May 19, 2021 10:32:48 GMT
Are there any models of cars from the 30s/40s/50s that would work as a base for a hotrod along the same lines as the US 1932 Fords like this?
I know 50s Ford Pops are popular as bases for hotrods but what else? Something like 30s or 40s Austins maybe?
May 19, 2021 11:24:05 GMT
May 19, 2021 11:42:11 GMT
They are all nice especially the last one.
British hotrodsstealthstylz
@stealthstylz
Club Retro Rides Member 174
May 19, 2021 11:49:34 GMT
34 Hillman is my favourite.
May 20, 2021 16:38:03 GMT
Not sure i've ever seen a Morris 8 before. I kinda like the shape.
May 20, 2021 18:17:07 GMT
May 20, 2021 19:04:53 GMT
Let's not forget there was a version of the 32 Ford built right here in Britain. They were only (to the best of my knowledge) available as 2 and 4 door saloons and there are minor differences in the body shell compared to the US versions. The UK/European versions were also built up to 1934 unlike the American one which was a one year only deal. I think this one's a '34 as it has different shaped wings. Wasn't there another thread on British based hot rods? If someone can find it and put a link it might save a bunch of repeats.
75swb
Beta Tester
Club RR Member Number: 181
British hotrods75swb
@75swb
Club Retro Rides Member 181
May 20, 2021 23:52:12 GMT
Was the British built '32 Ford a Model B4 with the same four cylinder running gear as the Model A rather than the V8?
Last Edit: May 21, 2021 0:19:19 GMT by igor
vulgalour
Club RR Member Number: 146
British hotrodsvulgalour
@vulgalour
Club Retro Rides Member 146
Vauxhalls of the 30s and 40s are very stylish things. Unfortunately quite rare.
May 26, 2021 14:18:42 GMT
I was going to put this in the spotted thread, but its not my spot, its someone elses. Its not only a Rod, its a RatRod. Not only that, I think it might be my personal car of the year, possibly decade [insert little medieval fanfare complete with trumpets with those little flags on] I mean, just look at it. Look. At. It.
horrido
May 26, 2021 15:30:52 GMT
1930s and 40s Austins are nice looking cars though they have incredibly high roof lines. The problem with old British cars is that they're almost all four door saloons. If you can find a coupe or a roadster you´ll be very lucky. Or you´ll have to make one.
May 26, 2021 17:16:06 GMT
Wish i had a pic, but many moons ago at a rwyb at the pod there was an austin 7 with a 2 litre pinto in it Boy could that shift! 😳
May 26, 2021 17:48:27 GMT
May 26, 2021 19:45:15 GMT
Dez
Club RR Member Number: 34
British hotrodsDez
@dez
Club Retro Rides Member 34
May 26, 2021 22:38:19 GMT
Let's not forget there was a version of the 32 Ford built right here in Britain. They were only (to the best of my knowledge) available as 2 and 4 door saloons and there are minor differences in the body shell compared to the US versions. The UK/European versions were also built up to 1934 unlike the American one which was a one year only deal. I think this one's a '34 as it has different shaped wings. Wasn't there another thread on British based hot rods? If someone can find it and put a link it might save a bunch of repeats. ‘Minor differences’ in that the entire body is completely, totally different in design and construction. They’re wood framed for starters. The only bits that are the same are the rolling chassis (except the steering, being RHD. Even the steering wheel is different) and the front fenders are the same. Everything else is different- body, dash, cowl, bonnet, etc. etc. They bear a passing resemblance but are in reality a totally different car. The 33/34 model 14 is different again, they only really share the chassis with American models as the front fenders are different. But then a 4cyl chassis is substantially different to a v8 one too...
Morris 8. nickwheeler is this what I looked at last week ? It is. Although that one has the front wings mounted further forward than standard and the rear wings have been widened. The CAD chassis mockup for my budget project: This is what Rhian looked at:
Nov 10, 2021 12:54:20 GMT
Nov 10, 2021 13:26:26 GMT
Not a chance; it's tiny. 1400mm across the rear wings, and the wheelbase is about 2200mm.
