Mar 18, 2021 16:49:56 GMT
In dipped beam mode, only the upper LEDs illuminate, focusing down onto the road surface, and providing width without dazzling oncoming drivers: Main beam illuminates through the biggest lens, projecting light everywhere else: I set the headlight alignment quite conservatively at first, to ensure I'm not an annoyance or hazard to other road users. The cut-off of the light pattern at the top is quite pronounced: Main beam is a bit different: My neighbour spotted me heading out for testing: Out on the test road, the conservative alignment and beam cut-off is very easy to recognise. Only drivers of Caterhams and Morgan 3-wheelers are likely to be disturbed. I'll gradually adjust the beam upwards to illuminate more of the road without causing offence: And if you were wondering how tall the hedges are, please refer to this image of main beam: The road surface here climbs up and then descends slightly, so it's a little misleading. The actual length of coverage in main beam is outstanding. No need for a WRC light pod for the speeds I'll be driving at. Before and after, on main beam: So, in summary, a massive improvement for a small investment, and all reversible if the LED units decide to fail or MOT requirements change again. I'm happy with that. Well, that was an UPDATE !! Great choice of direction with the lights. And as mentioned, cyborg-like sounds right. And the price of those units to me seem very good, amazing how much bang you can get for your buck.
Mar 18, 2021 17:02:53 GMT
Well, that was an UPDATE !! Great choice of direction with the lights. And as mentioned, cyborg-like sounds right. And the price of those units to me seem very good, amazing how much bang you can get for your buck. Cheers Grizz! The price of these LED units seems to be dropping rapidly. The first time I looked at them, they were at least £45 each. I bought them for £23 each, and now they're £18 each (i.e. £36 a pair). Bonkers value for money.
1991 Toyota Deliboy (RWD JDM LCV) - Now SOLD 1998 Lexus LS400 (RWD EUR VIP) - Also GONE 1989 Volvo 740 GLE (RWD EUR GLE)
Mar 23, 2021 11:44:55 GMT
29 years ago, I received a Higher Grade qualification in Physics, and another in Technological Studies. Since then, I haven't troubled myself with witchcraft, sorry, electrical systems. Fortunately, some people on the internet have, so I've copied their homework. The reason for doing this is to make the Main Beam warning light functional with the new LED headlights. These headlights only connect to one of the vehicle harness H4 connectors to get a switching signal (on the passenger side), and there is not enough resistance in the circuit to trigger operation of the warning light. According to a young man on Custom Tacos (disappointingly, this is a forum for owners of Toyota Tacoma pickups, and not related to tasty Mexican food), he calculated that he needed a 10w 50ohm resistor bridged across two terminals of the H4 connector. The following link is for my records, you really don't need to read it: www.customtacos.com/threads/hi-beam-indicator-fix.156849/Having purchased such a resistor, it was time for a series of experiments... The black box at the bottom is the load resistor relay that I purchased online. It's not set up for a switched ground circuit, so plugging it in did nothing. Next, I plugged in the old Halogen bulb to the empty connector on the Driver's side vehicle harness. The main beam indicator worked as normal. That's fine, but having a hot, fragile and unprotected bulb waving around in the engine bay didn't fill me with confidence. The old LED bulb (with it's little link harness) lit up, but doesn't have sufficient resistance to trigger the indicator. So, that left the ceramic resistor to try, with the aid of some spare wires and spade connectors from the Headlight kits. It works! Kind of... 50 ohms is actually a lot of resistance, and I kind of regret not reading this more detailed post first: www.4crawler.com/4x4/CheapTricks/Headlights.shtmlThere are a lot of words and diagrams and calculations, but the important part is here: So, while the main beam indicator comes on, it is very dim indeed. It might be visible in the dash at night, but it's not going to be very noticeable compared to the other lighting, and warning lights generally should be fairly easy to notice. Maybe the Taco guy has a very different system in his truck (or he should have spent more time on his studies). After a bit more reading (slowly, to avoid frying my brain), I got to this bit: As I don't want to risk the resistor burning out prematurely (not that I flash people a lot, but just to be on the safe side), I decided to skip whatever other complicated recommendations he made and go straight to a 20w 10ohm resistor, which will look the same as the one I currently have, but allows the indicator to be visible. Now I have to put the van in the garage for a month to take care of important family matters, but hopefully when I go back to it I'll remember to look at this thread and remind myself what I'm supposed to be doing...
