Jul 22, 2023 14:16:28 GMT
So I've just fitted my roll over valve and blanked off the original pipework to the original valve. I've routed some fuel hose down through a grommet in the boot and drilled it to size. When I pulled the original pipe off the tank went 'bong' and it sounded like there was a giant tying to suck a maccies milkshake through a straw for about 30 seconds... I'm hopeful the valve will do the trick! I'm about to head out and test it whilst buying new bulbs as it seems I need 2 taillight and a reverse light. The dodgy scotchlocks are all coming from the tow hitch which is a relief as it means there wasn't initially a problem with the lights. Fingers crossed I can sort the lights today 🤞
Jul 22, 2023 15:20:16 GMT
Seems to be a success - couldn't drive with the window down before as it seemed to suck the vapors in. Test drive it was fine - no noises from tank or cap. Boot still smells a bit when you open it but I guess it's had, potentially, years of fuel fumes in it. I'll monitor it over the next week or so.
All lights at the back fixed! Only one warning light on the dash and that's for front pads. I've bought a set of pads and some very heavy new discs so that'll be my next job.
I've also replaced the ariel grommet which has stopped 90% of the water ingress in the boot. The rest is coming from the fuel filler gaitor. There's a split where it clamps onto the plastic hose. The hose was also blocked - I took it out of the boot floor grommet and blew down it - big fountain of curse word came flying out! Cleaned as much as I could from the main gaitor and tested it with the kettle. Nothing really came in - I guess with it being blocked, the water would fill up and find the split to escape through. Now the drain is unblocked, the majority of it is going the right way. - I may take it off and fix it with rubber cement or just replace it.
All in all a successful day on the big Jaaaaag
Jul 25, 2023 23:14:38 GMT
The rear tail and brake lamp have gone again 🙄
More investigation required. Fuel smell when driving gone though 👍
Jul 28, 2023 14:51:06 GMT
Bother on the lights. The earth for them is just behind the cluster so might be worth giving that a scrub if you haven't already.
The other thing that I've found is if there's any break in the sealant holding the lamp lens on then you can get water pooling inside the lamp, which corrodes some of the connections (and leaks into the boot!). Might be worth pulling the back off and seeing if there's anything in there. To fix that I just drilled a drain hole in the bottom of the lamp so it drained out above the bumper, which seems to have sorted it.
Bother on the lights. The earth for them is just behind the cluster so might be worth giving that a scrub if you haven't already. The other thing that I've found is if there's any break in the sealant holding the lamp lens on then you can get water pooling inside the lamp, which corrodes some of the connections (and leaks into the boot!). Might be worth pulling the back off and seeing if there's anything in there. To fix that I just drilled a drain hole in the bottom of the lamp so it drained out above the bumper, which seems to have sorted it. I'll have a look at that this weekend. I think it must be something daft. I'm hoping it hasn't popped the new bulbs and they're literally not getting earthed like you say 🤞
Aug 31, 2023 23:55:59 GMT
Sorted the lights - bad earth as mentioned 👍 I've been wanting to get it prepped for the winter so I put it on axle stands and jet washed the entire chassis. I then used Lanoguard and hit the whole thing. Thankfully, it's as solid at I thought it was - I found no nasty surprises! There's a patch needed where the passenger floor goes up to the firewall near the jacking point but the jacking point is still super solid (had it on the axle stand). There's also 3 or 4 very small pin holes in the driver's footwell caused by wet carpets so it's gone through from the inside out. I used a wire wheel and cleaned the floors up from the inside and then hit it with some paint just for now as I'll be welding the hole up and then tidying it up from there. Now for the current issue.... I drove it round the corner and it decided to cut out when the revs dropped down. It only did it occasionally but when it switched to LPG it did it every time. I decided to give it a full service and change the ignition parts - turns out the plugs aren't iridium (need hotter plugs for lpg) so I bought a set. I changed the plugs, leads, dizzy cap, rotor arm, and coil and then changed the oil and filter. Then I got a check engine light! 😂 When I checked the code it says FUEL 23 FAIL 23 I'm currently trawling Google for ideas but if anyone can point me in the right direction that'd be swell! Here's some pics of some nice new ignition parts and how it looks under the arches with the Lanoguard ![](https://img.retro-rides.org/i/v/daveyboy20/f4d3dc6fb232.jpg) ![](https://img.retro-rides.org/i/v/daveyboy20/bfc2f06a1b13.jpg) ![](https://img.retro-rides.org/i/v/daveyboy20/478570bf61f0.jpg)
it seems fuel code 23 is for the oxygen sensor reading rich, could be many things I would start with clearing it leaving it on petrol and seeing if it goes away, LPG systems can set codes like this on the change over.
I expect you've found this site in your googling, but if not it's got a list of all the fault codes: www.jagweb.com/aj6eng/fault_codes.phpAlso, I remembered that XJ40.com doesn't appear on google for some reason (does that mean it's part of the dark web ![:D](//storage.proboards.com/forum/images/smiley/grin.png) ). It's one of the better XJ40 sites for technical expertise, so you might find something there.
