The Doctor
Club RR Member Number: 48
RRG campsite transport The Doctor
@thedoctor
Club Retro Rides Member 48
It's early but I'm learning to weld with my first welder and I work slow at best, so I need the time! I've got this picture in my 'some day' folder for a long time and now is the time I try to make something similar. So I've been gathering some parts, and picking up a mower as base for the oily bits soon. Had a quick go at getting the engine to run. Next time I'll try not to get my rear end in shot
Of course I am watching.
I have a complete unused, galvanised wheelbarrow tub stashed out back that you could have had.
Pity Corona has played havoc with everyone..
If you do find an opportunity to get it picked up, and can get it collected, let me know.
craigrk There you go...... This would have been a good use for the mower glenanderson now has to restore.
Nov 13, 2020 11:18:20 GMT
I like it. I built a few Radio Flyer customs and recently acquired a mobility scooter to make into something cool. I'll be following your build.
The Doctor
@thedoctor
Nov 13, 2020 14:00:36 GMT
Though about going electric, for ease of building, but where's the fun in that. And where am i going to find the new electrons when the battery has ran out after too much fun on the gathering campsite! Fuel isn't easy within the area either, but a lot less hassle then power!
The Doctor
@thedoctor
It now runs, but the clutch is slipping badly. Need to see if I can find a clutch or get it relined. And it doesn't select all the gears correctly, guess that's some play in the linkage.
So, clutch time and then take it apart!
ChrisT
Club RR Member Number: 225
RRG campsite transport ChrisT
@christ
Club Retro Rides Member 225
Great looking project, will be watching with interest, have a ride on mower and several motors kicking about the workshop waiting to find a use for.....
The Doctor
@thedoctor
Made a start on the tub tonight. Doesn't look like I can make this years gathering, but there's always RRG22! Chassis first thing on the agenda now. And I need to work out how to route the belt and make a clutch system with it, as the clutch is broken.
Generic centrifugal clutches are fairly cheap, might be an alternative? Otherwise all my ride-on mowers have an idler pulley which takes up the slack in the belt to provide drive
The Doctor
@thedoctor
I'm thinking about the 2nd option indeed. Looks like it is the easiest way of doing it.
The Doctor
@thedoctor
Friday evening came, so it was barn time again. Had a little play with the parts from the lawnmower and had a change of plans. Putting the engine in the back will make the whole belt route a lot easier. Does look less good though. Now get some steel and start on the chassis side.
Mock up a false engine for visual effects? Engine is going in the back of the one Iβm (supposed to) build, apart from not slicing bodyparts off in a belt or chain, as you say, routing is much easier Can alwsys build a βbootβ around it to hide it?
The Doctor
@thedoctor
I already have the engine propped up on the slots (it's tiny! ) Belts not slicing off body parts is also a good thing. And now I only need 1 smaller belt instead of more and longer ones. Does need to go closer to the gearbox, but I couldn't get it close enough with the stuff in the way.
mfrv1
Jul 10, 2021 13:45:54 GMT
Looks like there's wheelie potential π
The Doctor
@thedoctor
Jul 26, 2021 10:39:40 GMT
Another weekends came and gone, started on the chassis. Not sure if I'm totally happy with it, but I'm learning as I go! Also made the steering work, now I need to reinforce it all so it survives the campsite
Last Edit: Jul 26, 2021 10:40:50 GMT by The Doctor
Jul 26, 2021 18:32:50 GMT
Naaah, flexible chassis will improve the ride quality! π± ( ask morganπ)
The Doctor
@thedoctor
Jul 26, 2021 19:19:25 GMT
Flexible chassis might stay as a way of shock absorbing, but the steering is floppy now. Don't think that'll survive
RRG campsite transport glenanderson
@glenanderson
Club Retro Rides Member 64
Jul 26, 2021 21:32:50 GMT
Is the Ackerman angle still ok with the axle mounted the other way around?
The Doctor
@thedoctor
Jul 27, 2021 15:14:04 GMT
Probably not, as I changed it all. There's also less turns lock to lock, and I have less steering angle now, but it works. First test (my mate pushing me while I tried to steer it) showed that it went around corners pretty well without weird behavior, so I'm calling that OK for now.
//edit : I have sincere doubts that the stock system had correct ackerman, as it was all over the place.
Last Edit: Jul 27, 2021 15:15:31 GMT by The Doctor
