Jun 19, 2020 22:00:39 GMT
Hi,this is my build of my 67 Cortina 2 door.I imported from Finland,so is left hand drive.Have stripped car to bare shell,done any welding needing doing to chassis and floors,which was very little,car is in amazing condition.I am getting rid of the leaf springs and using a four link ive made up with Gaz coilovers,and Ford focus antiroll bar.Have made the gearbox tunnel bigger using a capri tunnel,to except my MT75 gearbox,and fitted a 2.0 l Zetec ,keeping the standard fuel injection.I am using capri front struts with adjustable bottom arms and compression struts,focus front antiroll bar,with escort rack and pinion steering.Have now fitted a right hand drive dash,and moved pedal box (which is a bias adjustable box) Thats all for now,cheers
Nice mk2. The Scandinavian shells are a lot better starting point than the UK ones when it comes to rust. I’ll be following this build.
Yeah,apparently the cars that come from the north of Finland are the most rust free,as they don’t salt the roads,because the raindeer come out of the forest to lick the salt off the road and cause Accidents😂
Jun 20, 2020 12:38:50 GMT
Nice Cortina Dunk
Jun 20, 2020 14:20:18 GMT
Hi Paul,hows it going,hows ya moggy,I'm getting bored as you can tell,no shows,no drag racing,even my cat looks at me like...go on p#*s off out for a while,😂😂
Last Edit: Jun 20, 2020 14:21:41 GMT by 58moggy
Jun 20, 2020 16:36:21 GMT
Dunk Iam that bored I've got my dragbike running again after 8 years Moggy needs a couple of jobs but nothing I can't do over a weekend
Jun 25, 2020 18:05:20 GMT
Got the bottom of car finnished at last,painted with corrosion converter then primed,seam sealed,painted with black chassis paint then sprayed with black stone chip K
Last Edit: Jun 25, 2020 18:07:20 GMT by 58moggy
Jun 25, 2020 18:24:36 GMT
That is in very good condition. Looks like your using compression struts on the front.
Jun 25, 2020 20:03:44 GMT
Yeah compression struts on front,I bought some for a escort mk2,and had the centre tube made longer to suit the cortina
teaboy
Make tea, not war.
Jun 26, 2020 21:11:36 GMT
What size is that rear anti roll bar? It looks huge. I think it will oversteer like a pig with that on.
Car looks mint by the way.
Jun 29, 2020 21:35:07 GMT
It’s a standard focus rear anti roll bar,it’s hollow tube so not to stiff.
Jul 12, 2020 14:47:03 GMT
WANTED Hi anyone got a rear seat ,back section,for Cortina mk2,series 1,2door,in black for sale.
Nov 20, 2021 10:46:39 GMT
Nov 20, 2021 11:13:14 GMT
Amazing work.
I was just showing Sally the underside work, saying that is madness doing that sort of work, then she reminded me, that I did it with the C10 as well, complete chassis strip down and cab off work.
One forgets soon the hard work that goes in.
Looking forward to the progress you make over winter.
1967 Ford Cortina 1600 Deluxe peteh1969
@peteh1969
Club Retro Rides Member 107
Nov 20, 2021 11:25:10 GMT
Great work nice subtle mods will be nice when done.
Can I ask will you be fitting a strut brace across the rear top shocker mounts or have you already re enforced that area to save you punching through or deforming the rear tubs now you have ditched the leaf springs for Coil overs?
Nov 20, 2021 12:06:04 GMT
Keep up the great work Dunk
bazzateer
Imping along sans Vogue
Nov 20, 2021 21:39:33 GMT
I love this kind of build!👍
v8ian
Nov 20, 2021 23:29:50 GMT
When I built my mk2, I made a strut brace that obviously tied the top of the strut towers, but the brace went back towards the centre of the heater bowl, mounted to a plate bolted thru the said heater bowl, I was really impressed with how it stiffened up the front end
