Sept 14, 2022 6:25:38 GMT
Great progress! These are such cool cars, would make for a great weekend break / free party car with a bed in the back! I have had three Citroen XMs and a BX too, I love and hate them in equal measure Great work getting on with the welding. I would say if you can cut back and weld the rust then do, it will reward you for years to come this way without that fearful bubbling appearing below the filler and paint. How is the hydraulic system? Have you had any luck with the snatchy brakes?
mrmichael
**1990 Citroen CX Safari**
Sept 15, 2022 9:47:46 GMT
Blown_Imp - Funny enough the hydraulics work amazingly! its leaks (alot) but only from one area so thats a good thing! that one area being the single main line that runs down the center of the car (most likely to fuel the rears) but most will get ripped out and changed anyway so its promising. I see what you mean about the love hate relationship, at the start I was really motivated about this project then a month into it i dwindled, I had this thought in my head "oh it will be done in a month" and then every time I found a new issue it put me back and back. Just had to take a step back and look at it with an open mindset. The car has been sat since roughly October '08 judging by the last MOTs mileage and the date the last tax ran out, so it will never be perfect, especially considering there must have been a reason why it was took off the road for one reason or another? economy crisis in '08? -Michael
bilkob
Sept 15, 2022 19:10:07 GMT
It shouldn’t have ‘snatchy brakes’ . CX brakes, indeed all the proper hydraulic Citroens have superb brakes. Almost zero pedal travel, it’s about pressure, not travel. Once learnt, you’ll marvel at the vague, squishy wibblepoo lesser manufacturers foist upon us. Or you’ll be thru the screen……🤣
mrmichael
Sept 16, 2022 12:26:36 GMT
bilkob - As i say, its either nothing or an emergency stop! Something to get used too
eternaloptimist
Sept 16, 2022 12:51:10 GMT
Just found this. You made a comment earlier on that the brakes were either emergency stop or nothing. That’s how they are until you learn how to apply gentle pressure to the brake pedal. Similarly with the steering; DIRAVI is unlike anything else. I’d have another in a heartbeat.
mrmichael
Sept 19, 2022 18:50:44 GMT
todays update: French electrics mixed with the previous owners engine swap resulted in some quite bad tasting electrical spaghetti, regardless I had to push on, due to the fact my feet kept getting caught in the mess under the footwell. I decided to take all of the covers off, along with the clocks to really "start again" as such, sorting wires my own way, pushing more wires into the dashboard that didnt need to be exposed and so forth. This is what is looked like just after I had took the clocks out. And this was the work after about an hour, may not seem much but during this time it was a great learning experience of where cables went, and where they were plugged into. Especially for a very novice CX owner. so all the cables in my hand would go to the clocks, with the cables on the floor being for the shroud, for hazards, rear wiper etc. After the top half was sorted and the clocks were back in (forgot to take a picture, thanks Michael you daftarse) this was the result after the shroud was fully fitted, some cables as you can see are still on the floor however, those will be tucked up when the junction box is ready to go back in, however the car is still plagued with loads more electrical gremlins so not jumping to conclusions just yet! To end a lovely productive day, I took this photo, enjoy it!
mrmichael
Sept 19, 2022 18:54:54 GMT
eternaloptimist - Agreed DIRAVI is certainly something special in this world! the CX has always been a dream, I smile at the littlest things with this car! its a pride and joy for sure! Glad you found this thread, I love nothing more than waking up to comments to reply too!
