On a slight tangent I now have a new carburetor, which is a lot less sloppy and slack than the one on the car right now. It needs a jolly good clean though. Phil
For the love of God man, get that off the table before the wife sees it...
It's completely dry. It was removed from a running car about 40 years ago... I'm guessing a scrapyard pull. It's remarkably good under the dirt.
Phil
Just put the accelerator pump top cap in the ultrasound bath for a while. Came up nice. Hopefully the rest of the carb will come up well also. Phil
Arses. I put the small stuff in a plastic pot with solvent, then that in water in the machine. Pop, the heat made it open. Oh well. Stuffed the choke assembly in seeing as the water is dirty now Phil
Spot the piece that I cleaned Phil
tristanh
Routinely bewildered
Looks like it will clean up great.
It's surprisingly clean inside. Phil
Yeah, that surprised me. The engine it came off was a heavy breather though, the choke mechanism was sooted up solid. Phil
Making some progress. Phil
looking good. Nice to find a unit like that that is actually clean inside.
JP
Looking at that lovely float, you realize there must have been vast rooms full of people soldering such pieces together. John
Looking at that lovely float, you realize there must have been vast rooms full of people soldering such pieces together. John Yup, and hammering in the little lead plugs. It's all quite intricate for a mid 40's design. It just doesn't have damped needles like an SU. Phil
Wait no. I'm wrong. It is damped, and in quite a clever way, too.
Last Edit: Apr 8, 2020 3:55:50 GMT by PhilA
Cleaned up ok.
Apr 12, 2020 23:59:40 GMT
Bolted the new carb on tonight. Don't be so mean! (You break it, you buy it!) I think that one can stay
Apr 13, 2020 21:03:44 GMT
I stand by my original statement: Morris Minor on steroids.
