Nov 30, 2021 18:30:48 GMT
Great work nice subtle mods will be nice when done. Can I ask will you be fitting a strut brace across the rear top shocker mounts or have you already re enforced that area to save you punching through or deforming the rear tubs now you have ditched the leaf springs for Coil overs?
Nov 30, 2021 18:32:45 GMT
Yeah i will be making a rear strut brace,also i fully welded the rear tubs so way stronger than the standard spot welds
v8ian
Nov 30, 2021 20:35:50 GMT
Yeah i will be making a rear srut brace,also i fully welded the rear tubs so way stronger than the standard spot welds I trimmed the edge right back and seam welded the inner and outers to each other, I could get 8s on the back with 235 55 15s still with leaf springs
Nov 17, 2023 13:22:38 GMT
Love what you've done, I'm just about to RHD my two door, what did you find the best way to get the pedal box mounts in the right place
Nov 17, 2023 15:33:37 GMT
This is my RHD mk2. If your upper bulkhead is the same as mine, the dimple for the the standard pedal box is on both sides. Drill that out so you can then mark the other mounting holes
Nov 17, 2023 18:04:18 GMT
Beautiful car, I loved my 1600E but, being honest, I'd love to do similar to your amazing work on a 2 door Mk1 Cortina, Bookmarked and looking forward to seeing future updates, Nigel
