I had just opened the bonnet and one of them shouts out "those wheels are curse word!" whilst nudging his work college I kindly reply "that's is the idea mate" giggling to myself. His faced changed to a slightly confused look from the previous "I'm well happy with my last comment" look as I began to transfer the intercooler and turbo from the boot to under the bonnet to help size up for rad options. had to laugh along with you there.
@ CRX_IN_SCOTLAND
Cool! keep us posted with updates, I think this is going to be awesome when finished!
lregg
Did some more work on the old girl tonight, mainly concentrating on the conversion to injection from a carb set up. As can be seen it the video above I plugged up the bare minimum just to get it running, today I tidied a few things up. The supply wire for the main fuel pump needed to go through the boot floor so I got out the old dye grinder and got busy Next thing on the agenda was to cut out the bulkhead to pass the injection system loom through as I had just layed it all over the top of the bulkhead as seen here I had to mate the ecu loom to the non injection mk2 polo loom as well as passing wires through the bonnet release cable hole for the earth and feeds for the injection lift and main pumps. I have used all original vw wiring from an mk3 polo injection to try to keep things under the bonnet as factory looking as possible. Quite suprisingly there were some holes for the ecu carrier plate and some threaded holes for the ignition coil already on the car (totally different than a mk3 set up) More progress pics tomorrow
Last Edit: Jul 6, 2007 21:54:55 GMT by lregg
Soon to have more power to weight than a modern £30k+ "rally car for the road" at the ripe old age of 23!! Ladies and gentleman, i give you, the beige beast
lregg
Been playing again today, mostly been concentrtating on the exhaust side of things Herer's how the barry boy taiilpipe looks LOL It will not be staying like that, it was only fitted to mock up the turbo downpipe section As you can see the fit is quite snug Here's james thinking hard Things were taking shape nicely Getting there It's getting tagged up ready for welding tomorrow
lregg
a little update, more to come later today if I get time Engine space is so tight that I have had to relocate the oil filter!! Not normally something you have to do a 4 cylinder engine in a car that uses a 4cylinder engine as stock. The reason being is the equal length exhaust manifold ran way too close to the oil filter for my liking As you can see above the take off plate, the centre two branches of the manifold swoop down close to where an oil filter would be so the oil filter has been relocated with a remote filter housing..... to the front of the drivers side inner wheel arch which fits in behind the plastic wheel arch trim nicely. directly underneath the filter housing is the thermostatic take off plate for the oil cooler.......... which will be fitted underneath the front bumper, not exactly stealth but it'll get lots of airflow and to be honest, it's about the only place I can fit it without getting in the way of the intercooler or radiator The added bonus of all this is that i'll have increased the oil capacity of the engine (not by masses but every little helps) what with the bigger golf oil filter and all the pipework etc etc. The oil cooler could not really be in a better position for cool air but obviousl6y I run the risk of a stone going through it which i'm willing to risk
Last Edit: Jul 14, 2007 7:52:56 GMT by lregg
VWDan
VW Jetta MK1, VW Caravelle 1.9TD, Audi A6 Tdi Avant
Jul 14, 2007 16:27:33 GMT
If only everything in life was as cool as a retro VW racer.
Jul 14, 2007 17:27:55 GMT
I just read this whole thread - some work gone in there! Good stuff, any pics of slotmags rocking the Polo's world???
Jul 14, 2007 23:19:38 GMT
1981 Prelude 1969 Bus 2001 A2 1993 911T
Jul 15, 2007 18:15:09 GMT
Re: your oil filter, do you know that Mk3 PizzlE items are much shorter than Mk2 ones? Mine runs one for that reason
Jul 15, 2007 18:24:35 GMT
Your car is super sweet btw, this is mine: Just NA unfortunately, but still quick
Jul 15, 2007 18:29:35 GMT
i thought that ^^^^ was sold ?
or am i thinking about something else
SPLIT RIMS ARE FOR WINNERS
Jul 15, 2007 18:45:53 GMT
No, it was for sale but after enduring all the standard "will you take 54p for it mate?"s I decided to keep it It's currently enduring daily hackery and has just done 2 trips to France and back.
lregg
Jul 15, 2007 21:17:41 GMT
I'm thinking about losing the front bumper like this mk2 has A) because it looks good IMHO B) it'll get rid of some weight and C) it'll help aid the efficiency of the rad and intercooler I purchased a hole cutter from B+Q which went blunt straight away which was rather annoying. You can see where i started to cut on the far right directly below the red quattro badge that james put on for a giggle I will replicate a big rectangular hole to the left of the original three and add small additional holes inbetween them, i'll also add 63mm holes slightly below but inbetween the rectangular holes along the black line you can see in the above pic You can just about make out the white chalk line that outlines the position of the front bumper so with it on you will not see any of the holes at all
Jul 15, 2007 21:34:20 GMT
carbon bumper ftw i'd make one but it'd cost a lot of money
lregg
Jul 15, 2007 21:52:50 GMT
Got to sort out a little heat shield as well!!
Jul 16, 2007 15:23:12 GMT
Lovin this project a lot, manifold and down pipe look sweet do to see it all fitted in okay.
Keep us updated!
lregg
Jul 16, 2007 20:34:16 GMT
Cheers robin.
I have decided to leave the front bumper on as it will go against the whole sleeper idea and it only weighs 6 kilos anyway
Jul 17, 2007 18:13:25 GMT
what management are you gonna run mate what turbo is that
would like to help on this project
kind regards jamie
lregg
Jul 17, 2007 19:59:04 GMT
what management are you gonna run mate what turbo is that would like to help on this project kind regards jamie I'll be using G40 management with a turbo chip to suit The turbo is a garrett T25 from a saab 9000 thanks for the kind offer jamie
Last Edit: Jul 17, 2007 20:00:02 GMT by lregg
lregg
Jul 17, 2007 20:15:47 GMT
I played a little more tonight but not that much I marked out the holes and then cut them I borrowed some hole cutters from a mate and they weree useless as well so I ended up having to drill round the inner edge of each hole before die grinding up to the outer line, proper pain in the aris Should get loads more air to the rad and intercooler now, even with the bumper on
Last Edit: Jul 17, 2007 20:17:21 GMT by lregg
