I’ve calmed down now!
So, the car’s wing is on hold because the decking arrived.
The decking is on hold because something else cropped up.
Something else will be on hole because….
And so on and so forth…
It’s just how it is at the moment.
In amongst which I fixed the pump in the rain water tank. Remember the old one got water in the bits that were supposed to be dry?
The new pump arrived.
It’s got a bit more grunt than the old one. Intentionally. The old one was a bit wimpy.
I ran a quick test in the outside sink. Two or three inches of water in the bottom. Here’s a video. (In the second part it’s been installed in the tank.)
For comparison I should say that the old pump in the same situation would get 6 or 8 inches of height and splash your shoes. This one can water the neighbours garden without much bother.
Mrs Sweetpea is ecstatic apart from getting blown across the garden every time she squeezes the trigger on the hose. The butler has to send the virile young footman to hold her from behind while watering the garden these days. Mrs Sweetpea is doing a lot of watering suddenly. Apparently the pots are quite dry…
All was well for a week or so until it lost pressure and there was a ’squirting noise’ from the tank. Got a leak then…
There is a piece of convoluted ‘pond hose’ stuff from the pump to the top of the tank where it connects to standard water pipe. Well the pond hose had split at the top. So I cut a bit off the end and reconnected it.
Turned on the power… The pump jumped into life… And immediately burst the pipe at the pump end.
To be fair the pipe is quite old and it does go stiff and brittle. I had a new bit so I replaced it.
Turned on the pump and grinned the grin of success. Er. No.
Actually I went wide eyed in shock as the pipe increased in length by a quarter, bulged alarmingly and then ruptured at the top.
This pump appears to have some serious urge.
It’s also now got plastic SpeedFit pipe all the way from the pump body. Blow a hole in that yer git!
James
James
