Feb 22, 2008 13:51:46 GMT
great progress OB, and hats off to u for doing all this work to what was already a sweet van, takes some guts mate. the lines of the engine cover are prime for detailing just like the exterior too!! bonus Thanks trg, was just going to slap some black paint on it and try and cover it with carpet like the rest...but now you´ve got me thinking ;D if u were local id nip round and paint it for u, its gotta be done
street
6.2 ft/lbs of talk
Feb 22, 2008 14:19:08 GMT
Superb work! You've got some nice clamps there too, top notch fabricating and repair work Glad you got the belt problem sorted, looks perfecrt! Keep it up
Feb 22, 2008 18:57:39 GMT
Thanks trg, was just going to slap some black paint on it and try and cover it with carpet like the rest...but now you´ve got me thinking ;D if u were local id nip round and paint it for u, its gotta be done Thanks for the offer trg, what do you think about painting it to match the dash?.....something like this... Superb work! You've got some nice clamps there too, top notch fabricating and repair work Glad you got the belt problem sorted, looks perfecrt! Keep it up Cheers mate, that´s a compliment coming from "the main man" Put a few hours into the radiator/engine cowling. Bit of cardboard cheating again... Welded it all up.... Finally worked out how i´m going to fit the radiator and still be able to access the engine. I´ll cut the middle section down the moddle... ...lengthen the left hand half and weld it in solid... I´ll be using this half to mount the radiator under. ..and the right hand half i´ll fabricate so that it can be screwed down and removed if really necessary.... ..if you get what i mean... You´ll see what i´m ranting on about tomorrow. Thanks for reading my drivel! ;D
Feb 22, 2008 19:05:28 GMT
thats gonna look the shiz all painted up to match the van. nice work fella!
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Feb 22, 2008 19:10:45 GMT
Popcorn time......
thats gonna look the shiz all painted up to match the van. nice work fella! Thanks mate, think i´ll go for carpet on this bit and maybe colour code the engine cowl..what do you think?
mrj
great works as ever, but could it be that you need small feet to get access to the pedals ?
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
Feb 23, 2008 13:02:11 GMT
Brilliant progress and attention to detail!
Feb 23, 2008 20:37:00 GMT
Brilliant progress and attention to detail! Cheers Jürgen, the room for my size 12´s hasn´t got any smaller since chopping the van to bits...it´s always been that tight. I´ll be trying to move the brake pedal over to the left a bit to make a bit more room for the accelerator pedal. Brilliant progress and attention to detail! Cheers mate, just following yours and your brother´s lead! ;D Managed to get a full day in the garage today, you wouldn´t think so when you see what i´ve got done..... As my new "all singing and dancing" ex F1 radiator doesn´t have any lugs for screwing to the van and is all aluminium i´m going to have to make some sort of frame up to fit it. Started off with an old bit of ex firebrigade racking out of the van... and using some of the old angle iron welded up a snug fitting frame.... Then with some more angle iron made up a frame for the VW/Audi fan ( cheers Thorsten!)..... I haven´t got a clue but looking at our daily moderns i think i should close off the gaps around the fan... With a bit of extra strengthening to the tunnel i can now screw the radiator in place and hopefully will be able to fit it all tomorrow... looking through this now i think, is that all?? and it took me the best part of 14 hours to do! Cheers, Dave
Anglia68
Powered By Boredom.
Feb 23, 2008 23:14:07 GMT
Excellent fabricating skills there Oldbus. Will there be any sort of mesh to protect the rad from any suicidal bats?Or indeed suicidal stones?
Excellent fabricating skills there Oldbus. Will there be any sort of mesh to protect the rad from any suicidal bats?Or indeed suicidal stones? Thanks Mr. Anglia, one of the advantages of having the radiator directly in front of the engine (more or less) is that it´s about 2` away from the front grill which will help. Once i´ve got in in place and all the cowling sorted i´ll probaly put some finer meshing behind the grill to be on the safe side.
Last Edit: Feb 24, 2008 10:55:29 GMT by Oldbus
This is better than TV, just hope you do not need to go on strike soon..... ;D
Awesome problem solving Dave.
I just sit here in comfy land and shake my head at your progress.
Feb 24, 2008 10:37:59 GMT
point discovery at this thread much better than beetle crisis
2001 HONDA CT110 (NOT RCV)
Feb 24, 2008 10:57:05 GMT
point discovery at this thread much better than beetle crisis Cheers Herr Net, but this is more than enough publicity! ;D
Feb 24, 2008 11:35:01 GMT
yeah definately paint it to match the interior, the dash is sweet don't think ive seen a pick of it before.
Feb 24, 2008 18:35:22 GMT
yeah definately paint it to match the interior, the dash is sweet don't think ive seen a pick of it before. ....on this one you can see a bit more..trg, just ignore that old git that´s in the way!!! I welded all the original holes (ashtray, horn & siren switches and loads of others) and painted it the same blue as outside.. Managed to get a few hours in the garage today. I was a bit unsure whether the radiator would be sitting to low or not, so fitted it and wasn´t happy with it. It was ok but i still want to drop the front of the van a bit more so need a bit more clearance between the bottom of the radiator and the floor. So made up some new brackets for the top of the rad.... This meant that i could lift it by about 50mm which should be enough. I´ll have to make some sort of bracket for the bottom end but i´ll do that from underneath, together with the radiator cowling. Here´s a pic from the front through where the grill normally sits. Radiator should be ok here, and it´s in a direct line so should get plenty of high pressure cold air through it.. Made a new lid for the master cylinder..... and with a bit of cardboard cutting (it´s like Blue Peter .... is that still going by the way or am i showing my age?) closed up the gap in font of the drivers seat.... ..will use a bit of Sikaflex to seal the bit on the wheelarch, didn´t fancy welding it is it´s all freshly painted from underneath! And that was basically it for today, put it all back together again to make sure everything still fits... Those holes in the cover are where the handbrake rod comes out. This has to be pulled up to put on the handbrake and pushed down to release. I´ll have to move them as the main chassis support now runs underneath that gap, but i´ll worry about that once i´ve got the gearselector mechanism sorted.
Feb 24, 2008 19:44:12 GMT
Well, you have been a busy boy Dave. I just had a date with a tall Blonde..... but I guess you made more progress than me. Well done again, I look at your bending, blending and welding , and just imagine people sticking their noses against your front windo saying.... ooohhh, thats nice ! They will never know just how much work has gone into all of that.
Excellent work, really interesting watching it come together
Faster. Faster. Until the thrill of speed overcomes the fear of death.
bigrod
Luvin' da fabbin'!!
Excellent patience and skillz OB! Keep it up!
If I have to explain, you won't understand. Maximum signature image height = 80 pixels
posam
Feb 25, 2008 12:48:15 GMT
I really need to learn how to weld.. just so that I can make pretty curved bits of metal like you have.. In all seriousmess though, what you're doing is more than just very impressive. Every time I check the thread you've come up with some new piece of fabricating juiciness to solve the latest problem... And all this to a van that was drop dead gorgeous in the first place.. where most people would have settled with what was already an awesome ride.. you just keep adding, and ammending and improving.. I'd love to know what your final vision is for the van.. or whether it's always going to be a case of tweak this, fiddle with that... How do you know when you've reached perfection ??
