roverv8rod
the little devil inside :)
Oct 24, 2007 21:38:23 GMT
still got the interiors of the two Rovers? let me know what you want for them, please, i need a few bits for my P5 beeing buildt... you can PM me, if you want? cheers, Chris
Oct 26, 2007 19:36:26 GMT
Still got full interiors for both.
Oct 26, 2007 21:01:53 GMT
MadMinor
Oct 27, 2007 12:15:35 GMT
Cliff, you're the mental bloke who is building that reshelled 200SX aren't you? That looks like muchos work. Fantastic idea. When you finish it I guarantee you could sell it to someone in Japan for a fortune...
Nov 15, 2007 10:23:54 GMT
Nov 15, 2007 11:30:38 GMT
;D
*n
Good work Widget, rip the interior out – everything – and get cutting. And banded steelies would rock the casbah. The ideal is the same width as the diameter!!
DutyFreeSaviour
Nov 16, 2007 10:34:19 GMT
;D ;D ;D ;D - ha ha ha ha ha
Can't wait for this to be showing up the local chavs....... fantastic project.
John
Nov 17, 2007 13:37:37 GMT
I'm keeping the interior intact Johnston. No point in having a stripped out sleeper. This has to look OAP spec, tartan rug and all.
WANTED: ROVER 200-216-220 donor car or suspension parts. Must be in NEWCASTLE area. Must have 4 wheel discs. Need rear axle, front struts, hubs, calipers etc.
Contact me if you can help please
Ok, who knows about Austin Princess or Embassadors? I hear they have 14" steels that look like Allegro rims. Can anyone tell me how to get 14" steels and caps that look like the OEM Allegro items? Maxi?
Maxis have 13's, the same as the allegros. The closest you can get in the BL range are the 14in ambasador rims, but you would have to adapt them to take hub caps as they have silly plastic caps as standard. Not sure whats available on the trummy 2000 range but i know they fit, as well as J stuff. Heres the ambasador rims on my dads car. The blue one has the alloys, the sandglow one has the steels, both 14's. These are about the limit on a maxi, simply because of arch space, but allegros have much bigger arches.
Nice info - cheers man. Nice Maxis too. My old man had a sandglow one. It got written off in a hit and run....
Feb 15, 2008 19:53:39 GMT
I could well be wrong here, but I got talking to a nice old chap at a local show last year and I, as some of the members who've posted here are, was under the impression that Allegros and Maxis both used 13" wheels. The old chap who owned the car told me this was not the case, and the Maxi has 14 inchers - he'd had to search to find a spare hubcap, I asked if an Allegro one would fit and he said no, it's an inch too small for a Maxi.
And the best bit is they look EXACTLY the same as Allegro rims.
Someone with a Maxi check, but I'm convinced that that is the case.
Sam Skelton
1977 Triumph Stag 1988 Citroen CX22 Croisette x2 1993 SAAB 9000CSE 2.3T 1993 Citroen XM CT SEi 1994 Citroen XM 2.1D 1996 Jaguar XJR 1997 Jaguar Sovereign 3.2LWB 1998 Range Rover Vogue SE 1999 Mercedes-Benz E430 Elegance 1999 Rover 820Si 2000 Citroen Xantia HDi110 Exclusive
Apr 21, 2008 14:57:13 GMT
Did we ever get to the bottom of the maxi steel wheel saga?
Any more Vento steel rims going for sale?
Apr 21, 2008 19:41:02 GMT
awsome awsome awsome....... just read thread from end to end..... cant wait to see this..... man this makes me chuckle from the inside out..
can just see mr spotty in his boombox sitting at lights next to plaid "mug in grandads car" onyl to see cloud of dust and the back end disappearing
Apr 21, 2008 20:14:21 GMT
awsome awsome awsome....... just read thread from end to end..... cant wait to see this..... man this makes me chuckle from the inside out.. me too.... as mad as the steering wheel your fitting! Bloody love it! ;D
Apr 21, 2008 20:20:06 GMT
I could well be wrong here, but I got talking to a nice old chap at a local show last year and I, as some of the members who've posted here are, was under the impression that Allegros and Maxis both used 13" wheels. The old chap who owned the car told me this was not the case, and the Maxi has 14 inchers - he'd had to search to find a spare hubcap, I asked if an Allegro one would fit and he said no, it's an inch too small for a Maxi. And the best bit is they look EXACTLY the same as Allegro rims.. That bloke is chatting rubbish. Both allegros and maxis came ALL with 13's across the entire range, princesses and ambasodors had 14's. Allegros had a very slighly less offset to the maxis but look identical. Hub caps were the very same too. See the above pic of my dads cars, as fitted with 14 inch ambasodor rims
Last Edit: Apr 21, 2008 20:38:10 GMT by bmcnut
Apr 21, 2008 22:54:19 GMT
Got one N.O.S quartic in blue (wall plaque for the spare room) and one brown lightly used quartic wheel which is now on the Retirement Rocket steering column.
Glad you're enjoying the project. Should be amusing.
Apr 27, 2008 21:01:55 GMT
That bloke is chatting rubbish. Both allegros and maxis came ALL with 13's across the entire range, princesses and ambasodors had 14's. Allegros had a very slighly less offset to the maxis but look identical. Hub caps were the very same too. Thanks for clarifying mate
Sam Skelton
Apr 29, 2008 14:44:13 GMT
Did we ever get to the bottom of the maxi steel wheel saga? Any more Vento steel rims going for sale? I have sent you a PM Really sorry about letting you down on the ones I had going Must admit the Vento wheels look very much like those on the beige Maxi above Project coming along nicely BTW - can't wait to see the finished article
