jehu
Sept 17, 2022 12:39:46 GMT
I never balanced the fan on any of the Jag's i've rebuilt previously and i've never seen any seperate balance weights on the fan on any other cars with stamped metal fans. Personally I wouldn't worry about it as I can't imagine many of these weights were refitted and/or reset when water pumps were replaced when the cars were in daily use. I guess that is the way I'll end up going Homer, with a few washers to get it as near as I can. My problem is I'm a bit of a pedant when it comes to following the manual. Do Jag's have the same counterweight on the fan originally? Cheers Jehu
2016 Audi Q3 1976 MGB 1968 Daimler 250 V8
Sept 17, 2022 12:44:16 GMT
I never balanced the fan on any of the Jag's i've rebuilt previously and i've never seen any seperate balance weights on the fan on any other cars with stamped metal fans. Personally I wouldn't worry about it as I can't imagine many of these weights were refitted and/or reset when water pumps were replaced when the cars were in daily use. I guess that is the way I'll end up going Homer, with a few washers to get it as near as I can. My problem is I'm a bit of a pedant when it comes to following the manual. Do Jag's have the same counterweight on the fan originally? Cheers Jehu Yes the MK2 Jags have the same balance weight arrangement, given that the engines don't rev particuarlly high and they aren't especially a precision instrument i've never been concerned by it. If it were high reving and highly tuned then I would perhaps consider it but an electric fan would probably be the better proposition in that circumstance.
Sept 17, 2022 22:06:52 GMT
Jehu, Let me take a look at the Daimler v8s I've got here (I have 2) and I'll let you know whether there are any weights on the fans.
1964 Daimler 2.5 V8 (project)
2015 Disco 4 SDV6
Sept 18, 2022 7:26:56 GMT
The engine which is in bits has what appears to be a 'late' model Japanese plastic fan with viscous hub. The bolt heads are marked with metric grade 7. I haven't investigated the water pump on this one any further, but don't think this finding is very useful to you. The parts car is pretty original looking and hasn't been pulled to bits. It is very rusty. It doesn't appear to have a balance weight on the fan, and no evidence there ever was one. Both cars are 1964 and NZ new.
2015 Disco 4 SDV6
jehu
Sept 18, 2022 23:17:39 GMT
Thanks Homersimpson and Edwagon, I will not worry about it further and the Japanese fan assy looks like an alternative solution if there was an obvious issue. It does seem strange though that the manual gives 3 pages to it when it seems to be superfluous. I suppose it's akin to the provision of locking tabs every where on the daimler when modern high reving engines don't use any.
Last Edit: Sept 18, 2022 23:19:39 GMT by jehu
Sept 28, 2022 10:17:41 GMT
Hi Jehu, yes that's mine. If you want some light reading material to get you off to sleep, my blog is at lootintheboot.uk I've read your thread. Some up's and down's....just like the rest of us...lol. At the beginning you mentioned that you had already completed a load of work, I'm sure we'd all be interested if you have some time to write that part up too. we all love a good story! What an amazing rebuild Voucherboy. I showed someone the pics of your body work before you repaired; their comment was, "No self respecting garbo in Aust. would take that away." You certainly set yourself a challenge. The only welding I have ever done was the occasional 'tack' weld as an apprentice. And the last time I did that (50 years ago) was after waiting on a construction site for 2 hours for a welder to come and do it so I picked up the welder and did it myself. The next thing I knew was everyone was out on strike over a demarcation dispute. It took me a moment to realise it was because of me. ) Anyway your work is an inspiration that I am glad I don't have to do. Thank you Jehu, yeah, lots of work with lots still left to do, hopefully over the 75% complete mark now though. Your welding story sounds exactly what it was like here around that time too. Slightest thing and the union rep would blow the whistle and 'All Out!' ..lol. Great to see of your progress pics on here too, keep us posted.
jehu
jehu
Strangely I seem to have a have been supplied 'paper' gaskets for the exhaust manifolds as well as composite ones. I cant imagine why you would use paper ones.
jehu
A question for Daimler V8 and Mk2 Jag enthusiasts: After vacillating for ages over whether to drop out my front suspension and overhaul it, I have finally decided to bite the bullet and go for it.
The question is, where is the best place to get cheapest parts? And are the dearer alternatives (presumably genuine parts) worth the extra especially when there is often a range of alternatives of the same part? The best place in the antipodes is the Daimler spare parts club in Christchurch. They have usually been slightly better priced than UK on most things but they are a club and you have to pay for a membership before finding out price and availability - plus it is a bit trickier working out part numbers.
Comparing steering/suspension prices between SC Parts group and David Manners is an eye popping experience. I started with SP parts because I found their website easy to navigate. The first part I compared, an anti roll bar rubber bush was cheaper at SC parts at £6.20 vs £6.78 (no complaint there) - the second thing I priced was the front sandwich plate mounting - £12.00 at DM vs £37.40 or £52.49 for a genuine Jag one at SP parts. Bump stops are a similar difference - mostly about 3 times dearer at SP Parts.
