ltrs of v8 tuned,lol.
mrj
Mar 16, 2008 17:52:25 GMT
if you find a screen over here, i can bring it to the UK, we are coming over end of may.... nice car, btw, try to persuade my Missus to an east german car, but she wouldn't accept one (though she comes from east germany)
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