Last Edit: Mar 23, 2021 21:33:51 GMT by Flingstam
Mar 23, 2021 21:47:19 GMT
We will be waiting....
Go do your thing, trusting all is going to be good.
The 20W 10ohm resistor turned up, and it's a lot bigger than the 50ohm one was. Anyway, last weekend I soldered it really badly to some off-cut spare wires with spade connectors already installed, and covered my shoddy workmanship in heatshrink. Then all I needed to do was install it into the correct slots on the vehicle wiring harness connector, and secure it so it wouldn't swing around in the engine bay. Lo and behold, normal warning lamp service has been resumed. Easy peasy...
Last Edit: Apr 12, 2021 9:49:05 GMT by Flingstam
Apr 14, 2021 15:09:57 GMT
I click on this thread just have a random grin and a feeling like one gets looking at a nice ex girlfriend after she dumped you.
So pleased you got that sorted too.
I think in a weird way, your Deliboy and my S10 both got the right keepers and carers.
Apr 14, 2021 15:25:52 GMT
I click on this thread just have a random grin and a feeling like one gets looking at a nice ex girlfriend after she dumped you. So pleased you got that sorted too. I think in a weird way, your Deliboy and my S10 both got the right keepers and carers. Cheers Grizz! I think you may be right, but most of the time I'm the one who needs a carer... In completely unrelated news, I've changed back to the glow-in-the-dark gearknob. The faux carbonfibre one is cool, but being a solid ball of aluminium means that it's a little too heavy, and exaggerates the rattles from the column shift. The glowy one is larger, but plastic and hence lighter.
I had planned to do some things on the van yesterday, but realised that I might not feel up to it after my vaccination first thing in the morning, so pulled ahead to Saturday. A very high quality horn has arrived on a slow boat from China. I did some quick comparisons with the current horn and concluded that the new one is slightly louder, slightly higher-pitched, and significantly more golder. The new horn is also slightly larger, so a gentle massaging of it's bracket was required to help it to fit behind the grille. While that faffing was going on, I also changed the engine oil. It's only 5000km since it was last done, but the colour of the oil was pretty dark. Much like my first car (a classic Mini), I decided to change the oil based on condition/appearance rather than sticking to a rigid time/mileage interval. The Deliboy works it's oil pretty hard, mainly because I haven't used it for local urban delivery runs, but rather long adventures including lots of hours cruising at dual carriageway speeds. Ridiculous, really, considering the Lexus is far better suited to such journeys. The great thing about the Deliboy (and the RAV4 which preceded it) is that you don't have to lift it off the ground or remove anything to change the oil. Just slide the oil catcher underneath and loosen the sump bolt. The lowest part of the sump is handily placed at the front of the engine, so it's the easiest change I've ever done. 3 litres of 10W/40 later, and it was good to go again. I didn't feel too bad after the vaccination yesterday, so treated the van to a quick wash at the local jet wash place and went out for a meander around the local countryside. I don't think I was mistaken for an ice cream van, but plenty of people were pointing and staring. The next big outing will be to Caffeine and Machine next Sunday morning, as part of their Daikoku Weekender. Should be fun if the weather holds.
