Aug 11, 2020 13:00:38 GMT |
So, the lack of a builder broke me, and I decided to have a crack at progressing the walls myself. I'm no brickie but have turned this into this and this into this Walls are solid and level, run between beams keeps all true(ish),tied to the steel every 2nd course. I think I am quite happy with it and will continue with the build myself. I will engage the services of a pro again to render the walls when the time comes.
Aug 11, 2020 16:34:25 GMT |
Not bad at all for a beginner.
Aug 11, 2020 22:23:25 GMT |
Cheers, the pro did the hard work by starting the walls off though. Hopefully I can continue them to eaves in a similar manner.
Aug 11, 2020 22:25:52 GMT |
Anyway no real progress this evening, just erected the scaffold and loaded a few blocks onto it ready for the next episode.
Aug 11, 2020 23:11:25 GMT |
Looks good.
The first time I had to do anything like that was a small kitchen extension - in natural stone. Took forever but turned out okay well, at least wonky was expected!
Aug 13, 2020 16:42:10 GMT |
Its coming on now, looks like your trying to point the blocks up too quickly, let the mortar ooze out and leave it to dry off a bit, the beds a bit thick so find a big bit of hose pipe to point it up and then brush it off after
If your struggling for trades why not batten and clad the outside with feather edge or similar you would cover the steel uprights as well?
Aug 13, 2020 17:33:23 GMT |
You are correct I am pointing it immediately after squaring up the block. I will try leaving it a while before pointing to settle. My 1st builder reckoned he could fit mesh over the beams and then plaster and harl right over it. I am only blocking to the eaves anyway then timber to the peak so a full on timber clad would look quite good too.
The Lockdown Lockupglenanderson
@glenanderson
Club Retro Rides Member 64
Aug 13, 2020 20:47:13 GMT |
The profiled concrete weatherboard you can get is low maintenance and looks really traditional. The other good thing about it is that you can do it in stages as time and budget permit.
Aug 13, 2020 21:30:27 GMT |
Every day is a school day Didn’t know such a product existed How does it compare to timber cost wise?
@glenanderson
Aug 13, 2020 23:14:41 GMT |
Dearer, but not much once you’ve factored in painting it. Cheaper by far in the long run.
Harling remains my preference but if I struggle to get someone to do it, will certainly look into the concrete weatherboard re
Aug 15, 2020 16:06:03 GMT |
Personally I hate any type of render with a passion, it will crack especially if your going over the wide steels with mesh, it needs painting which is a pain when its rough cast, even when it is painted it gets grubby quickly and it holds the damp
After coming from our previous property which was rendered we vowed never to have another rendered house, apart from the one we replaced it with!! difference is this one has barns/outbuildings and land so the house was a bonus regardless of finish!
Aug 15, 2020 18:39:12 GMT |
hmm, My house was built in 2005 and the harling doesnt look grubby, it has never been painted either
Sept 1, 2020 17:51:57 GMT |
Some more blockwork progress has been made. Office window lintol rigged up ready to hoist in place. Lintol in and blockwork completed above More walls up to finished height 2 course left on the office front wall to complete Other small front wall just started off, pipe penetration for floor drain and cable entries. I can see the light at the end of the blockwork tunnel now, just the small front walls to complete and 5 course on the other side wall. A decent weekend should see that done. Unfortunately the blockwork tunnel will then be replaced with a roofing tunnel followed by a concrete floor tunnel. Nights are beginning to draw in now though and my working time in the evening is being restricted, having to down tools around 9pm now, was still going strong at 10:30 when I began. I am Offshore just now for 10 days also and the good lady wants to have a long weekend away when I get back, so wont be doing anything in anger for a fortnight or so
Sept 1, 2020 19:49:49 GMT |
It's coming on well now, shame the light is going before you get a roof on it.
Sept 1, 2020 20:40:35 GMT |
Have floodlights, will illuminate
Not sure if I have mentioned it earlier in the thread but apart from a new office for working at home and a place to store my Scimitar the garage's other main use will be for the storage of my caravan over winter. Unfortunately my caravan is a shade too long for the garage, i was looking to replace the caravan however so wasn't too concerned by that, Id just make sure the new one fitted the shed, right? Wrong, I bought another caravan that is 8.25m from its extremities and the garage internal dimensions is a little under 8m. I think I have hatched a plan so cunning you could pin a tail on it and call it a fox. In my minde eye it works but not sure in reality and it may not be the prettiest thing, but bear with me. If I back the caravan right in to the wall then drop the nose as low as I can get away with, my thoughts are then to frame this out to a level just above the drawbar therefore allowing the roller door to rest upon the frame and close the garage up. When the caravan is out from March to November the frame will be removed and the roller door will close normally. Obviously the frame will be of a similar material to the door to match in as much as is possible, might not be the ideal solution but its a solution, open to other thoughts though, so fire away. See sketch below for a visualised idea of my thinking.
@glenanderson
You might get 250mm or so by unbolting the hitch. Some caravans can even have their A-frames unbolted; if yours can, happy days.
yes, I havent checked out the potential to unbolt the drawbar. Could be a goer. From looking at the sketch (roughly to scale) there may also be the potential to slew the van on the angle and get the door down.
@glenanderson
Either that, or back it in a bit quick a couple of times until you can get the door down. 😉
