Jun 28, 2021 15:42:43 GMT
Interesting re the inside door handles....how do Mk1 Frogeye Sprites get MoTs? Or is it a historic exemption?...not that I've had an MoT as its been SORNed for years! By the oem not having a solid roof and the door handles are within X inches of an unobstructed portion of the door.
mk2cossie
Club RR Member Number: 77
The Temptressmk2cossie
@mk2cossie
Club Retro Rides Member 77
Jun 28, 2021 17:04:51 GMT
Interesting re the inside door handles....how do Mk1 Frogeye Sprites get MoTs? Or is it a historic exemption?...not that I've had an MoT as its been SORNed for years! By the oem not having a solid roof and the door handles are within X inches of an unobstructed portion of the door. Thats pretty much it The MOT exemption is more so that things don't get incorrectly failed for things the younger/less experienced testers when they get older vehicles in
Jun 28, 2021 21:46:36 GMT
Thanks for the replies....but don't give Robert ideas about making a drophead AS!
Jun 30, 2021 19:08:26 GMT
Ello all , lots of interesting info about door stuff ,Thank you , i do like the starter idea , v cheap way to go . This week I had a bit of a go trying to talk to the ecu that controls the lpg mixture , had no luck , and took it apart to find this .. not a very healthy looking resistor , so i ordered another one , which will be here tomorrow.100 ohms 1 watt. Next my bit of rubber hose arrived , this meant i could finally connect up the water feed to the heater , and then get the inlet manifold on .. And then straight onto to the throttle linkage fun .. as you can see , there are a couple of rods connected the throttle lever , one from the pedal , and one from the gearbox ,the ratios and movement are important ,so i have to devise a way to mimic this on the new inlet . first off i made some measurements .. had a ponder , and decided to try to incorporate the original lever plate , to this end a got a shonky old bit of ally .. i measured the original mounting height of the lever , and mimicked that on the plate by drilling a mounting hole and a pivot plate hole . this then bolted to the inlet , and i experimented to get it all as it should be. to do this first i held the throttle pedal at the correct place with a spacer .. i then moved the mounting plate around to get the correct angle on the lever plate of 18 to 20 degrees , and found i needed to extend the rod by two inches .. there it is with a bit of s/s tube welded in . getting that rod off with its rusted in split pin was a delight . here is how it sits .. i spent a long time with the mirror on the stalk ,and the angle box setting the pivot plate angle , next i marked the plate , and drilled the 2nd hole so its bolted in two places and cannot swivel . tomorrow i will work on the vertical rod to bring the motion up to the throttle body . luckily i looked through Ali Babas cave of a thousand delights or A.B.C.o.a.1K.D and found these goodies.. which may come in very usefull indeedy . The prime benefit of using the original angle on the lever arm , is the gearbox rod , once i extend it , should behave the same way as it originally did . in other news . I spent a lot of time this last wek looking for the starter switch ,which i had lost . just about dismantled the cave , my bedroom living room car etc , but could i find it ...nope. When i started working on the linkage , i found the pedal pivot was seized ,and the rusty floor was giving way to let the pedal move ,a bit of lube and wiggling and it came free , but while i was in that area , i looked sideways ,and there wedged in a hole in the floor ,was this little urchin.. BRILLIANT . regards robert
Jun 30, 2021 20:37:11 GMT
......,"a bit of lube and wiggling and it came free , but while i was in that area , i looked sideways".....Very pleased for you Robert!!
Hah, the garage Faeries strike again!
Phil ! are you being SMUTTY young man !? in the corner !! Mark i am slightly disturbed by how you spelt fairies , it's all a bit magical , go on admit it , you think Narnia is a real place ? Well i had a success today , a job i thought was going to take days of plans graphs ,calculations etc , the throttle linkage with its multiple ratios , got done . looks like this .. and moves like this .. i have to make bushes an proper pivot bolts etc , but the design gives me full throttle when the pedal mechanism is on the stop , and closed throttle when the pedal is 50mm from its stop , and the pivot plate that operates the gearbox is 18 degrees off vertical . i made a new vertical rod , then shorted it 34mm , and drilled a new hole in the pivot plate to change the angular vertical movement ,did it all by eye and no paper was harmed during this process . pedal pressure is a nice smooth loading , and my experiment to drill the hard plastic cable disc on the throttle body , and then tap it 8mm ,seems to have worked . onwards !! tomorrow i take off the inlet again , so i can get at the gearbox rod , and extend it and free up its adjuting threads to make it possible to tailor it in . ( i also forgot to put silicone around the waterways ,but i don't want to sound inept , so lets leave that bit out ) regards robert
No......Narnia is not real........ The Ocean at the end of the lane is though.......
I thought the cupboard under the kitchen sink at the back of A.B.C.o.a.1K.D led to Narnia?
Still waiting for you to emerge with the lion skin rug for Medusa's lounge chair..
Wow ..... Smutty YOUNG man...I'll take that as a compliment! Seriously, you are doing a great job getting life back into such a classic car - especially as it had been neglected for so long. The upgrades are in keeping as well.
not a lot , but a little done . when i took off the inlet i realised that the hole number 2 was not sealing , and so spent a while on the 80 grit and flat plate sanding it down , here it is about halfway done with a black paint guide coat .. i then gave up , and handed it to a friend with a big linisher , and he will do the rest , , after i popped it on a press and tweaked it a bit in the area. i also re made the ally throttle brace plate out of 3mm stainless for extra stiffy ness nosity .. i tapped the pivot hole 3/8th unf , and used a prop bolt as the pivot ,with a nylock on the end . i then made a new thicker steel sealing plate for that hole on the inlet ,and reshaped the pivot plate , fitting a steel pivot hub... the whole mechanism.. lastly i need 7 knobs like these , and the club chap was all ready to give me some old ones cheap , 4 months ago , but then no luck after lots of asking, i wonder if i have been blacklisted due to crimes against originality , anydup , i am having a play making my own out or brass , i got a m12 domed nut , made a 7mm bore steel insert ,crossdrilled it with a m6 grub screw , and tried that on the shaft of the switch ,looks a bit like this .. also i could machine down the dome and fit a letter in the top . second lastly i lengthened the gearbox rod .. regards robert
Last Edit: Jul 6, 2021 19:43:32 GMT by ivanhoew
Like the brass against the wood, very much!
Excellent ,thank you George made a L shaped bracket today , and pop rivetted it to the side of the ignition switch , so i could screw the leg of the L to the back of the dash , i had to remove a few slices of ply so the switch was the right distance in the hole , also experimenting with letters for the switches .. oh as you can see i also drilled the dash ,and fitted the little chrome mounting screws . Regards robert
I don't think it's been asked before but what's the rust situation like on this one? I'm assuming it's on a full chassis so it only needs to pass the no gaping holes test?
Chassis appears solid all over DR , doors wings floors etc all a bit frayed . outriggers still there and fairly rigid but 40 % missing .
Are you hoping to get it running and driving on the road so you can get a feel for it before starting on the body modifications?
did you fix the LPG ECU? If you need it I think I have one I picked up years ago and never used you can have.
i didn't kevin , and yes please !