The problem is I cant find all the parts I want at DM's eg. upper and lower ball joints etc. Any suggestions?
Last Edit: Nov 23, 2022 6:59:36 GMT by jehu
goldnrust
West Midlands
Minimalist
Nov 23, 2022 10:48:15 GMT
Haven't caught up with the build for a while, the engine is looking fantastic. www.sngbarratt.com/ are another UK supplier worth checking out. Not necessarily the cheapest, but I've had good service when I've used them and the website its good with nice exploded parts diagrams for most assemblies. Sadly the quality of some of the cheaper rubber parts is a bit disappointing. I used David Manners, and went for the cheapest option, for all my suspension bushes when I did my Daimler, and 2 years and ~2-3,000 miles later the wishbone bushes are looking perished and my second set of sandwich plates are pulling away from the backing. I think I will be trying the genuine sandwich plates next, or maybe the uprated polyurethane ones, despite the eye watering cost. Regarding your previous post, are the paper gaskets not intake gaskets?
Last Edit: Nov 23, 2022 10:50:39 GMT by goldnrust
jehu
Nov 23, 2022 11:39:25 GMT
Thanks Goldenrust, that's really useful especially your experience with the cheaper bits (sorry for you). I was thinking of going the cost saving way considering I wont be doing a huge milage and not driving hard - but serious signs of deterioration after just 2 years makes me reconsider. I just did a quick look at the sngbarratt site. It is disconcerting to see their prices vary wildly too compared to both of the other UK ones. Unfortunately it is too complicated to shop across the 3 of them. I should have thought of sngbarratt myself as I sourced some parts for my MGB through them and found them very helpful. Amongst other parts they accidently sent me the wrong engine mounts and a telephone call later they had the correct ones freighted same day (and told me to keep the TR4 ones which a friend appreciated . Yes I'm happy with the engine - looks pretty and I'm keen to get it back in. Of course the paper gasket must have been a spare set for the inlet - red face here!
Nov 23, 2022 18:58:17 GMT
For ball joints you can fit the later XJ6/XJ40 sealed units, thats what i've done on all the ones i've restored and its much easier than trying to rebuild the original ones.
jehu
Nov 23, 2022 21:32:45 GMT
For ball joints you can fit the later XJ6/XJ40 sealed units, thats what i've done on all the ones i've restored and its much easier than trying to rebuild the original ones. Thanks Homersimpson, I noticed that sealed ball joints are offered as an alternative for the Mk2/Daimler, I guess they are the same as the XJ6/XJ40 sealed units. Restoring the shimmed assemblies just for the sake of originality is a bit over the top I recon. Taking goldenrust's experience of cheap rubber deteriorating and delaminating, I am now stuck with deciding which parts to order and how much to pay. Across the 3 main UK parts distributors there are at least half a dozen different manufacturers and it's really hard to know how to tell cheap Chinese rubbish from something a bit better without going to the extremely expensive alternative?
Nov 23, 2022 22:52:27 GMT
For ball joints you can fit the later XJ6/XJ40 sealed units, thats what i've done on all the ones i've restored and its much easier than trying to rebuild the original ones. Thanks Homersimpson, I noticed that sealed ball joints are offered as an alternative for the Mk2/Daimler, I guess they are the same as the XJ6/XJ40 sealed units. Restoring the shimmed assemblies just for the sake of originality is a bit over the top I recon. Taking goldenrust's experience of cheap rubber deteriorating and delaminating, I am now stuck with deciding which parts to order and how much to pay. Across the 3 main UK parts distributors there are at least half a dozen different manufacturers and it's really hard to know how to tell cheap Chinese rubbish from something a bit better without going to the extremely expensive alternative? Its very difficult to know what is and isn't good.
I've used parts from David Manners so far on this one and the last one and generally they have been ok apart from the fuel tank rubbers that started to split. It really is pot luck and I would probably take a view on which ones to buy based on how important they are (i.e. if they fail what happens) and how hard they are to change.
One thing when stripping the front subframe, be careful with the springs as there is a huge amount of pressure in them, I used a piece of all thread through mine with a plate where the damper mounts to the lower wishbone and take it easy, the first one I did 20 years ago (a 1966 S-Type) I used a piece of all thread that was too small and it snapped and nearly broke my fingers!
jehu
Yes the springs look formidable. I am planning to use 16mm threaded rod which voucherboy did successfully lootintheboot.uk/running.htm I'm hoping that will be robust enough not to lose fingers. Homersimpson, sounds like you were lucky - I imagine a spring could do a lot more damage than breaking a few fingers.
Last Edit: Nov 25, 2022 12:38:06 GMT by jehu
