Aug 19, 2024 22:08:21 GMT
Spent most of Sunday starting to pull the old shed apart. This is where we ended up: It was used by the previous owners as an illegal weed grow, so was heavily insulated! Even found some evidence though no stashes of drug money so far... Eventually got it stripped down to a shell inside. Now, the original plan was to dismantle this into its component materials and then re-use them to build a garden shed/firewood-processing area on the opposite side of the garden. However, it's proving to be rather well constructed. Nailgun used at any given opportunity (meaning lots of nails to pry apart, and comparatively few screws), and good quality nails (meaning it doesn't like to be pried apart) are making it a rather slow job and has prompted a re-think. The shed is a bit too big to re-use as-is, but if I lop 5ft off the end of it and drag it over to the opposite side of the garden it would save a lot of work dismantling the thing, and wouldn't be a terrible fit for the space we have. I expect it would survive the journey as the walls are linked together with floor joists rather than just being rested on the concrete slab beneath it. Anyone have any experience of moving sheds whole? The final size of it will be about 3m x 4m (10ft x13ft).
BiTurbo228's garage buildglenanderson
@glenanderson
Club Retro Rides Member 64
Get some lengths of soil pipe, jack the structure up and use the pipe as rollers.
Ah soil pipe is a good idea! We thought about fence posts, but finding 3m ones cheaply locally is proving to be a bit tricky.
@glenanderson
Aug 20, 2024 11:07:00 GMT
The best things about soil pipe are it’s not dear, it’s pretty damn tough, and it’s the kind of thing that you can always find some use for afterwards.
Aug 20, 2024 15:09:58 GMT
Its handy for storing lengths of steel offcuts in the workshop.
Aug 25, 2024 21:13:27 GMT
Last Edit: Aug 25, 2024 21:16:45 GMT by biturbo228
Aug 26, 2024 20:58:37 GMT
Yeah absolutely! Some of the ends got a bit chewed up, but there's a good 50 or so 2.4m 4x2s, and the same again of usable batten. At least a dozen 6x2s from the roof. All the sheeting that came off (which again is a little worse for wear, but can be used in out of the way places where that doesn't matter). Even managed to get one or two lengths of feather edge off without breaking it, which must be some kind of record There's more to come out of the floor as well! I'm currently weighing up whether to save this lot for things like shelving, or make a saving on the structural timber. It'd be nice to save some money, but thanks to the bulk order I'll likely never be buying 4x2 as as cut-price a rate again, so if I can stretch to it I could make a longer-term saving. I suppose that choice will depend on how bruised the wallet is feeling!
Sept 2, 2024 13:07:53 GMT
Well, 5kg of nails later and it's all been dismantled and the useful timber salvaged. 50 lengths of 2.25m 4x2 (which I'll probably use for constructing shelving and workbenches), 20 lengths of 3m 4x2 which will do for the walls, and 16 lengths of 3m 7x2 which will do for a number of the raised ties. About £300 of timber in all, plus all the boarding I may or may not use. Useful! As you can see the slab is a little worse for wear. Some big finger-width cracks running down it, and even a hole you can see the sub-base through... Current thinking is to break this all up and sort out the hardcore underneath it as there look to be decent sized voids in it. Shouldn't be too difficult as the slab's only 4" thick and doesn't seem to be reinforced. Not really what you want right at the base of a tree!
Sept 7, 2024 22:30:53 GMT
Started breaking up the old concrete slab: I've come across tougher crisp packets. While some areas are 4" thick, most of it varies from that down to about 2" (and not a reinforcement in sight): Not that I'm complaining of course! I'd borrowed my dad's kango hammer in anticipation of breaking this up, but in the end I just massaged it a little all over with the sledgehammer and pried it up with a crowbar and it fell to pieces. Took no time to get to this point: ...and not a great deal longer to get it all clear as well. The hardcore underneath is similarly dodgy, being mainly ex-breezeblocks and full of voids and soil. I gave it a bit of compacting with the sledgehammer and checked the level afterwards. Don't have a laser-level yet, so got a bit creative with two poles, a length of batten and a level app on my phone: Turns out it's 2" lower than it needs to be over most of the area, which gives a bit of space for some better quality hardcore. So long as it's at least as tough as plain dirt I should be ok. The extra space for hardcore is useful though as I had a load in the pickup and the soon-to-be-hardstanding area was looking pretty full! I can sense a time when I can do something other than groundwork. It's not here just yet, but it's exciting that it's coming!
Last Edit: Sept 7, 2024 22:33:46 GMT by biturbo228
75swb
Beta Tester
Club RR Member Number: 181
BiTurbo228's garage build75swb
@75swb
Club Retro Rides Member 181
Sept 22, 2024 2:50:45 GMT
Just caught up for the first time in a while and that's huge progress. I have a very similar view as to recycling and saving cash being the way to go.
Sept 29, 2024 8:01:02 GMT
Thanks man! Lots of work, but progress hasn't been too bad. And yeah, if I didn't get all of this recycled stuff I wouldn't be able to afford it! Crazy how much material goes into groundwork.
Not much to update, other than groundwork continuing and not looking a great deal different to before! However, I have made a rather dangerous realisation. Initially, the garage plan has been this: Big long set of benches along the back. Division between dirty garage on the left and clean garage on the right. Loads of room around even the biggest car I own/ever plan to own on the right (Jag XJ40), and the main project at the moment on the left (Spitfire). The dangerous realisation is that if I get 2 sets of wheel dollies and lose the bench at the back I can just about fit my X1/9 in the lefthand garage as well... I've worked in cramped garages my whole life so far, and while it's doable I was rather looking forward to working somewhere I don't need to shimmy around the whole time. Having them at an angle means I can still get to both sides with plenty of space, and around the front and rear, but with around a foot (give or take) to shimmy between them. I suppose planning on having tight space right from the get go isn't really a recipe for longer term workability, but it's mightily tempting to get two cars inside instead of just one...
Now I'm actually back at home to measure things, I actually have an extra 1m I can push the back of the LH garage back by. If I narrow the internal width from 3.8m to 3.4m (which is still fine for the little cars I work on), things get a lot more flexible. I think this might be the favourite. I'll still have more workbench space than I've ever had, especially if I keep the floating workbench idea, and it means I can get two of my little sportscar projects in out of the weather and still have space to work around them (even more if I get some wheel dollies to angle them).
It is *such* a nice feeling to get your own undercover working/storage space when you've been used to working outside for so long! Trouble is it's never quite big enough...
Sometimes, others may not understand why you like a car so much. Sometimes, you may not even understand why you like a car so much. But none of that matters; all that matters is that you like the car, and having it makes you happy.
It is *such* a nice feeling to get your own undercover working/storage space when you've been used to working outside for so long! Trouble is it's never quite big enough... Tell me about it! Definitely looking forward to not rolling around in puddles. Arranging car work around a kiddo and guests in our airbnb outbuilding is tricky enough without having to mix in the weather as well. I am pretty well practiced at completely ramming them with junk to the point I can't really do much work in them though hoping to maintain a little more discipline this time (and build in a few things that'll make it easier to maintain, which we'll get to later).
Oct 14, 2024 18:45:04 GMT
Well, I've sorted one garage base ready for shuttering... ...and got halfway through the second, but I've managed to do my back in again! Off to get beaten up by an osteopath and onto light duties for a while to let it recover. Hopefully won't be too long until I can gingerly shuttle things backwards and forwards and at least keep the momentum going.
@glenanderson
Oct 14, 2024 19:58:44 GMT
Liked for progress and support, not the backache. 👍
