bstardchild
Club RR Member Number: 71
Update in italics
- Fit last Dellorto Throttle lever (when it arrives from Italy via UPS) - Arrived
- Fit 3 x equal length rods for upper lever on pivot bar that are in post from birmingham - the kit I bought caters nicely for twin carbs 2 of most rods and 4 of one of them - sods law the one with four I need Six!) - On route
- Drill and tap the pivot bar for the three lever pivots - in progress
- Drill and tap the pivot bar for the throttle linkage pick up - in progress
- Drill the pivot bar for retainer R Clips - in progress
- Shorten it to the correct length - in progress
- Fit and locate 3 x additional return springs (also with Dellorto lever from Italy) - Arrived - Find 2.6 Carlton throttle cable - Original one is too short (on the case but NLS so the throw cash at it option and buy a new one ain't the easy fix) - Fly in ointment
- Make bracket to hold cable to rocker cover (that will be "heath robinson" to start with till I find an asthetic solution)
- Make gaskets for manifold to head x 4 (Got gasket paper and scalpel) - Gaskets made
So still some things to do but at least progress is being made
bstardchild
Update in italics- Fit last Dellorto Throttle lever (when it arrives from Italy via UPS) - Fitted- Fit 3 x equal length rods for upper lever on pivot bar that are in post from birmingham - the kit I bought caters nicely for twin carbs 2 of most rods and 4 of one of them - sods law the one with four I need Six!) - Fitted- Drill and tap the pivot bar for the three lever pivots - Done- Drill and tap the pivot bar for the throttle linkage pick up - Done but I've made an error - ooops- Drill the pivot bar for retainer R Clips - Done- Shorten it to the correct length - Done- Fit and locate 3 x additional return springs (also with Dellorto lever from Italy) - Arrived two sizes and neither are any good - time for a re-think!!!- Make gaskets for manifold to head x 4 (Got gasket paper and scalpel) - DoneIt looks like this at the moment set up on the spare head So Still to do - Correct my measure once cut twice error - Find 2.6 Carlton throttle cable - Original one is too short (on the case but NLS so the throw cash at it option and buy a new one ain't the easy fix) - Fly in ointment- Make bracket to hold cable to rocker cover (that will be "heath robinson" to start with till I find an asthetic solution) So no carbs for Sunday but hey ho won't be long ;D
bigrod
Ian,
That is quite incredible to say the least!! Fine bit of engineering!! If I had a hat on it'd be doffed in your general direction!
Is it all gonna fit under the bonnet though? ;D
If I have to explain, you won't understand. Maximum signature image height = 80 pixels
bstardchild
Is it all gonna fit under the bonnet though? ;D If it doesn't I can cut a hole ;D In fact I might cut a hole anyway It should be fine as you will know that the inlet manifold goes over the rocker cover on a 24V and that fits fine in a Monza
djmatt
Jun 11, 2008 11:27:59 GMT
That is just sexy. You are going to take a video of it and youtube it aren't you.....? That's the only way to actually hear the thing from Australia!
rysz
Jun 11, 2008 12:04:16 GMT
What springs are you looking for? There is a place in Nottingham that has a reasonable stock on the shelf of compression / tension / torsion that are normally available for pennies and you can bend the ends if torsion with pliers...
Company is Kato - Entex: (0)115 9293931 and speak to Jeff Poole (Sales) or Dave (Technical) and they should be able to sort you out.
Rysz.
bstardchild
Well in between showers it now looks like this I think I need to move some stuff - the loom needs tidying too And when it's not raining it's a nice day to work on cars
bstardchild
Jun 22, 2008 22:36:19 GMT
Now manifold fitted Loads of clearance Roddy ;D Had to take the carbs off again to shorten the levers Things to move ABS modulator unit - needs to go down 2 cm - currently unbolted I'll stick some new holes in tommorrow Brake splitter - Needs to be moved out (done it with a large hammer) Get the carbs on and I can sort out the throttle cable
bstardchild
Jun 23, 2008 21:33:23 GMT
Well this evening the bay looks like this ;D Actualy it looks a bit better than that cos the fuel pressure regulators are in and piped up to the carbs Bad news is what I feared might happen - the Motronic ECU has detected something ain't quite as it should be and shut down the fuel pump - so for the rest of the night I will be mainly looking at wiring diagrams and trying to see exactly what I need to frig/hotwire to make it thing stuff that isn't there still is That washer bottle has got to be moved or I've got to block up the level sensor that isn't used anyway to make some space for the filters on that carb
curse word I've missed loads! Triple carb FTW, great work Ian. Hope you get the ECU problem sorted.
bstardchild
curse word I've missed loads! Triple carb FTW, great work Ian. Hope you get the ECU problem sorted. I'll get it sorted but I might have to wait for my "wiring diagram expert" to return from Italy where he's working this week I'd like to hope I can sort it myself but if I can't he'll spend 30 secs looking at the diagrams and go put a wire from X to Y and it'll work - and it will too (smart chap he is)
DutyFreeSaviour
Just read this lot of updates - HEAD. DONE. IN !!!! - Skillzorz BC, beautiful looking bit of kit
Seth
Jun 24, 2008 11:16:54 GMT
Looking great BC! Can't wait to hear it ;D
bstardchild
Jun 24, 2008 12:05:46 GMT
Looking great BC! Can't wait to hear it ;D LOL - I can't either ;D Had some discussion elsewhere and the concensous of opinion is the std ECU might have some problems with lack of throttle position switch, Airflow meter and injectors in circuit - meh - where there is a will there is a way (Will in this case being someone I know who is quite good at re-writing ECU code)
bigrod
Jun 24, 2008 14:28:22 GMT
Gaujus Ian!!!
Couldn't you just hardwire the fuel pump and unplug the ECU?
I realise this would cause issues with ignition advance/retard but surely a man of your talents should be able to frig something together using Royale dizzy, a couple of toilet roll tubes and a pair of Val's old knickers!
J.P
I like to eat ice cream and I really enjoy a nice pair of slacks.
Jun 24, 2008 15:04:44 GMT
Mmmmmm those look great
*ignores all the problems*
Those will sound GREAT!
street
6.2 ft/lbs of talk
Jun 24, 2008 15:53:53 GMT
Nothing looks finer than a brace of sidedraughts! It really is going to sound amazing, good luck with the setting up
Jun 24, 2008 18:20:29 GMT
This pic needs adding to the OOOOF thread. Gonna sound orgasmic. Matt
bstardchild
Jun 24, 2008 18:23:41 GMT
Nothing looks finer than a brace of sidedraughts! It really is going to sound amazing, good luck with the setting up Isn't a brace a pair Or can't I count ;D It won't sound anything unless i can get it running - might squirt a bit of petrol into the float chambers just to fire it up and spur me on a bit ;D
bstardchild
Jun 24, 2008 18:28:07 GMT
Gaujus Ian!!! Couldn't you just hardwire the fuel pump and unplug the ECU? If I do that I'd be cheating and I'm not to keen on losing the "have an accident engine stops so fuel pump does too" control circuit I realise this would cause issues with ignition advance/retard but surely a man of your talents should be able to frig something together using Royale dizzy, a couple of toilet roll tubes and a pair of Val's old knickers! And lose the knock sensor control and ign maps that have been well fettled over time - not keen to be honest Chopping off the original dizzy head and welding on an early Monza one with advance and retard weights was considered as much of a backwards move as putting carbs on a car which has fuel injection as std Nah I'll work it out - bit more head scratching and studying "tube maps" required