mrmichael
Sept 27, 2022 9:36:53 GMT
Hey Guys! time for another update: Unfortunately, I am chocka full of cold, along with the weather being mainly sh!te this has caused work to come to a standstill. However, winter is on the horizon and with this comes the dreaded weather, so making the car watertight, and welding new sections to place the rust is a priority, as no doubt it will only get worse as winter rolls in. So I decided to start by cutting out the sections of the rear drivers side door, it was fully intact, however it had rust away from the outer skin of the door, leaving it to trap water and what will eventually rust the door more if its left. So a few sparks in my eye, a few burnt fingers, and some metal in my eye later the bottom of the door was chopped out (i later invested in some safety goggles) This being the before...... With this being the after cut photo, its just like getting a new haircut ey! Once I removed the section of metal however, the rust problem became more evident, clearly the rust had started on the outer skin of the door, and when that developed several small holes water got in, and water sat inside on top of the metal base, leading to the rust. This can be evidenced by the amount of rust that fell out of the door, when i removed the section of metal RIP - Citroen CX, ashes to ashes, rust to rust Once that was all dust paned away (using my parents best indoor brush), I decided to straighten the edge on some metal I got a while back (0.8mm) from Ebay. I decided rather than one big piece, I would use several smaller pieces, this would allow me to get alot more adjustment on each panel, along with making welding abit easier, and would not waste as much metal if something did go wrong (blew a hole in metal etc) So it was getting late by this point (around pm) and we have a 1 year old at home, and I'm sure my neighbours wouldn't appreciate the grinding noises (insert dirty joke here) so i decided to call it a night, after i got around 5 pieces made. This was a picture of the first piece of metal roughly taped in place, I realised after i was done, that it still need a slight few mm taking off as it makes the door bow out ever so slightly, not noticeable, but if you bend down, you can see it on the sill cover how it doesn't fit quite right Next stage is to slowly start to spot weld the metal in place! once I have had a play around with my flux core electric MIG. Thats all for now folks! thanks for staying interested Take care, Michael
mrmichael
Feb 23, 2023 15:54:46 GMT
Hi all,
Its been a while, and with that comes exciting (for me anyway) news!
The CX has officially found an enclosed garage to live in, whilst i work on it.
I live right on the seafront (less than 5m to the beach) so the northern winds are a pain, especially when doing fiddly type work.
Currently, the car is rear wheel "less", with the back brakes off in prep for welding and disc resurfacing!
Fun fact of the day, the I found an installation date on the brake pads, which was 2 months before it got taken off the road, strange, clearly was able to stop....
Watch this space folks, alot of updates to come! hope you're all well
mrmichael
Mar 25, 2023 18:49:13 GMT
Evening folks! Started off the weekend with tackling some of the inner rust, starting with some rear sill work. Its been patched towards the rear jacking point, however water has got in and rotted it away inside out!, the easiest way possible was to just cut it out and start again, which is exactly what happened Before: After: Now a lovely (staying optimistic) blank canvas so the outer bodywork can be glossed up, and a new reinforced section of metal welded in place, with a lovely dose of WaxOYL. Whilst owning the car, i reckon its had a wack of some description on this side, as the door catch section of bodywork was 99% filler and 1% metal, that much infact when i shut the door quite abruptly (after banging my head on it) the filler fell out ! leaving me with this:
Anyways, it started to get cold inside the garage, and i decided to hold off on any further work until weld through primer arrives (thanks Evri) Any questions do ask away, I love hearing from you all
mrmichael
Jan 24, 2024 13:36:17 GMT
Very neat work! Nice welds on thin tin, and the return you've formed is nice as well. This car looks like it's in good hands!
Have to say, hats off to you. I couldn't even begin to think about welding until I was in my mid-twenties, and even at 34 my welds are passable. This is such a cool (and rare - when was the last time you saw one) car, keep up the good work.
Feb 22, 2024 13:06:55 GMT
Love those 80's citroens, great color on this one too! Your welding has greatly improved since your first posts, great job! Keep up the good work!
1982 Ford Sierra 1.6 L - 2.O Pinto swapped 1990 Volvo 460 Turbo 1.7 1994 Ford Fiesta 1.6 16v 1996 Ford Fiesta 1.2 16v
mrmichael
Apr 15, 2024 12:27:16 GMT
Work has slowed down slightly, but the welding still continues. Finding time to work on the car in-between my working schedule is a pain. I've had to cut quite a big section out from around the passenger rear seatbelt location. The unit itself its almost sat on a metal shelf which had rusted right through and was weakening the actual structure of the rear end. Everyday is a step closer, that's what i keep telling myself
Apr 21, 2024 18:03:19 GMT
I can't see your pictures, which is making me sad because I f*cking LOVE CX Safaris. Am I doing something wrong are are your pics down?
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
