Sept 26, 2024 10:20:51 GMT
My bug has been in my possession for 28 years now. Used her to go shopping last week and she decided to drop a load of oil from the rocker cover on the drivers side. Seems the cheap no brand cork gaskets from ebay were a lot thinner than the ones i've used before. New rocker covers bought (the ones on may have been the originals and were rather pock marked with rust) and a handful of new elring gaskets.
Oct 14, 2024 20:30:09 GMT
Been using my bug as my daily for the past few days as my caravelle broke a water hose connector so I had to order a replacement. Have you ever seen those Russian videos of a cow being transported in the back of a Lada? Well thats what its like having Lucy in the beetle.
Last Edit: Oct 14, 2024 20:31:18 GMT by Zebedee
Oct 14, 2024 20:43:17 GMT
Been fun hooning around the last couple of days. Made a change rather than driving my caravelle. My dogs even started to settle down a bit once they'd got use to the noisy exhaust. Fitted new rocker covers, elring cork gaskets and bent the bales a bit to give a bit more tension on the covers but still got a leak from one corner of one cover. 🙄 Removed and resealed it 3 times and bend the bale a bit more before it stopped leaking. The other sides cover now has a slight drip of oil leaking from it. Looks like I'll have to bend the bale a bit more.
Ratchet
The user formerly known as Thomas
Oct 20, 2024 20:47:28 GMT
Been fun hooning around the last couple of days. Made a change rather than driving my caravelle. My dogs even started to settle down a bit once they'd got use to the noisy exhaust. Fitted new rocker covers, elring cork gaskets and bent the bales a bit to give a bit more tension on the covers but still got a leak from one corner of one cover. 🙄 Removed and resealed it 3 times and bend the bale a bit more before it stopped leaking. The other sides cover now has a slight drip of oil leaking from it. Looks like I'll have to bend the bale a bit more. are you still using the original OEM clips/bales?, as i seem to remember aftermarket ones could be somewhat out of tolerance,(as in sometimes to overlong they could never clamp down hard enough to seal. i suspect parts QC hasnt improved since the mid 00s :I
Competition is the law of the jungle, but cooperation is the law of civilization.
1971 vw beetle 1200 1978 international loadstar 1700 4x4 1987 landrover 110 1994 Yamaha FZR600r 2010 honda CBF1000GT
Oct 21, 2024 17:37:04 GMT
Yeah, they're still the original bales. I used aftermarket ones on my bay window years ago and the rocker covers constantly leaked. Swapped to some original bales i got secondhand and it stopped leaking.
