Nov 12, 2021 13:43:32 GMT |
Onward and Upward. started to do the install of the stuff i have been planning for ages. had an old counter top that i have been using as a template for the small sink near the door. going to put an IBC tank on the rack and harvest the rain.
Nov 13, 2021 11:50:23 GMT |
did a little bit today, i am taking my time on this build as i am only doing it once. cut out the hole for the sink and put a cupboard above it. Also secured the cupboard to the back wall ready to clean it and restock it with all the paints and oils etc.
Nov 14, 2021 11:25:50 GMT |
Filled the cabinet with the paint and oils etc etc, i,m sure there are more somewhere. Also started to sort out the front with an old damaged rim for the hose pipe also going to do an external powerpoint switched from inside so i can connect the pressure washer.
Nov 15, 2021 13:26:17 GMT |
some more done. I'm not a plumber so it will be compression fittings and adapters. put up the other cupboard. and the drain from the sink. closer look and its got a steel reinforcing bar in it, i,m lying on the floor with a hacksaw blade like I'm trying to escape from prison
Nov 15, 2021 14:58:53 GMT |
Looks good. Will be interesting to see what sorts of space-saving solutions you come up with. My current garage isn't a million miles away from what you've got at 7m x 3.3m (although blessed with a tall roof). Taking full advantage of the verticality has been really useful. Lots of storage up high, and a mezzanine shelf above the working area. Using rafters for storage, hanging bonnets on walls, and making tyre racks up high has been really useful. Edit: popped links to the photos so it doesn't take over your thread!
Last Edit: Nov 15, 2021 15:10:06 GMT by biturbo228
Nov 16, 2021 13:37:23 GMT |
done a bit today but had a slight hicup later in the arvo, i was drilling some small holes and accidentally drilled through my baby finger by [email protected] it hurt but now ok after a trip to A+E for Xrays and cleaning. so back to work on it all tomorrow.
Nov 16, 2021 14:19:10 GMT |
My boo boo.
Kron
Nov 16, 2021 14:29:46 GMT |
Ooooh, that just made my toes scrunch.
Nov 17, 2021 12:09:04 GMT |
Nov 17, 2021 12:11:34 GMT |
the pics of the cut on my finger are taken with an iphone 12 much better, and the other pics are taken with my iphone 6. Just thought i would clarify that.
Nov 18, 2021 13:08:48 GMT |
Nov 19, 2021 11:29:49 GMT |
Nov 19, 2021 11:33:30 GMT |
I'm going to have to hoist it up there somehow its not too heavy while its empty but 1000L is a Ton when full. so extra orange beam put in front.
Nov 20, 2021 10:34:09 GMT |
Nov 20, 2021 11:51:23 GMT |
Not bad for a fat 60 year old guy on his own.
Nov 21, 2021 12:25:44 GMT |
Only half day today, tideied up and put race car tyre rack.
Nov 22, 2021 11:41:06 GMT |
another half day again today. did some small jobs using stuff i had lying around. putting some copper pipe plumbing fittings and pipes along the walls etc. drainpipe from sink through wall to drain. temporary bolt in beam just to hold it while i put more mezz structure up.
Nov 23, 2021 12:13:28 GMT |
Nov 24, 2021 11:32:05 GMT |
put up the monitor screen so that it does not get damaged, and more done to the welding trolley.
Nov 24, 2021 13:37:44 GMT |
Looks really good does that! I get some weird satisfaction from fitting stuff in all nicely, like Tetris!
