Time to convert over to a manual choke from the standard factory electric one. I did the same on the previous Edelbrock.
I despise the electric chokes on these with a passion.
Hateful things that are always going out adjustment and constantly closing back up wether they need to or not.
I’m sure someone’s going to tell me they’re the best thing ever! Good, I’ve got a pile of them I’ll box up and send them to you.
The conversion kit is a big bundle of levers and linkages with the worst set of instructions ever.
Luckily there are a couple of half decent YouTube vids that help greatly.
After removing the choke pod a vacuum port becomes exposed that needs to be plugged.
A lead ball is supplied for the plug.
Which is simply banged into the hole.
The electric fast idle arm needs to be removed from the primary throttle shaft.
To be replaced with the manual choke version and stop lever that also has a spring behind to keep it all under tension.
With the retaining screw reinstalled the throttle shaft was now jammed and notchy.
Taking it back apart, a quick squeeze of fast idle lever had it all freed off and working smooth again.
The two main linkage pieces need to brought together.
Again, these are all spring loaded and the levers have to be orientated correctly on their stops for it to function properly.
The whole assembly has to be held together while being fitted plus lining up the pull Rods in their correct holes and getting the fixing screws in. It takes a few attempts!
The kit comes with two choke pull arms and two choke cable clamps.
The right combination has to be worked out but the instructions actually cover this.
One completed rebuild.
![](https://img.retro-rides.org/i/v/4ever4/dbb735d3a028.jpg)
![](https://img.retro-rides.org/i/v/4ever4/8add5e4e8579.jpg)
![](https://img.retro-rides.org/i/v/4ever4/1e4ec175dd08.jpg)
![](https://img.retro-rides.org/i/v/4ever4/d43c26679cb9.jpg)
![](https://img.retro-rides.org/i/v/4ever4/6a1bcb4cf421.jpg)
![](https://img.retro-rides.org/i/v/4ever4/0256d3d346cc.jpg)
![](https://img.retro-rides.org/i/v/4ever4/ef109a20cb44.jpg)
![](https://img.retro-rides.org/i/v/4ever4/e8366fd3fbea.jpg)
![](https://img.retro-rides.org/i/v/4ever4/5673c93fbe00.jpg)
![](https://img.retro-rides.org/i/v/4ever4/11ffaae0e7c2.jpg)
![](https://img.retro-rides.org/i/v/4ever4/ba8e5f877a7f.jpg)
![](https://img.retro-rides.org/i/v/4ever4/ea83b22fa493.jpg)
