mylittletony
Club RR Member Number: 84
1978 Fisher Fury - whoosh!mylittletony
@mylittletony
Club Retro Rides Member 84
Feb 11, 2024 15:46:04 GMT
This weekend I had a proper clear out of the garage, got rid of a car full of stuff to the tip and found things homes on the shelves. I also did a roof chop Mark up: Choppy choppy: Very crudely reattach I then set about bracing it a bit as I'm going to have to remove more of it before I can start to craft the new one. But I think it's a huge improvement already, the roofline is WAY better Then I took some more pics with the targa panels laid in place. I'm in a bit of a quandary where to take it tbh. I'm actually quite happy with the shape of it, if it was finished. The proportions are good, the height is exactly what I was aiming for. I could try and cut and shut the roof and fill the gaps, but I think the curvature would be off in a lot of places. The next option is to basically cut it away from the deck upwards and B pillars backwards and redo the whole thing. The latter was what I was expecting to do, so I should probably just get on with that...
jimi
Feb 11, 2024 17:00:25 GMT
Looks much better How about cut-n-shut the bottom rear section and lose the quarter windows ? very rough photoshop
Last Edit: Feb 11, 2024 17:01:22 GMT by jimi
mylittletony
@mylittletony
Feb 11, 2024 18:38:26 GMT
Looks much better How about cut-n-shut the bottom rear section and lose the quarter windows ? very rough photoshop Thanks Jimi That looks good, you can see why I'm tempted to try and make what I have work... There's a couple of issues, the top of the old screen opening is contacting the roll bar. I'm tempted to cut that out and tilt it back to mate the lower screen opening, but the widths are different because of the chop. Plus the rear deck isn't actually flat in either direction and everything is curved in plan view too... I'd like to keep the roof openings, but they start to curve down a fair bit at the rear. Si I'm basically into redoing anyway. My current plan is to cut the roof section just behind where I've attached the brace, and the sides from the B pillars. Then form a buck from thin ply strips & ply board ribs and then glass over that. I think it has a baby corvette vibe to it, so an interpretation of of the C3 corvette shooting brake is my intention. Like these, but a bit... less
Feb 11, 2024 18:47:40 GMT
YES!!! I have a thing for breadvan racers, so yeah, I really like those plans...
Darkspeed
Club RR Member Number: 39
1978 Fisher Fury - whoosh!Darkspeed
@darkspeed
Club Retro Rides Member 39
Feb 11, 2024 19:19:12 GMT
Or Which I always fancied a form of on the G27 rather than the G4 bubble type ETA Ahem - cough cough - them's not Wolfies.....
Last Edit: Feb 11, 2024 19:22:32 GMT by Darkspeed
mylittletony
@mylittletony
Feb 11, 2024 21:02:39 GMT
Or Which I always fancied a form of on the G27 rather than the G4 bubble type ETA Ahem - cough cough - them's not Wolfies..... Yeah that's another great influence, if I can get anywhere near that I'll be winning!! Err yeah, the new wheels have snuck in! They're definitely style over substance, a lot heavier than the slots! Pretty happy with how the look is coming together though
mylittletony
@mylittletony
Feb 12, 2024 18:40:45 GMT
The other thing I started over the weekend and finished this evening is replacing the rear lights. Slightly complicated by having to create a way of earthing the housing, but otherwise just joining wires and attaching to the body. Here's a before: And an after: As you can probably tell I took that halfway through, but I have done both sides. The reverse light is getting binned off for a small LED with chrome ring, this needed a little adaptor crafting. The fog I'm going to swap out for a light I've had for a while, bit of silly fun
mylittletony
@mylittletony
Feb 13, 2024 18:32:40 GMT
Riding the wave of progress I thought I'd have a crack at the remaining lights. This is the LED I got for the reverse And a 3d printed surround I drew up to cover the hole from the old wipac light This is now together, tested and inserted into the hole with some sealant to hold it in. The fog light is also in situ, after moving the cable pass through, making a gasket, fitting longer bolts and drilling some fresh holes in the body. I think it was originally intended for a chopper, it's just for a bit of a laugh tbh And all lit up! (The tape is holding the reverse light in) I'd like to find some smaller reflectors too at some point...
mylittletony
@mylittletony
Feb 22, 2024 21:09:24 GMT
Managed to get a little more done on the tonneau. Longer rivets arrived so I could attach the poppers to the rear deck. There were 2 fitted to the tonneau when I bought it, so I've used those. Then something I've kinda ignored became an unavoidable issue... how to fit it around the roll bar. Nothing for it but to grow a pair and cut into it Here's the aftermath! I think it'll be ok, not going to win any awards, but it should do I'm going to rejoin the splits with some webbing and more poppers. I also need to decide how to fasten it along the sides yet not interfere with the hard top, I'm considering magnets but still mulling.
