Mar 16, 2008 16:45:58 GMT
back to the plot rear valance widened and fitted. tubework round the rear tub is fully welded and ground back and the last job for today was to start the removal of all the unwanted metal around the lower door bits and seals
Mar 21, 2008 10:35:02 GMT
new man size inner sills being made. this joins onto the door step and will be covered by an outer sill at a later date. part of this is the mounting for the body to sit on the chassis
Mar 21, 2008 15:00:03 GMT
pic showing how it all ties in together. got some more tubework to go in at the rear but cant do it until the floor starts going in
Apr 19, 2008 17:02:37 GMT
just dragin this up as i started back on it after a short break. made new wing panels and welded the panel in under the screen. split in wing is where it will flip front widened
Apr 26, 2008 10:29:49 GMT
nothing like a quick mock up to get you motivated
61stu
Apr 26, 2008 11:11:33 GMT
thats bloomin nuts
qwerty
Club RR Member Number: 52
v8 Custom Mini pedalsqwerty
@qwerty
Club Retro Rides Member 52
Apr 26, 2008 11:46:57 GMT
For soe reason I'm seeing this rolling low on big chrome smoothies.....kinda 50's Custom stylee..
Apr 26, 2008 11:51:29 GMT
plonked the engine in roughly where its gonna go. even with the stretch its very tight lenghtways
Apr 26, 2008 11:53:20 GMT
looks great, brilliant skills.
minis look suprisingly good as proper sized cars
Apr 26, 2008 22:09:35 GMT
i've got to agree with that last quote, it looks the dogs widened & streched. thats got to go on air bags mate,it'll be a shame not to. top skills & excellent work fella.
Apr 26, 2008 22:53:54 GMT
This thread is awesome! Can't wait to see how this progresses and the end result!
v8 Custom Mini pedalsstealthstylz
@stealthstylz
Club Retro Rides Member 174
Apr 27, 2008 11:35:44 GMT
I think it looks great apart from the wheels.
Matt
Apr 27, 2008 16:25:00 GMT
pic showing the start of the chassis. this is how the main body,s mounted to the chassis .bolts holding outside part of chassis to sill plates outside shot showing flange nuts welded on. at a later date an outer sill will be added to cover these over. at this stage the body is welded to the chassis table to stop it moving when welding main chassis rails under construction and roughly in possition. they kick in at the rear so the seat bases can be recessed slightly into the floor. exhausts should hopefully run in between these two rails and under the prop shaft. they need a kick up at the front yet for the front suspension to mount on. cars going on air so the chassis will sit on the floor once dumped
That front view looks the dogs mate! I was round at the garage tonight and this car is awesome, Wayne's work is superb as always. (have to say that as he rebuilt my chassis, lol)
Certainly not just another mini thread - great fabrication skills thanks saturday mornings update while my welder cools down chassis rails in place and lots of crossmembers the possition of these all serve a purpose at a later stage of the build front kick up cant do a lot else here till the air bags turn up. then I can fabricate the suspension and steering around them close up of a bit at the rear
Last Edit: May 30, 2008 19:14:00 GMT by nobody
May 30, 2008 19:15:48 GMT
started to fit the sierra diff prop loops fitted and holes cut outa rear crossmember for the exhaust to go through
May 31, 2008 12:58:06 GMT
qwerty
@qwerty
May 31, 2008 13:33:49 GMT
Yet more incredible fabrication!!
Wayne, Mark, Jon ... ;D howdy chaps... Bill here, formerly a Kat now a Fish. Outstanding Wayne, was hoping for more pix and here they are
