Nov 26, 2007 21:42:30 GMT
Hi guys and gals. If you had a lowly old early RWD Toyota and wanted to give it some sparkle, what Toyota twin-cam carburettored engine with 5 speed box would you put in it which is still reasonably readily available?
Not knowing my Toyotas all that well, I'd be thinking of buying a running rot box and scavenging for parts and dumping the rest. What would be my donor car? 1600cc - 2000cc without scrapping an important model. Does such a thing exist?
Cheers
Ferg
Nov 26, 2007 21:54:07 GMT
have you thought about mk3 supras? 3 litre straight 6 either turbo or na. there are loads about for cheap. not too much of a shame to kill one off for bits.
The Doctor
Club RR Member Number: 48
Nov 26, 2007 21:55:04 GMT
You can get a 2T-G (1600cc DOHC 8V with twin solex-mikuni carbs) or an 18R-G (2000cc DOHC 8V with twin solex-mikuni carbs). Both very rare (and cost loads to refurb/service because parts are getting rare). You can get an 4A-GE (1600cc DOHC 16V) fairly easy, but since it's fuel injected, you have to change to injection or fit carbs to it Enginewise it's the best choice, reliable, cheap(ish) and lots of parts and tuningparts available.
The Doctor
Nov 26, 2007 21:59:22 GMT
have you thought about mk3 supras? 3 litre straight 6 either turbo or na. there are loads about for cheap. not too much of a shame to kill one off for bits. my experience with those cars is, that they are as reliable as ... well... not very reliable ;D Be ready to stack a load of headgaskets and bigend bearings ;D
Nov 26, 2007 22:20:48 GMT
Thanks for the replies guys. I have a Corona RT40 you see, or will have shortly and will probably want more oomph and stoppage. What cars should I look for for those engines and some disc brakes?
Ferg
Nov 26, 2007 22:24:57 GMT
i have just bought a 4age from ebay, it was £100 from a mr2, with the box, althogh no use to me!
Now, with a little bit of farting about, i am going to fit it to a type 9 sierra 5 speed, although, i would if a road car use a toyota box.
I'm going to use the tvis injection, although for you there is no reason why you would not use bike carbs, better than webbers or delortoes...
cheep chearful you wont regret it!
The Doctor
Nov 26, 2007 22:25:21 GMT
RT40... then i'd be looking for an 18R-G, will probably slide on you own enginemounts (and search for the matching P51 5 speed gearbox). Found in Celica RA28 GT (ST had the normal 18R, which isn't bad either) and Celica RA40 GT. any pics of your Corona? ;D I can't give any advise about brakes, i don't know what suspension/brakes those Coronas use.
Last Edit: Nov 26, 2007 22:28:29 GMT by The Doctor
Nov 26, 2007 22:30:46 GMT
are they solex's?
Nov 26, 2007 22:30:51 GMT
You've probably seen it quite recently. Collecting on Saturday Would it be criminal to buy a rotten Celica GT for spares and scrap the remains? Ferg
The Doctor
Nov 26, 2007 22:33:17 GMT
well, probably yes, but who cares ;D It's also criminal to leave your Corona like that ;D Lovely car! I always loved the shape of those! yeah they are, Solex-Mikuni 40PPH carbs
Last Edit: Nov 26, 2007 22:33:56 GMT by The Doctor
Nov 26, 2007 22:41:30 GMT
i thought they only came on i-tal stuff, i have a set for my lada, although didnt work as well as a single 45 webber sp...
Nov 26, 2007 22:41:40 GMT
have you thought about mk3 supras? 3 litre straight 6 either turbo or na. there are loads about for cheap. not too much of a shame to kill one off for bits. my experience with those cars is, that they are as reliable as ... well... not very reliable ;D Be ready to stack a load of headgaskets and bigend bearings ;D ah fair enough. i was going on the cheaponess and commonness factors. i know finding a 4age isnt hard but the box is... lovely sounding engines when on throttle bodies though.
Nov 26, 2007 22:57:40 GMT
Yes but the thing is , if you listen to the sound of a mkii escort with a bda in, it sounds exactly the same!!!
Nov 26, 2007 23:42:35 GMT
I was watching that on ebay......i'm pleased the owner ended up on here Good buy you got there I personally would go the 4age option.Other 4 pot toyota rwd options are very thin on the ground.2tg's and 18rg's are very rare in this country. Have a looksee here and here
I was watching that on ebay......i'm pleased the owner ended up on here Good buy you got there I personally would go the 4age option.Other 4 pot toyota rwd options are very thin on the ground.2tg's and 18rg's are very rare in this country. Have a looksee here and hereThanks for the reply. Am I right in saying 4AGE was in RWD Corolla and EFI only? I would want to stick with carbs Cheers Ferg
it was in the ae86, the mr2, the corolla ae92?
the only rwd injection was the ae86 i think...
You can easily bung carbs on it. Ooo looky here
I know its a RT51 but the theory is the same. This one is the 'Silver Top' 20v 4A-GE with the factory quad throttle bodies on display. Let me know if you want a PDF of the whole article.
Sweet! I'd love a PDF of the whole article, thanks. Please send to ferg[AT]monkeyrun.co.uk
Cheers
Ferg
I've got a spare 3S-GE 2000 twincam from a fwd celica, I've seen a few converted to RWD then all you need is a set of bikecarbs and megasquirt for the dizzy £50.00 for the engine
