Frankenhealey
Club RR Member Number: 15
1951 Pontiac ChieftainFrankenhealey
@frankenhealey
Club Retro Rides Member 15
Apr 16, 2022 21:06:44 GMT
Out and about today, car broke down. Started running real rough, managed to nurse it a ways out to Auto Zone. Popped the hood, liked to lose my fingerprints on the coil. Bought a new coil, fittes it in the parking lot and carried on. Old cars aren't so bad all the time. Yay! I'll take it off your hands
Apr 16, 2022 21:40:58 GMT
Yay! I'll take it off your hands Couldn't give you something broken. Checked the plugs, all are a nice sienna color. Regapped them all. Cleaned and gapped the points, 16 thou', test drive successful. Smooth! Phil
Last Edit: Apr 16, 2022 21:41:24 GMT by PhilA
cut the old coil up phil ? see what happened inside .
Contact less ign upgrade Phil?
cut the old coil up phil ? see what happened inside . It had been getting progressively worse, the tach was randomly flicking as I was driving. It was hot so the insulation had broken down. New coil runs at the same temperature as the engine bay. Phil
Contact less ign upgrade Phil? Thought about it, decided no- I like the twin points setup. If one fails it'll stay running but it does give you a warning it's happening, you feel the timing changing randomly. I like the simplicity, it's reliable enough. Edit: Went check and most contactless points systems won't go as low as this one idles.
Last Edit: Apr 17, 2022 14:08:29 GMT by PhilA
Frankenhealey
@frankenhealey
Apr 17, 2022 20:22:06 GMT
Yay! I'll take it off your hands Couldn't give you something broken. Phil I share your pain. Tried to start the Goddess today. Freshly charged truck battery, new battery clamps. Half a rev and the solenoid does one Grandson was not impressed that no Cummins 'shops' were open on Easter Sunday.
I share your pain. Tried to start the Goddess today. Freshly charged truck battery, new battery clamps. Half a rev and the solenoid does one Grandson was not impressed that no Cummins 'shops' were open on Easter Sunday. You could always buy a $55 bag of oranges down the market and get a free solenoid thrown in. I took the kids to go rollerblade at the park today. Surprisingly, the car behaved almost flawlessly. Phil
Apr 18, 2022 19:15:18 GMT
Invisible* repair time. Hood got a few ripples, light skim of filler now should see that right. Roof still needs work, but is less conspicuous. Ten minutes' work in the sun, I had shredded my arm on the headliner clips and that was enough. Phil
Last Edit: Apr 18, 2022 19:15:30 GMT by PhilA
Quickly washed the car. It's Thursday. Chocolate malt time!
Tweaked the timing a touch. Fixed headlight connector which had fallen apart (rusty spring clip). Plugs look good and the car is really happy now at 2000 RPM (45 mph). That's good.
Frankenhealey
@frankenhealey
Apr 23, 2022 11:52:56 GMT
Quickly washed the car. It's Thursday. Chocolate malt time! Phil, We need a picture of the Chieftain with a 50's car hop on roller skates when you go out for a chocolate milk
Apr 23, 2022 20:37:39 GMT
Quickly washed the car. It's Thursday. Chocolate malt time! Phil, We need a picture of the Chieftain with a 50's car hop on roller skates when you go out for a chocolate milk Sadly there are very few places that still do that, let alone entertain the concept. It's considered rather un-PC here these days. That and you cannot really clip a tray to a modern's glass.
Some housekeeping tonight. Checked the vacuum advance module still works. Tweaked the timing slightly because hot it was pinking at low revs under heavy throttle. Lubricated all the linkages and carburetor. Cleaned the screen wash bottle and filled it up. Now I want an orange soda. Fixed the low note horn too, the points needed cleaning and adjusting. Better now. Even bought a new magic tree. Phil
Frankenhealey
@frankenhealey
Even bought a new magic tree. Phil The Magic Tree will make everything better. It's the law
Apr 27, 2022 12:04:37 GMT
Cleaned the loom smoke bottle and filled it up. Phil corrected that
Apr 27, 2022 17:51:01 GMT
The Magic Tree will make everything better. It's the law "Sunset Beach", smells like a boudoir.
jamesd1972
Club RR Member Number: 40
1951 Pontiac Chieftainjamesd1972
@jamesd1972
Club Retro Rides Member 40
Apr 27, 2022 17:51:43 GMT
The Magic Tree will make everything better. It's the law "Sunset Beach", smells like a boudoir. Sounds good to me ! James
nze12
1986 BMW E30 refreshed to original spec 1973 BMW E12 520 converting to Motorsport 530 1982 XJS V12 converting to 5 speed manual
Many landscaping projects overriding above!
Cogito cogito ergo cogito sum!
Contact less ign upgrade Phil? I tell you what, a bit of a Covid scare and everything has to go contactless! Really glad to see the big Chief getting some love again