Apr 26, 2021 12:00:13 GMT
Production of the Deliboy was never in big quantities, and finished in 1995, but there is still a small group of enthusiasts in Japan who modify them and look to produce new parts and accessories. My new friend Takuya works at a custom shop near Nagasaki, and he decided that a new Deliboy-inspired leather keyring was required to promote the business and sell to like-minded Deliboy fans across Japan. A small batch was made up and started selling quickly. Of course, as soon as I saw it on Instagram I had to get in touch. I persuaded Tak to get a Paypal account so I could pay him, and then just had to wait... On Saturday, a small parcel arrived, and these were the contents: Tak was kind enough to include a bonus keyring and a sticker in Japanese, which he thought was very funny. I knew what it was for, but I still used Google Lens to translate it: With my Deliboy key attached, I took the van out to the Daikoku Weekender Japanese-themed event at Caffeine & Machine yesterday, and got to watch the confused people trying to figure out what it was. On the way home, I stopped for another photo in an appropriate location (an industrial estate in Wellingborough). A successful weekend, by all accounts. This morning, my friendly local Parcel Force delivery driver dropped off a large box from Japan. I had been idly browsing the Yahoo Japan Auctions site for Deliboy bits, and found a couple of useful items. As you may remember, the wiper arms on the Deliboy are a bit of a mixture, and original Toyota items are NLA. I found a used pair on Yahoo which had received a rattle-can restoration, so quickly decided to snap them up. In addition, I wanted an instrument hood, in case my installation of a rev counter (which I will get around to at some point in the future) makes a mess of the current one. The sellers on Yahoo Japan Auctions aren't really set up for posting things out of the country, so I re-activated my From Japan membership. They are a forwarding company which buys items on behalf of foreigners/aliens, collates them and then posts overseas. Not very cheap, but extremely convenient. The parts arrived today, and I'm pleased. The seller of the wiper arms was kind enough to include brand new 'View' wiper blades, and the instrument hood will be just fine for the job once it receives a little paint (it's a little blotchy and faded from exposure to the sun). I'll store that as it is for now.
Apr 27, 2021 19:29:09 GMT
Well,
Every time I check in, you make me smile.
This car has so found the right owner.
Love the bits you have managed to find.
And the way you know your way around to maximise everything relating to this car.......
Brilliant.
The excitement almost never stops. I decided last week that it was about time I obtained a spare wheel, just in case. The cradle which should hold one is empty. I was trying to figure out how to solve this dilemma when I remembered that the steelies I bought for the van are from a Toyota Auris (same PCD, centre bore, and almost exactly the right offset). It therefore seemed reasonable to purchase a spare from the same vehicle. Onto eBay and before I knew it a second hand but unused spare was winging it's way to me from Shropshire. According to the advert, it could come in orange, black, blue or yellow. Purely by chance, it arrived in an appropriate colour: Initially, I just slung it in the back, as there was just enough space for it: On Sunday, I decided to find out whether the rusty-looking spare wheel carrier system was still operation. I assembled the lever and popped open the mystery hole in the side of the van to poke the hook into and start turning. Of course it still works! The chain which passed through the mechanism was a lot cleaner and more shiny that the part which was visible in a resting state, and the articulated arm lowered towards the ground. It was then a case of placing the spring-loaded retainer through the centre hole on the wheel and winching it back up to the supporting plate on the underside of the body. Much easier than I was expecting. I'll have to occasionally check that it doesn't work free, but it feels pretty secure. Now I just have to hope that I never have to use it. The other part of my preparedness exercise was to confirm if the bottle jack and other wheel-swapping onboard equipment is still operational. Of course it is. The cardboard box on the left is for the original equipment snowchains (which won't fit over the tyres, but I'm not ever getting rid of them).
Last Edit: May 4, 2021 13:52:28 GMT by Flingstam
May 20, 2021 19:55:00 GMT
I am surprised no parcels have landed recently
Good job, testing the equipment
I am surprised no parcels have landed recently Good job, testing the equipment Hi Rian, No parcels have arrived... for this vehicle. I need to switch attention to the Lexus, which needs a new timing belt and possible a couple of suspension parts to address some rattling from the front end. Hence I've been ordering bits from Rock Auto and Autodoc. The full timing belt kit with water pump, pulleys, tensioner, gaskets, etc. comes in a single box ('cos that's how they do things in the USA), and it only took 3 days to get to me from Kansas City, Missouri. That's without even paying extra for express delivery. I guess FedEx had space on the first available transportation device for each step of the journey, so just slung it on. I'm expecting the seals I've ordered from Germany to take a bit longer, but still slightly less time than from Japan.
