Torquesport
Astras all the way!
An excellent write-up as usual Mr.B. You are certainly living my dream and that of many others I suspect! As for smelly interiors. We have two manky dogs and my wife swears by 10:1 mix of warm water/Ariel Biological in a spray bottle. Waz it over the carpets etc, leave a day or so and vacuum off. Smell gone every time!
Been lax in keeping up to date with your thread.
Entertaining as always.
Just to say, I am not sure I have even seen an Uno pickup before.
And of course I do approve.
The Nissan Primeras are totally underrated in my book.
drdick
I was a bit confused when i realised i didn't know what was fashionable in trousers these days - i think i have reached that age Very tight around the leg, low waist and possible turn ups. I do live near Shoreditch mind, so may be suffering from hipster influence
ulver
Spent most of my day off yesterday reading the entire thread. I don't regret it for a second. More please!
'99 Alfa Romeo 156 2.5 V6
Forgive me - I'm not in any way surprised to see this very sad photo.... Hope its an easy fix. :-)
Well I've got a headache today and am not doing a lot so lets have a couple of updates on the fleet. ROVER 75 So I put this on the road at the beginning of February and have been bombing about in it. Its very nice to drive and not desperately underpowered although its a bit undergeared, 85mph is 4000 rpm so its not as laid-back on the motorway as you might like it to be. However its still a very nice way to get about. The steering is beautifully fluid, probably the best I have tried yet on sweepy curving A-roads, its a real joy to use and the car is very comfortable. Does about 33mpg average. I have done a few de-snagging jobs: The heater was cold on the passenger side, much to the anoyance of the current Mrs_nuts who does not own any leg warmers. To fix that I chucked a washing powwder tablet in the cooling suystem then after a couple of weeks flushed and back-flushed the heater matrix. Result: LOVELY WARM HEATER!!! Ace. A very slight knock over rough ground was traced to a track rod end getting tired so that was replaced. Fitted my Sony radio with the correct (and quite expensive) interface to supposedly make the steering wheel controls work (they half worked, you could turn the volume down but not back up!!! Load of cr4p). Basically the car seemed pretty well sorted now and I did about 1200 trouble-free miles over 3 weeks. Unfortunately the day after I was boasting to my dad about what a great car it was, this happened: Just lost all drive without warning on the A38 going to work one morning. I was not caning it and there was no big bang or owt, one moment I was blezzing along, the next you could put it ina and out of any gear without the clutch and there was absolutley no drive whatsoever. I had absolutley no idea what this was all about, I assumed something in the clutch or gearbox had knackered up. Whatever it was, I had a big one right up there so rang up the RAC, joined, and asked to be recovered. After 2 hours some dude in a van turned up and agreed I needed a flatbed lorry as the lard ar5e 75 is too heavy to be dollied beehind his VW van. After another 2.5 hours a lorry turned up: I asked him to recover me to my garage where at least I could get into the Primera and be mobile again. So: By the time we arrived at the garage it was half two, SIX AND A HALF FLIPPIN HOURS since I rang the RAC. Obv the day was a write off so I decided to have a look at the problem. It turned out the driveshaft had come disengaged from the diff!!! WHAT!!!! The driveshaft is held in by the big bearing on the LHS of that pic. Why would that fail in its duty to retain the driveshaft io wonder? I took the driveshaft out for a proper look. The bearing is supposed to be a tight interference fit on the shiny bit of the driveshaft. IN the pic, I had drifted the bearing down the shaft away from its proper spot. I couldnt see anything obviously wrong although the bearing was a bit gritty, not the smoothest. I worked some oil into it which helped a bit but I could not see any obvioius problems. I put the bearing back where is supposed to be, along with some loctite to help hold it, and put it back in. Drove half a mile up the road and back and had a look. It had already worked itself 1/2 inch out the box already. I was flummoxed by this so parked it up, swapped the insurance back onto the Primera and drove home. After thinking about it I decided tha, although I could not see exactly why, the bearing must be at fault as all it has to do is hold and support the shaft and for some reason it was not doing that. You can't buy a new bearing off Rover or Rimming brothers as it is supplied as part of a complete middle driveshaft assy. But, I had noted a reference number off it and eventually found the orignal bearing manufacturers website which gave me the dimensions of the bearing. Some googling unearthed the fact that a Nissan Murano 4x4 has a same-sized bearing holding its driveshaft in!!! So, I bought an aftermarket Murano bearing from an Estonian company off Amazon for £14: Yeah check out my pyjama trousers futhamuckaz! Went back up the garage and took the driveshaft out again: Heres the old bearing: You