mylittletony
Club RR Member Number: 84
1978 Fisher Fury - whoosh!mylittletony
@mylittletony
Club Retro Rides Member 84
Sept 29, 2024 8:32:03 GMT
Seeing as it's rained almost constantly for the past week, I decided to crack on with extending the bottom flange (snigger) First step was to sand back the edges, which I just about managed with a very cheap new mini grinder. Then mask off the car Then a couple of layers of parcel tape, ready for resin Then 1 layer of glass, followed by a second more localised layer, around the edges and across the back Not my finest work as I discovered once I'd started that my roller was seized... I'm going to try and use it this week as the forecast is dry, then probably get stuck into building the form
mylittletony
@mylittletony
Oct 29, 2024 10:06:14 GMT
Mini-update, mainly as it's been a month since my last post!! The adjusted wastegate actuator was still allowing nearly 12psi, which according to the chap doing the tuning is fine for a std MX5 engine, but not for the injectors I have fitted. Here's me testing the actuator as scientifically as I could think of Not really wanting to cough up on a set of bigger injectors and also because it's pretty f-ing fast as is, I plumped for an adjustable actuator to bring the boost down to within the fuel system capacity. I also discovered the position of the actuator can was causing the movement of the arm to be obstructed. The new actuator is a cheap one, similar to a mambatek, supplied with springs of different ratings. I've fitted the 0.3 bar spring to see where we get to. I took the opportunity to lower the actuator body, away from the bonnet, and made a cranked actuator arm to make sure the motion is smooth. The result of this, after a few data log drives, is that I'm seeing 4psi at ~5k rpm, but it's rising fast. Next step is full throttle up to 7k - that's proving hard with how wet it has been and how damp the roads are!! Once that's all bottomed out, I'd like to increase the boost until I get around 8psi. Other fantastic news to report is that it starts brilliantly from cold and is driveable immediately - the initial goal from this whole malarkey!!
Interesting work on the hardtop. I never realised such a thing was available for these but always liked the idea of these sort of cars made into a sleek coupe. That original top is anything but sleek so I wish you luck transforming it.
mylittletony
@mylittletony
Thanks! The hardtop has taken a back seat, I've been out round the block a couple of times to get this tune sorted so the bits haven't been on the car for a while. As the weather gets darker and wetter I'm sure I'll get into it again. There's another reason which I'll get to in a minute! As for the tune, I got up to 7k revs, but the boost was climbing and climbing so something wasn't right. I checked the wastegate actuator and it opens under a whiff of pressure from the bike pump, so that's working. I started to wonder about an exhaust restriction and then the tuner mentioned bad wastegate port shaping, especially with the Chinese stuff. This would definitely describe my symptoms, the wastegate can't actually dump exhaust gases, so the turbo keeps boosting. I checked my old turbo Big flap, small hole, doesn't look very promising, hmmm. Then in a flurry of activity, I removed the turbo and split the turbine housing off. Same deal And from the other side So the plan is to open the hole up a bit and blend the entrance side to ease the flow for the exhaust. Hoping I can have it back together fairly quickly! The other reason I've been distracted, and not bought materials for the hardtop, is I've bought another car and marginally overspent! It needs some weld repairs and a few other bits buying, although I'm hoping I can enjoy as is over the winter I'll start a thread soon, but ultimately, this may get sold to fund a build...
mylittletony
@mylittletony
Time for some 'after' photos. The housing was attacked with the following implements, all found in my messy garage: 18mm drill bit, cheap burr tools, round hand file. I have smoothed the edges since taking the pics. I'm calling that a success, going from 15 to 20mm diameter virtually doubles the area and the blending is significant, even if you can't see it in the photos. EDIT, check out my editing skillz, a little side-by-side I've put the turbo back together, after a thorough blow out, but not refitted to the car yet. Can confirm I do have black bogies after all the grinding.