I had a relaxed cruise over to Bicester Heritage yesterday for the Sunday edition of the Scramble. An indicated 110kph (GPS-corrected 63mph) seems to be the ideal Deliboy cruising speed. Too long above 70mph and the temperature starts to climb and the engine starts burning a bit of oil. 63mph is just fine. It is a suburban delivery vehicle, after all, and probably never saw more than 50mph during it's service life. I was directed to park with the classics, which led to some interesting combinations of vehicle. I had a great wander around looking at all the cool cars in attendance and the various businesses on site, and chatted to some very nice people. I'm not one for going up to speak to celebrities, but I chatted to Sarah Crabtree off of t'elly (Bangers and Cash) when I was speaking to Popbangcolour artist Ian Cook, and I saw Jimmy De Ville and Jonny Smith were on site. As it happened, Jonny and Jimmy were exploring the car park when I was eating lunch/handfuls of sausage sandwiches, so I took the opportunity to give them a tour. They found the Deliboy quite interesting and entertaining, I think. We were captured by a distant papparazzi at this point: All in all, a grand day out. My feet called time when I'd done 12500 steps, and I cruised on home.
Last Edit: Jun 7, 2021 16:23:15 GMT by Flingstam
1991 Toyota Deliboy fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
Ethan liked the penguin. I saw that the Toyota century had pulled alongside your van before it left too, the owner presumably got a photo of his car next to yours.
Ethan liked the penguin. I saw that the Toyota century had pulled alongside your van before it left too, the owner presumably got a photo of his car next to yours. Ethan is clearly a man of taste and artistic sensibilities. I would have liked to see the Century and Deliboy together. Opposite corners of the Toyota empire.
Looking for another photo, I got to where I was looking at buying this, and the file of photos I had gathered of Deliboys and for a moment regretted not buying it at the time…..
Then instantly realised again, you got the right car, as did I with the S10.
I do hope to randomly be in the same space as your van, in my truck some time.
To me, a head to head or side by side pic would be cool.
As would be, sniffing around it.
Jun 17, 2021 16:23:24 GMT
Looking for another photo, I got to where I was looking at buying this, and the file of photos I had gathered of Deliboys and for a moment regretted not buying it at the time….. Then instantly realised again, you got the right car, as did I with the S10. I do hope to randomly be in the same space as your van, in my truck some time. To me, a head to head or side by side pic would be cool. As would be, sniffing around it. Hi Rian, I'm hoping to get to the RR Gathering in the Deliboy this August, but I'm sure our paths will cross some time.