I expect you've found this site in your googling, but if not it's got a list of all the fault codes: www.jagweb.com/aj6eng/fault_codes.phpAlso, I remembered that XJ40.com doesn't appear on google for some reason (does that mean it's part of the dark web ![:D](//storage.proboards.com/forum/images/smiley/grin.png) ). It's one of the better XJ40 sites for technical expertise, so you might find something there. I'd forgotten about xj40.com - thanks. I already have a login from the last time I was trying to get one!
it seems fuel code 23 is for the oxygen sensor reading rich, could be many things I would start with clearing it leaving it on petrol and seeing if it goes away, LPG systems can set codes like this on the change over. Seems to have gone away now - drives absolutely great but if I put it in nuetral and rev it it cuts out. Does it everytime on LPG and occasionally on petrol. No warning lights or codes now though
oto67
Sept 3, 2023 10:14:32 GMT
Cool thread buddy an a brave man for taking the old girl on. I well remember em coming out in i think 86' but its a long time ago now so may be wrong, anyway i remember the chat about all the ''on board computers'' with 6 being the generaly accepted number (at least down the pub) and the debates about wether the advanteges of all the electrickery outweighed the concerns of problems down the line with so much more to go wrong. Bare in mind that most of us knew sod all bout ECUs then and most of the motors we had anything to do with were all points @ condenser etc an the most modern lecky bit was the radio lol
Sept 4, 2023 12:19:20 GMT
Cool thread buddy an a brave man for taking the old girl on. I well remember em coming out in i think 86' but its a long time ago now so may be wrong, anyway i remember the chat about all the ''on board computers'' with 6 being the generaly accepted number (at least down the pub) and the debates about wether the advanteges of all the electrickery outweighed the concerns of problems down the line with so much more to go wrong. Bare in mind that most of us knew sod all bout ECUs then and most of the motors we had anything to do with were all points @ condenser etc an the most modern lecky bit was the radio lol Thanks man - interesting to hear that perspective! I was but a bonny wee bairn when they came out but I've always, always loved the look. Had lots of x300s and 308s but never been brave enough for an xj40 until now. I'm absolutely loving it!
Sept 4, 2023 12:23:15 GMT
Sept 4, 2023 15:38:43 GMT
Very shiny!! Cool old thing.
Sept 4, 2023 16:47:28 GMT
very nice, the real challenge would be it getting that level of shine on the capri !
Sept 5, 2023 14:40:38 GMT
Ha ha, that won't be happening any time soon!
Sept 5, 2023 14:41:09 GMT
Cheers, I sure think so!
Sept 5, 2023 14:54:32 GMT
The stereo has clearly been replaced at some point as the wires in the back of the Jag stereo have been brutally sliced at the plug. The original stereo has been thrown back in to sell the car so obviously doesn't work. Now, I could wire it up again following the colours but I suspect that it would sound a bit papp and I'm partial to some tasty sounds in my rides. I'm wanting to keep the interior looking period correct so have been researching headunit options and I'm pretty much settled on the Blaupunkt Skagen 400 DAB: It's around £140. The one below it is £80 but it's less powerful. This one is 4x50watt. It has bluetooth, USB connection, and AUX in as well as DAB radio. There's another Blaupunkt one which looks awesome but is WAY out of my budget. This one also has different colour lighting to choose from so I'll be able to switch to green to best match the interior lighting. Now the problem I'm having in my research is that my XJ40 is a 92 model and therefore has a 6 speaker system with some shared earths. The speaker wiring is also very thin meaning 20watts max. There are 2 bass speakers under the rear seat and 1 coaxial in each door. I believe the door speakers are 3.5" whereas the rear bass pair are 5.25" (please correct me if I'm wrong - there is a lot of conflicting information!) It seems that I wouldn't be able to just fit this stereo as I wouldn't be able to wire the 4 channel headunit to the 6 channel system. So my current thinking is - buy 4 new door speakers and put new thicker speaker wire in. Keep the back two speaker grilles for original looks but behind them fit an underseat sub/amp (assuming there's space as I've not looked yet.) Has anyone got any experience of this in a 6 speaker XJ40? Also - as I'm not so hot on understanding the specs - could someone please recommend the best speaker specs to match this headunit? Specs; Speaker Outputs (Channels): 4 Preamp Outputs (Channels, Voltage): 4 (RCA, < 2V) Sub-Out (Channels, Voltage): 2 (RCA, < 2V, gain/ frequency variable) Max. Power: 4 x 50 watts Sine power at 14.4 V: 4 x 24 watts (according to DIN 45324)
misteralz
Sept 5, 2023 19:58:22 GMT
Can you run an amp with the Skagen? I've got the Bremen and it's a lovely bit of kit, and also has the provision for an amp. It's fine as it is in my wee car, but an XJ40 has a lot more space to fill...
misteralz
Sept 5, 2023 20:03:03 GMT
Okay, just looked and the answer is yes. I'd whack it in and see how it sounds, and if it's a bit weedy then run an amp.
