Apr 22, 2008 18:48:28 GMT
Nice to see you´re moving on and i´m sure you´ll sort out the leak! ;D Well thats a " NOT " as far as I can see Just been out to have a look ( after a characteristically bad day at work ) My diagnosis - the head gasket hasn't taken properly, got a nasty oil leak just below the dizzy and theres white smoke on start up. Really curse word off and despondant now - not as if I haven't done a sodding head gasket before.
Apr 23, 2008 13:23:08 GMT
I've got a bare block and head in the back yard if you need any parts mate?
Apr 23, 2008 15:29:05 GMT
Nice to see you´re moving on and i´m sure you´ll sort out the leak! ;D Well thats a " NOT " as far as I can see Just been out to have a look ( after a characteristically bad day at work ) My diagnosis - the head gasket hasn't taken properly, got a nasty oil leak just below the dizzy and theres white smoke on start up. Really intoxicated off and despondant now - not as if I haven't done a sodding head gasket before. Really sorry to hear about your woes Probably not going to make you feel any better when I tell you that I've just done the same job on the Derby's 1.3 and so, far apart from a small drop in the water level (hopefully due to some escaped air bubbles) Everything 'touch wood' seems ok. Thing is; my mate recommended I get the head skimmed despite the fact that the gasket hadn't actually gone or the engine overheated, the ali heads just gradually twist slightly over time - So I got it skimmed & the engineer who did it, did indeed say that it was slightly warped - which backed up what I could visually see using a straight edge. Did you get yours done before re-building it?? Cars looking good BTW - non-GTi Mk2s are FTW BTW; whitbytom - have you got a link to your Readers-Rides thread on your Scirocco, the pic of it in your banner looks proper cool
May 20, 2008 19:52:34 GMT
Well now, no pics yet....but I think I've got it sussed, wipped the head off last weekend, then popped it over to Bob Harman Performance in Watford, Bob himself skimmed it and proclaimed it fit for further service...back on in less than an hour and all is well..... at last..
May 21, 2008 12:43:49 GMT
Result!!
May 21, 2008 16:50:50 GMT
great to hear you've got it sorted, whats next then??
May 21, 2008 18:11:30 GMT
great to hear you've got it sorted, whats next then?? It will resume work hack duties forthwith. Was going to t cut and wax it, but thats not really my style !
