Apr 13, 2020 23:24:13 GMT
Can you tell us more about the carb's dampening?
More importantly, did you guys escape the heavy weather today? Even up here in New England, the winds were > 60 mph.
Best, John
Apr 13, 2020 23:35:10 GMT
Weather was pleasant today. The big line of frontal storms skipped past us by about 30 miles to the north. It was a bit windy and rained for about a minute. The needles system is remarkably simple. There is a loosely coupled T bar, with the bottom of the bar attached to a spring loaded plunger. The plunger is pulled against the spring by manifold vacuum, which pulls the needles in and closes the apertures. The leaning off is simply damped on way by a ball bearing against a split hole- when against the hole like a one way valve the vacuum can only draw the needles in slowly so the mixture becomes lean slowly. The needles can also be pulled upwards sharply by the same mechanism that operates the accelerator pump, and then the plunger can catch up if required. Very simple damping of the enrichment. Phil
Apr 19, 2020 22:45:10 GMT
Auto choke was set just a shade rich. Since adjusted. Also tidied the bench. Good enough for today Phil
Apr 30, 2020 18:56:41 GMT
Just sent my wiper motor off for rebuild.
Apr 30, 2020 19:08:20 GMT
Good to see a post Phil. John
Apr 30, 2020 23:06:01 GMT
Sent the heater valve off for rebuild also.
Phil
Sent the heater valve off for rebuild also. Phil wow, something you have decided to send out for service? it must be very difficult to fix DIY, then.... JP
Sent the heater valve off for rebuild also. Phil wow, something you have decided to send out for service? it must be very difficult to fix DIY, then.... JP It's a piece of spring loaded thermostatically sprung nonsense that requires special tools to pull apart and the correct rubber boots to reassemble and not have leak. Rebuild cost was reasonable and the guy's been doing them for 30 years. Ditto the wiper motor. Kits used to be available. Said hell with it and sent it off too. I tried fixing it but it needs new parts that they won't sell independently. Phil
You earned these little luxuries when you mastered that transmission. John
totti
Yes,thats a good decision....i tried to repair the Trico wiper unit from my Volvo 4 years ago....no chance!
Find no spares or somebody who overhaul them...
Now i have a electrical Bosch unit....
Greet
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
Yes,thats a good decision....i tried to repair the Trico wiper unit from my Volvo 4 years ago....no chance! Find no spares or somebody who overhaul them... Now i have a electrical Bosch unit.... Greet Ficken Wiper Service. rebuildingtricowipers.com/what-we-rebuild
Phone call this afternoon. Wiper motor is rebuilt and on its way back.
The case was bent, guy said looks like someone had dropped it so he changed the case for a new old stock one. That explains why it would get hung up in the middle of the screen.
Phil
May 12, 2020 22:38:37 GMT
Much wiper, so wow
1951 Pontiac Chieftainglenanderson
@glenanderson
Club Retro Rides Member 64
May 12, 2020 22:53:08 GMT
That’s great. Definitely a worthwhile thing to get done.
May 12, 2020 23:10:07 GMT
That’s great. Definitely a worthwhile thing to get done. Absolutely. It's taken them from useless to slightly crappy, which is about as good as vacuum wipers get. Phil
I'll call it character. John
Wooo happy clappy!!
ovimor
North East
...It'll be ME!
May 13, 2020 15:43:57 GMT
This youtuber suffered AMC 'vac wiper blues'... Abandoned AMC Hornets Junkyard rescue.... Quick..SlowSlowSloww OVIMOR
Knowledge is to know a Tomato is a 'fruit' - Wisdom, on the other hand, is knowing not to put it in a 'fruit salad'!
May 13, 2020 16:01:13 GMT
Phil, this may be a goofy question, but what would it cost to put A/C in that car? Are there any reasonably priced kits? John