Darkspeed
@darkspeed
Feb 22, 2024 21:28:03 GMT
Usually do the splits / joins with extra material and velcro. Do you know anyone with an industrial sewing machine?
mylittletony
@mylittletony
Feb 22, 2024 21:53:05 GMT
Usually do the splits / joins with extra material and velcro. Do you know anyone with an industrial sewing machine? No, sadly not. That does sound like a better way! I don't have any extra material either, although it's fairly basic vinyl... I've also earmarked a piece of ply to brace the B pillars of the roof to enable further trimming and bought some more appropriate jigsaw blades.
mylittletony
@mylittletony
Feb 24, 2024 14:39:12 GMT
This weekend's progress was curve balled by having to replace the driver's door Bowden cable on my daily Audi A2. What a fiddly job... Taking off the door card was the easy bit Even removing the aluminium inner door skin thing wasn't that hard compared to unhooking and then rehooking the cable at the lock end. New swear words were discovered. Still it's done now and everything in the door works afterwards, plus I no longer have to open the window to get out, so that's a win
mylittletony
@mylittletony
Mar 21, 2024 11:30:14 GMT
Long time update: We've had a few days without so much rain and it's a bit warmer, so... I drove it to work today! 2nd time driving, ten times the distance (15 miles vs. 1.5 miles) I was nervous again, been several months since I drove it last, but it was awesome fun! Not the best car to deal with traffic, but ok after some time mastering the clutch. Brakes are soft now, but it's got brand new pads and I was wearing work shoes with wider soles than ideal. A quick squirt shows around 1 bar of boost (I was curious!) it's fast! There's a couple of mechanical noises which I'll look into and I think I need to rebalance the wheels. The ride was pleasantly surprising, I remember it being a bit firm but it soaked up bumps pretty well. Really looking forward to the drive home!
zeberdee
Club RR Member Number: 2
1978 Fisher Fury - whoosh!zeberdee
@zeberdee
Club Retro Rides Member 2
Mar 21, 2024 11:59:24 GMT
Really liking the wheel choice .
Somehow adds to the ‘period correct’ kinda vibe it has .
Be nice if you could loose a little tyre to arch gap , but that’s just my opinion . (Think I remember you saying you might be working on that ?)
Steve
Making progress in small, easy to handle chunks of awesome
Mar 21, 2024 12:03:15 GMT
GREAT SUCCESS!! Looks the part dude
mylittletony
@mylittletony
Mar 21, 2024 12:31:55 GMT
Really liking the wheel choice . Somehow adds to the ‘period correct’ kinda vibe it has . Be nice if you could loose a little tyre to arch gap , but that’s just my opinion . (Think I remember you saying you might be working on that ?) 👍 Thanks! I'm pleased with the overall look, although like you say it would benefit being a touch lower. The sump to ground clearance is borderline as-is, going off other people's greater experience. It already has a shallow sump fitted... In the short term I may try winding down the coilovers a touch, but given the state of the roads I don't think I can go much lower. Longer term I would need to raise the engine, which has a lot of ramifications.
Mar 22, 2024 10:04:48 GMT
Great to see it out! If the clutch is hard work it might be something you can fix with a change of master or slave cylinder. The Anglia has standard Girling type master cylinders and they come in all different size bores. I put in the smallest one they made and an oversize slave cylinder to make a light pedal with sensible throw.
Darkspeed
@darkspeed
Mar 23, 2024 23:37:20 GMT
Good too see that you are getting the chance to get out and use it.
The swap from 15's to 13's will have a marked difference in the ride, especially if you have the tyre pressures in the 20psi range.
For the brakes feeling soft its also worth checking the bulkhead the master is mounted on - Get someone to view it whilst you give the pedal a hefty shove - Some cars are quite flexible in that area and benefit from reinforcement.
I liked the Wolfies - So much so that I may be tempted go that way on the V8 Gemini....
mylittletony
@mylittletony
Mar 24, 2024 11:31:32 GMT
I'm pretty sure the tyres are around 20psi, but will double check.
The pads are brand new, so have only had 30 miles of use, hoping they will bed in after a few more drives. I'll definitely check the mounting area and pedal arrangement. It may just be that it's very different to my A2 😂
As for the wolfrace, I still have them and no intention of getting rid. Currently thinking of fitting some stickier tyres... I would really like a pair of 6s to replace the 5.5s though
