Jun 23, 2020 17:00:53 GMT
"You've ruined that!" Talk to my wife! If she likes it, tough! Are you having uplighters in your decking James ? Well we are wondering about that. We have a stand dangly candle thing which I converted to LED (it's probably in this thread somewhere) which provides general illumination. And lights pointing randomly upwards feel a bit nutty to me. They need to shine some light on a thing to look their best not just light the bottom of passing airplanes. However there will be a step between the upper and lower deck and it's likely that well use some there to shine across the bottom deck. There will also be a short fence thing with some newel posts and Mrs Sweetpea would like to stick some form of light on the top of them. Me - not so sure. But that might be because I don't want to try and hide the wires!
Jun 23, 2020 18:45:40 GMT
Actually there is another reason for not having lights in the decking...
When I made the original deck I paid no attention to where I put the noggins. Are they called noggins in a floor structure? They are in a wall but I'm not sure about a floor. Hmmm. Tell you what, for fear of calling them by the wrong name, lets agree to call them "Rodgers" instead.
So I slapped the Rodgers in randomly. I think every last one showed through the gaps between the boards. For some reason it's annoyed me for 10 or 12 years or however long it's been down. This time I was determined to hide all the Rodgers under the boards and working out where to position them has made my head spin.
Trying to position the structure to avoid lighting as well would drive me potty!
Jun 26, 2020 10:26:49 GMT
Coming to a thread near you soon... The hole in the floor is actually a rain water storage tank. Anyway we don't use the tank anymore. When we built the extension we got two proper tanks for rain water storage. So the big tanks have a submersible pump that feeds a hose pipe that Mrs Sweetpea waters the garden with. It's not quick but it works perfectly well. Last night Mrs Sweetpea was finishing the garden, don't know why 'cos it chucked it down in the night, when the pump shut off and the water stopped. It's tripped out the RCD that feeds it. And it won't now run without tripping the RCD. So it has an earth fault. I expect it's got water in it. Looks like I'll be pulling the pump out and seeing if it's possible to fix it or if it's toast. Hmmm. More work for Mrs Sweetpea.
Jun 27, 2020 22:02:00 GMT
Predictably the submersible pump had water in the bit that was supposed to be dry. The water seal on the bottom of the motor has cut into the shaft and that’s allowed water in.  The top bearing is as rough as a badgers botty too. Actually I’ve never fondled a badgers botty so I’m just assuming that the common wisdom is true. So the pump is toast. It’s a Clark Hippo…  …and it’s been in the bottom of the tank for 12 years or more so I can’t complain. I’ve repacked the bottom seal with grease and it’s back in the tank. That’ll keep it running for another week or so until I can order another pump. In other news work on the decking frame continues.  My hair really is more Ken Dodd than sexy bloke about town. Progress has been a bit slow because I’ve been melting as soon as I do anything, and today it’s rained at inconvenient moments.  Anyway, it’s down now and little cement footings installed to stop it moving.  The little retaining wall has been backfilled too. If you are lucky in the next instalment I’ll tell you why I was crawling under the house messing with wires, and I might even tell you what the little black ‘things’ in the last post are for. And if I’m lucky I might get a pile of the actual decking down. James
Jun 28, 2020 20:32:43 GMT
Wires under the floor. Mrs Sweetpea wants outdoor speakers. She’s wanted outdoor speakers for years but obviously it’s completely impossible. Well it was until I ran out of birthday present ideas (again) and it suddenly became possible. Just an unpleasant job. There is an amp in the living room that can run speakers in two zones. With different sound on each if you want it. So the second zone is to be “outside” and I just needed to get some wires out of the house. Luckily there is a a way to do this. It just means running speaker wires through a pipe I’d installed years ago but it was still an unpleasant job being in the crawl space under the floor. The wires eventually wind up under the decking.  From where they (will, eventually) branch off to a few places in the garden. I had some of these totally disastrous lighting loop in boxes hanging around. I hate the useless things but under the decking, protected from rain, they’ll be ok for speaker wires. And, at least the’ll get used. I totally refuse to put mains through them. (Because they are useless. Did I mention that?) Remember the black things I mentioned dangling from the ladder in a previous post?  They mount some Neutrik Speakon connectors into a standard waterproof 13 amp box. There’ll be 3 of these around the garden. One on the decking, one on the other side of the garden, and one by the swing bench at the back. There are 2 pairs of weather proof speakers.  One pair will be permanently mounted in the roof over the swing bench. The other pair can be on the decking or in the garden. Wherever you want to party. Simply plug into a convenient outlet and enjoy the sounds.  Clearly turning them up and down or choosing different music is going to be inconvenient. You’d have to put down your Babycham, wonder into the living room and make the appropriate adjustment. I suppose if one had one’s mobile phone, one could call the butler… Well, as it happens the amp has an app that runs on a tablet to remote control it.  So you just take that down the garden and Bob’s a close relation. Nice! Oh and I’ve also started cutting the decking boards. The fiddly ones round the edges. But wood work is boring compared to music so no photos. James
All clever stuff!