Jun 18, 2021 11:08:09 GMT
As others put multiple cars in a single thread, I might as well join in... After many months of playing second fiddle to the Deliboy, the Lexus has been working hard this week. On Sunday, I cruised down to the Thruxton Historic Festival to assist Mission Motorsport with the running of the 4x4 experience. It was nice, and some other Japanese cars were in attendance on the race circuit. And some non-Japanese vehicles, including a fabulous tow vehicle or two: And some more Italian cars: On Sunday evening, I trundled over to Billingshurst, and the fabulous Five Oaks Travelodge, which is next to a greasy spoon cafe. This meant that Monday's breakfast looked like this: The main focus of the day was to take the LS to ACE Engineering, so Gareth could engage in some well-needed maintenance. I wanted to take it to someone skilled and trustworthy, and it was convenient as I was down South anyway. Gareth in return trusted me to acquire the necessary parts, which was almost entirely successful. I ordered a new timing belt kit from Rock Auto in the US, as it was far cheaper than any UK or European sources, and included all the necessary parts. I didn't pay extra for fast shipping, but it still took only 3 days for a large box to arrive from Kansas City, Missouri. Inside was the belt, a new water pump in a large aluminium housing, the belt tensioner, idler pulleys, gaskets and O-rings. All for £175. Bargain, frankly. The disassembly was not without it's complications, mainly due to the fact that it's a 23 year old unit which hasn't been taken apart very much. The water circuit on the front of the engine includes a cast aluminium parts which fits tightly into another cast aluminium part with an O-ring between them. The round hole top left of the below image is the socket in question. The tightness of the fit combined with the hardness of an old O-ring made this quite a challenge to remove, particularly as thin-section aluminium castings aren't the most robust of parts. Gareth even got a sweat on, while I stayed at a safe distance (I've found that things can break if I even look at them too intensely). After a long and careful struggle, it was free. There were still parts to remove after I took the photo, and Gareth also cleaned the throttle body while he was there. The rest of that particular job went so well that when I returned from a leisurely lunch (no photos of that) it was all back together and correctly timed up. Gareth finished off the re-assembly and topped up the coolant. I took charge of writing on the sticker and applied it over the previous mechanic's scribble on the engine cover from the last time it was changed. I also wanted Gareth to take a look at the transmission sump and change the ATF filter. I'd ordered another part from Rock Auto for this, but it was the wrong one. I'm going to choose to blame them for this failure. However, as the filter is a stainless steel mesh, it's possible to clean and re-use the old one, and transfer across the new one's cork seals to improve it's fit. There was no visible evidence of anything untoward in the sump (e.g. no shiny shavings on the magnets), so it was thoroughly cleaned and re-assembled with a new gasket. The gearchanges have returned again to silken perfection (they were occasionally a bit snatchy before), so again a job well worth doing, and very much worth paying an expert to do for me. The AT sump is held in place by about 20 randomly-spaced bolts (only one of which snapped) and a large quantity of pink sealant/adhesive. Amateurs have been known to mangle the sump pan during removal and it never seals again. Having watched Gareth do it, I'm pretty sure that I would have turned it into a taco... After leaving Gareth with a supply of biscuits, I took the short trip towards Chichester for another Mission Motorsport event at Goodwood Circuit, taking over the place for the day to enable beneficiaries to get hot laps of the track in a variety of excellent vehicles. I was directing traffic around the paddock, while wearing a hat and Factor 50+ sunscreen and drinking litres of water. It was a bit hot, but a brilliant day. I didn't get out on track (I probably could have, but I didn't really want to jump into a tin box in that heat and sweat on everything), but I did briefly get the chance to drive Alex Goy's Morgan 3-wheeler. Hilarious thing, although the braking performance is a little scary. Here's Ben and Jack checking it out: Once the day was over, I needed to stop by at Halfords in Chichester, as while at Gareth's I noticed that the rubbers holding the exhaust onto the car weren't looking too clever... With a temporary hanger solution applied (I'll have to replace all the rubbers holding the exhaust on when I can get the bits), it was time to cruise home. 2.5 hours passes easily when travelling in the Lexus, and the 300 lb ft of torque came in handy when I needed to overtake a line of traffic following an old truck doing 15mph uphill on a rural road. The Deliboy definitely can't do that...
Jun 18, 2021 11:36:41 GMT
The most exciting reason to be at the Scramble was to purchase a deck of playing cars put together by the team behind Revs Limiter, a Facebook group of like-minded but diverse car enthusiasts led by a Vicar (Adam Gompertz). They are very much like another playing card game whose name I won't mention for legal reasons (but rhymes with Kop Krumps). All the featured vehicles belong to group members, so it made sense to propose one myself. They've only gone and included it in the actual pack... If you would like a set and donate to worthy charities at the same time, you can order from this website: narrativebooks.net/product/top-revs-card-game/
Last Edit: Jun 18, 2021 17:45:38 GMT by Flingstam