cant get the bearing of cos of this collar on the driveshaft. I heated that up with the blowtorch which expanded it enough to drift it off without completely mullering it. Then I drifted off the bearing and had another look at it: Would you believe it. A big crack in the inner race!!!! Thats the cause of the problem - now of course the bearing is not gripping the driveshaft properly allowing it to work its way out!!!! Get in. Heres the knackered old bearing: Pressed the new bearing into the housing: Then I had to fit the bearing back over the driveshaft. This was a bit of a war as it was much tighter to put on (due to not being cracked) than it was to remove. It was too big to fit in the press too so I had to use HAMMERS which was not ideal but I got it on and it was still nice and smooth thankfully. Heres the complete reassembled shaft: If I had to do this job again I'd get a tool made up on a lathe to allow the bearing to be drifted onto the shaft via its inner race, you'd need a tube of very specific diameter to fit over the shaft but also fit inside the hole in the bearing housing, and theres not a big gap for that. If you had that tool I reckon you could easily fix this problem to a really high standard for just the cost of the bearing. The only alternative is a complete secondhand replacement shaft, which might well have a tired bearing itself. Anyway with that done the Rover is BACK IN THE GAME, but now that I've swapped the insurance over, I'm not gonna swap it back so its up for sale to make room for more hopeless old crocks. Anyone wanna give me 650 quid for it? I think its a pretty well-sorted 75 now. got a few scuffs and scratches but drives bob-on and should be free of K-series 'Morphy Richards Syndrome' for a good while yet. Low mileage and 10 months ticket. PM me!!!
camper damper
Another car bites the dust
When you said that I was thinking of what my corolla did one night but I did get a big bang and then lost drive and it wasn't a drive shaft
VOLVO 760 Havent got this on the road yet, although i have been chivvying away on it. The main issue with this car was some rust problems underneath. I had a look around found three bits that needed looking at: Battery tray was a bit sad-looking Both footwells had a hole in beside the outrigger, not catatstrophic but reasonably involved to repair properly. The battery tray was pretty simple so I tackeld that first: Chopped out the crustacea; Welded in a new piece; Slathered on my favourite red gloop!!!! Obv I will underseal that before hitting the road. Next i had a look at the passenger footwell: Start by stripping out the interior; Hmm, Yes, I think I can see the problem here Bust out the usual suspects Clean up and chop out the rusty bit of floor; That reveraled a hole in the side of the chassis leg as well Had to chop out part of the outrigger so that I could patch the side of the chassis leg Chassis leg fixed and outrigger put back to normal Floor fixed and painted! Looks like 5 mins work but it took me all afternoon! Anyway that bit of rot is sorted, let the paint dry then put the interior back together. The other side was similar but a bit rustier, I ended up drilling out some spot welds and taking the outrigger right off. Took it ow work and cleaned it in the blast cabinet: Coming together - here I was trial fitting the outrigger I patched the floor and then drilled it so I could plug-weld onto the outrigger The sill flange had been butchered by some ham-fisted jacking so the wrinkled bit got chopped out and replaced; Got it painted up All seam sealed up! All that lot still needs undersealing but that os all the rot I can find on this thing. I've replaced the front numberplate, and I think for a MOT I just need a replacement headlamp, but it seems to be taking me a long time to sort one out!!! Also need to do the cambelt and probably tackle the headlining too as its not very good. But, its coming along anyway! Check out those two SILVER STUNNERZ!!! More news as it happens
Last Edit: Mar 8, 2015 21:16:48 GMT by xbo11ox
Glad to hear that the 75 was an easy(ish) fix, and that it has been repaired. Always liked the first gen 75 - in early '97, I sat in the interior buck at Gaydon whilst there on work experience Looking forward to seeing the 760 all finished - that rot seems to be the only places where the 700s go - not bad for a car of that age! Btw, are you on the Volvo OC forum? If not, worth joining for all the tech advice, and I am sure that they would love this thread - it is certainly one of my favourites on here!
Interesting failure on the R75... one to keep an eye on. Can I linky to the R75 forum for reference plz Mr Bol?
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
By all means!
Rimming Brothers... That really made me chuckle.
JohnK
North East
Nice update - 760 dizzler is on my list of cars to own at some point.
That Fiat looks stunning in that last pic too.
------------------------------------------- 1999 'V' Rover 620Ti 1999 'T' Mercedes E55 AMG 1997 'R' Ford Probe 24v 1994 'M' Nissan Maxima 3.0 1992 'J' Honda Prelude 2.0iS 1986 'C' BMW 728i Auto 1985 'C' Talbot Solara 1.6 Minx 1984 'A' Talbot Horizon LE Ultra 1.3 1978 'S' Ford Cortina 1.6 GL
teaboy
Make tea, not war.
