Arfur
...There's as much ice on the inside of the windscreen as the outside. Jeez, how cold is it this morning? My hands can't feel to grip, as Bob Dylan might have once said.
Elequantly put ahhhh I have fond memories of driving my camper with my elbows so I could keep my hands warm on the window heaters
Dec 20, 2004 10:30:45 GMT
I remember driving my first imp by looking out the bottom of the windscreen as that was the only part the heater cleared.
BS Nymph Singer Chamois Coupe Series 3 Landy
Dec 20, 2004 11:09:29 GMT
Jeez, how cold is it this morning? Don't know as got a days holiday & haven't ventured outside yet ;D ;D Was cold walking back from bowling last night though at half 11
Dec 20, 2004 11:12:20 GMT
My Cavalier is still iced over. On lates this week so hopefully it will de ice is self by half 1.
Rob
You know, for kids!
Dec 20, 2004 11:13:44 GMT
yeah... scrpaing ice into your lap from the windscreen... joy of joys ! ;D (now my rear demister switch makes an un-nerving burning smell after about 2minutes... hmmm.... i don't want to be THAT warm ! )
Dec 20, 2004 11:24:04 GMT
Pah! The heater in the Beemer is 100 times better than the one in our (much newer) Astra. Show me a Vauxhall with a decent heater and I'll give you a tenner....(claimant collects!). That said, the Beemer did chuck a paddy after I'd had it up in the air to put the new rims on last night. Coughed and spluttered in an unpleasant way...Not sure what was going on....normal service appears to have now been resumed!
Dec 20, 2004 11:27:07 GMT
Maybe it dosent like its new rims
Dec 20, 2004 11:41:58 GMT
Maybe it dosent like its new rims Maybe... but it's tough, they're staying on now! ;D I just reckon it the "curse"....whenever I fiddle with cars stuff always starts going wrong....maybe I should just leave them the hell alone!
Dec 20, 2004 12:33:39 GMT
I know what you mean by Vauxhall heaters. My Cavaliers is so bad I bike to work.
richy
Flatheads forever....
Dec 20, 2004 16:40:54 GMT
and on the infamous Toptaff HA van, you can't turn the thing off!!!!
Davenger
It's only metal
Club RR Member Number: 140
Dec 20, 2004 17:02:57 GMT
Hello, mini owner here!!!!!!!!!!!!
Heater? whats one of those, all we got is an ugly black box that mekes a blowy noise and makes you colder
Dec 20, 2004 17:42:26 GMT
Maybe you should put the roof on the convertable next time ;D
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Dec 20, 2004 18:26:59 GMT
I know I,ve posted it before but it's a cool winter pic and fits the thread. And yes it was as cold inside the Landy as outside!!
This space available to rent. Reach literally dozens of people. Cheap rates!
Dec 20, 2004 18:35:14 GMT
dunno what yer on about i rode me motorbike to work today.......
not that cold
2001 HONDA CT110 (NOT RCV)
Dec 20, 2004 19:16:02 GMT
Well I walk to work, you're all soft southerners. Even the ones from north of here! On the subject of Mini heaters. The standard heater from about MkIII onwards does a damned good job. However I find that there are lots of other things, usually due to poor maintainence that cause you to get cold tootsies. 1. Clogged up matrix, flush your cooling system completely when you change the coolant. 2. Stuck heater tap. Make sure the heater tap opens and closes when you move the conytol knob, if not make sure the tap and cable are cleaned and lubed. If the tap itself is stuck replace it, it doesn't cost much. 3. Stuck thermostat. Sometimes this can be masked by the temperature gauge reading warm because the wrong temp sender is fitter or the voltage stabilizer on the gauges is shot. 4. Low coolant level, so there's no water in the heater matrix. I had a friend who whinged about his mini's heater blowing cold for months. When he finally let me look at it the cable had snapped so the tap was staying closed all the time.
Dec 20, 2004 20:18:35 GMT
my "modern,spacious and comfortable"vw 411(none of the above) should have an eberspacer petrol heater in it,but its been removed.so I'm using my w123.you can fry eggs on the dash after about 10 mins.
Dec 20, 2004 20:30:47 GMT
i drive to work with the windows open so i don't get warmed up, i'm a builder working on roofs ATM so i don't want to get spoiled.
(never got above 3 degrees today)
Dec 20, 2004 20:45:55 GMT
u want to try working in water all day when it splash up and freeze on u and the beastly benz runs on lpg only so 80 temperture gage before u can put the heater on and i only work 1 min and six seconds away
Dec 20, 2004 23:12:47 GMT
It was pretty cold up here as well, (if you don't like the cold, don't live on a Scottish coastline!) bloody River Clyde, the wind coming off it hurts your face a lot, and I agree that it's worse when you're cold AND wet! The bloody Imp froze solid last night, so it took about half a tin of de-icer just to get in the car and be able to see enough to drive away, then there's the hilarity of a cold Imp engine! That's it, I'm getting electronic ignition!
"He's not the messiah, he's a very naughty boy!"
