The track season has come to an end. I raced for the first time this year doing two double headers in the Castle Combe Hot Hatch Series. I used a Civic Ek firstly with a B16A lump and then with a built B18 engine. We managed 4 class podiums and a best of 6 out of 30 cars. Having done surprisingly well we decided we will drop the current engine into a lighter earlier Civic EF for the 2020 season.
I will drop the planned spec here and will update as we get deeper into the build. Its an 88' Civic Import shell.
Spec:
- B18C 1798cc Vtec (rebuild 2018 220bhp)
- P28 ECU with Hondata S300
- King Racing Shells & Bearings
- B18C Pistons
- Uprated Conrods
- Uprated Cams
- Uprated Valves
- Uprated Valve Springs
- Edelbrock Performer Inlet Manifold
- Unknown 70mm Throttle Body
- Ramair Airfilter
- TB Industries Engine Loom
- Bosch 044 Inline Fuel Pump
- Bosch Mechanical Lift Pump
- OBP Swirl Pot
- Teflon Braided fuel Lines
- NGK Iridium Spark Plugs
- Baffled Sump
- Innovative Engine Mounts
- Billet 2 post engine mount
- Tegiwa Large Bore stainless exhaust manifold
- 2.5” Side Exit Exhaust System
- Unknown Uprated Helical LSD
- Unknown Race gear set uprated box
- RPC Lightweight flywheel
- Tegiwa Ally Half Radiator
- Mocul 13 Row Oil Cooler
- Mocul oil Sandwich Plate
- BC BR-RH 14/12 Coilovers
- 4x100 EF GL Hubs Front
- EK4 VTi Rear Trailing Arms/Hubs
- Skunk2 Front Roll Centre Adjusters
- Hardrace Front Upper Camber Arms
- Hardrace Rear Toe Arms
- Hardrace Rear Camber Arms
- Hardrace Rear Trailing Arm Bushes
- Superflex Control Arm Bushes
- Ultra Racing 22mm Front ARB
- Ultra Racing 19mm Rear ARB
- Skunk 2 Rear LCA’s (EG)
- EK4 VTi 242 Rear brakes
- Hel Braided Brake Lines
- Hel Braided Clutch Lines
- Manual Rack Piston Removed
- Ep3 Type R front brakes (280mm)
- Project MU Pads
- SHJDM J Hook Discs
- TD 1.2’s 15” 7J ET40
- Must Weld Motorpsort Weld in Roll Cage
- Sparco Steering Wheel
- SPA Fire Plumbed in Extinguisher
- TRS Harness
- Cobra Wrap Around GRP Seat
- Carbeau Alloy Side Mounts
- Prodrive Carbon Dash
- Oil Temp & Pressure Gauges
- Race Switch Panel
- TB Industries Interior Loom
- Wilwood Bias Valve
- Carbon Roof Bung
- Import Rear Lights
- Import Rear Bumper
- Import Front Bumper
- New Fuel Tank
- ACW Motorsport Plastics Windows
- Custom Tubular Front End
- Aero Catches
- Quick Release Boot