All this messing around with cars is reasonably interesting XB, but I was more shocked to read this:- the current Mrs_nuts does not own any leg warmers. She is clearly far less stylish than your good self. Yeah check out my pyjama trousers futhamuckaz! Keep up the good work. BTW, didn't you used to have a Masser?
It's in his sig *n
I found the Uno sill I had Boll, let me know if its still required.
Looking good, looking very good...
'Thread of the Centuryâ„¢'...
***GARAGE CURRENTLY EMPTY***
Excellent writeup ! Years ago I had a Mk5 Cortina and a Montego estate blow up on the A38, good to see its still doing the business on newer stuff !
1994 Mercedes e220 petrol estate, daily driver. 1998 Peugeot 406 Coupe 3.0 v6, shopping car.
I'M AS SERIOUS AS CANCER WHEN I SAY RHYTHM IS A DANCER So as usual with these updates, another old crate has joined the fleet. I saw this for sale on Facebook of all places, the lad was trying to flog it but reckoned the clutch was slipping. About a week later someone else enquired and he said they could have it for £130 but the clutch was now completely DEAD. I got in touch with him and after a fashion I agreed to buy it for that sum. ANyway I got organised one night and went up to Preston to fetch it. Agreed to meet the lad at a pub, when i got there he said 'I'll be right there, hang on' and shortly afterwards a knackered old Clio with a bunch of lads turned up with some bangin choonz coming' straight outta there. A gangly lad with a rucksack got out and shambled over, and got in my car. We drove round the corner to some side street where this rover had broken down. It all seemed a bit dodgy to me to be honest. I asked the lad if he had the logbook, and the best he could do was 'I think so' and sure enough he did have it, complete minus the 'selling a car to a trader' section. I asked him what happened, he said he'd bought it for £300 to sell on but then after a short while the clutch had gone. I said 'don't you know anyone who'll lob a clutch in it for you?' to which he replied 'I do, but to be honest i just can't be arsed' !!! He was only about 19 or something and looked like he couldnt be arsed with a lot of stuff. The inside of the car honked of dope and was full of pop bottles. The car looked very straight though with no rust, original paint everywhere, 51k on the clock and ran lovely so I thought I would gamble the £130 on it. It fired up alright but the clutch was mega bad, it could just about muster 5 yards in reverse so i pushed it to the end of the street with the Primera and started hooking up while the lad recovered his duvet which was inexplicably in the boot. My small monkey assistant 'Ian' helped to rig up the A frame in exchange for a couple of bananas: I handed over the £££ and set off, it towed fine and we got back about 10 pm. The rover seemed super original, not really a mark on the body, the caramac interior was a bit minging though Original dealer plates and sticker!!!! I ordered a new clutch off eBay (£28 delivered!!!! BARG) and this weekend set to work: Took a couple of hours to get the box out, fairly painless though: To my surprise, seeing as the car was incapable of moving under its own steam, the old clutch didnt look that bad Still, I had a new one so in it went: cleaned the box up a bit with some thinners: When it came to refitting the box I was gutted to find that I am just too skinny and weak to lift it up and refit it. I yarked on until my arms were destroyed (didnt take long) then gave up and rigged up this lot to hoik the gearbox up and in: Spent a couple of hours refitting all the driveshafts, gear linkage etc. Eventuall had it all back in one piece. Went to back it out the garage and..... Its only EXACTLY THE FLIPPIN SAME!!!!! No drive!!! WHAT!!!! After some more research the theory seems to be that the Peugeot-derived gearbox is probably the culprit, the CROWNwheel on the diff is seemingly shrunk on and prone to losing its grip after a while (yeah, I know the feeling), meaning that the CROWNwheel just spins on the diff and the car goes nowhere!!! Seemingly a fairly common problem on the old PSA version of the box. How annoying!!!! Looking underneath it there are big clods of mud in the wheelarches and on the exhaust box, it wouldnt surprise me if the lad I bought it off had been demonstrating his 1337 driving/wheelspinning skills in a field or something and ended up busting the diff like a twa7. Now I am making a plan to get a replacement box but I am gonna try and keep that as a back-up and attempt to repair the existing box using blacksmith technology if I can. Also I have applied for the logbook so fingers crossed I don't get a letter off the DVLA telling me this car is flippin nicked or some such bo11ox. More soon!!!!
Last Edit: Mar 9, 2015 23:30:19 GMT by xbo11ox
THE_Liam
Yorkshire and The Humber
If at first you don't succeed... HAMMERS.
Don't think I've ever seen a 3-door non-GTi/GSi version of these. Nice little rarity, hope it's a cheap fix.
