the method ive gone for:
1.8 zetec flywheel (lighter) 1.8 zetec pressure plate sierra clutch plate and release bearing (unsure as to which sierra, the one with the same size clutch plate as a 1.8 zetec) RS2000 bellhousing and release arm, although you can use the standard bellhousing, its just heavier and bigger. CVH sierra starter motor
there are a million different combinations though really, probably the best way is to get a retro ford zetec flywheel that is redrilled to accept a pinto clutch (£40 exchange) due to the zetec clutch being quite heavy on the foot.
diff
When i've turned zetecs rear wheel drive i use early cable mondeo clutches and never found them heavey under foot and its same spline as type 9 so is a direct fit.
engines got to come back out again not to worry, will get the hoist tonight and have it out tomorow. i need to either file a bit off the thermostat housing or bend the bulkhead back (will probably do both) i thought i could do it in situ, but managed to take some paint off, so ill whip it out and do it properly. i got all the radiator hose sorted and the wiring in, which has all got to be taken out again ;D ;D inlet manifold got given to my pal to be tig welded, so should get that back soonish.
Sept 5, 2007 10:30:29 GMT
anyway.......... oh hai, just modding ur bulkheadz, hope you don't mind ooooooops! cutting into the fresh paint made me wince enough room now! i think i can live with that tbh
Sept 5, 2007 10:37:58 GMT
oh, its been finsihed a bit better than that last pic. anyway, the other thing ive been working on remember these? got them welded now they are starting to look like an inlet manifold......... bit too long though port spacing is cock on, the shape of them is a bit, erm. shouldnt be too much of a problem once ive give them a little porting if you squin it looks finished! just have to weld it to the flange and pu some injector bosses in there too. oh, bought myself an engine hoist last night (don't have to rely on pals ones) - managed to get my girlfriend helping a hand too
Davenger
It's only metal
Club RR Member Number: 140
The Silver EscortDavenger
@dminifreak
Club Retro Rides Member 140
Sept 5, 2007 10:39:33 GMT
Looks good to me
Sept 5, 2007 12:47:56 GMT
just been out there, i didnt
Sept 5, 2007 12:49:08 GMT
just been out there, i didnt quite get the right area in regards to the bulkhead mod. however it got most of it, i think i just need to take a grinder to the one leading edge.
now the engine is back in i know i need a 45 degree angle on the TB's
Davenger
It's only metal
@dminifreak
Sept 5, 2007 14:10:30 GMT
Maybe a little fettling with a knocking stick would sort it?
Sept 5, 2007 14:51:43 GMT
tried that, hence the hole in the first pic ;D ;D
Davenger
It's only metal
@dminifreak
Sept 5, 2007 14:53:59 GMT
Oh, right ;D
Sept 5, 2007 17:18:03 GMT
ive sorted it now - bulkhead is clear, inlet manifold is built..........I'm happy again pics when i get back to the flat
Sept 5, 2007 19:30:35 GMT
anyway, the offending item of the day........... met mr grinder they danced the fandango, and now there isnt a problem of clearance i can fit whole finger between them ;D ;D ;D
Sept 5, 2007 19:37:58 GMT
now, the boring stuff out the way, i can get onto these babies i mitre'd them (badly, with only an angle grinder) then after a bit of fine adjustment after some trial fitting, i decided i wanted them the other way around upside down the offending item
Sept 5, 2007 20:04:53 GMT
Oh hells yes....
Davenger
It's only metal
@dminifreak
Sept 5, 2007 21:32:21 GMT
Looking good buddy. Quality grinder action ;D
Last Edit: Sept 5, 2007 21:34:45 GMT by Davenger
street
6.2 ft/lbs of talk
Sept 6, 2007 10:49:52 GMT
Superb progress! Looking forward to the next installment!
thats excelent, I'm planning on putting a zetec in my cortina i just wondered what the wiring is like as thats the thing whats worrying me
Sept 7, 2007 10:36:08 GMT
Could you give a few more details on your manifold design and the calculations you used etc, or was it a bit of guesswork?
Adam
Sept 7, 2007 16:01:10 GMT
with the engine awaiting an inlet manifold to be finished off before carrying on, i got the suspension on the one side on - it involved the use of a 12 foot long leverage bar (didnt have to use spring clamps this way!) then, today, i went the fabric shop and bought some italian closed weave hessian - apparently the nicest stuff around - £6 a metre the rover seat taken apart one of the 2 bits needed a ROUGH idea of what it will look like - i only placed the fabric on the foam, it will be properly stitched and shaped into exactly the same as the original, even with the recaro badge should have the seat done on sunday - will carry on with the car tomoro