James - You have gone up the list in my estimation since we last met / spoke in person (probably 30 years or so ago) - reasoning being - excellent choice of music (or was that just the first thing that came up on a unselected not of your choice random playlist - if so I'll have to downrate you) Still I have to give you credit where its due - just imagine sat on the swing bench without a care in the world - speakers plugged in and 'Blue Oyster Cult' blearing out 'Don't fear the Reaper'
Last Edit: Jun 29, 2020 8:00:48 GMT by Deleted
James - You have gone up the list in my estimation since we last met / spoke in person (probably 30 years or so ago) - reasoning being - excellent choice of music (or was that just the first thing that came up on a unselected not of your choice random playlist - if so I'll have to downrate you) Still I have to give you credit where its due - just imagine sat on the swing bench without a care in the world - speakers plugged in and 'Blue Oyster Cult' blearing out 'Don't feel the Reaper' While feeling a Reaper isnt reccomended either i think you meant "don't fear the Reaper"
James - You have gone up the list in my estimation since we last met / spoke in person (probably 30 years or so ago) - reasoning being - excellent choice of music (or was that just the first thing that came up on a unselected not of your choice random playlist - if so I'll have to downrate you) Still I have to give you credit where its due - just imagine sat on the swing bench without a care in the world - speakers plugged in and 'Blue Oyster Cult' blearing out 'Don't feel the Reaper' While feeling a Reaper isnt reccomended either i think you meant "don't fear the Reaper" Bloody auto correct keyboards - now edited
Jun 29, 2020 13:30:13 GMT
While feeling a Reaper isnt reccomended either i think you meant "don't fear the Reaper" Bloody auto correct keyboards - now edited "Don't feel the reaper!" Ha! That's brilliant. Hang on, I am the bloody reaper...  There appears to be a shadow in your window. Has Death been taking on apprentices again to assist with the current workload? Well it explains why my normally 'adventurous' social life took a nose dive. I thought it was the 2 meter social distancing thing but apparently I was wrong.
Jun 29, 2020 14:16:18 GMT
James - You have gone up the list in my estimation since we last met / spoke in person (probably 30 years or so ago) - reasoning being - excellent choice of music (or was that just the first thing that came up on a unselected not of your choice random playlist - if so I'll have to downrate you) Well I've not been on a canal site for at least 20 years. I'm pretty certain we met at Little Venice one year but I can't remember when that would have been. Anyway, music. I have a USB stick that plays in the MR2 and that was in the amp at the time (it still is 'cos I'm not using the car). It has some of my favourite records of the late 70s to early 90s on it. Appropriate for the car you see. Now for every record that you like there'll be a load you hate. I have a fairly odd and varied taste in music and I keep surprising myself. For example I loath and detest jazz. And then a 'dinner jazz' record by somebody called 'The Holly Cole Trio' turned up and I fell in love with it. Then I listened again to Swing Out Sister which I loved back in the day and realised it has a heavy jazz influence. So you can't trust me and music. I like all sorts - even stuff I admit to not liking. The stick... Someone, Somewhere in Summertime. Possibly the best Simple Minds record ever. Abacab Genesis. Actually I just rediscovered Paperlate by Genesis. It's fabulous and is never played. Another one I rediscovered... Tears for Fears - Pale Shelter. Possibly the best Tears for Fears record and a brilliant tutorial on what an 80s pop record should sound like. Some Talk Talk. How does Bon Jovi - Dead or Alive grab you? Frankie gots to Cricklewood? Or somewhere like that. Two Tribes. Hated it at the time. But now... Hell, could Trevor Horn make a record, or what!? A few bits of Fleetwood Mac. But then there is Birmingham by Amanda Marshall (which most of you will never have heard of) because it has lyrics that that are full of hope and the future. Level 42 - Leaving me now - because it has lyrics that are just so sad. Simply Red. That man can sing like nobody else. Live To Tell by Madonna. Because it's fabulous even though I'm no Madonna fan. And to leave you with a couple that are out of period... I hate the Stones. But Gimmie Shelter. Oh wow. Stunning. Has a rough feeling of early Motown stuff. The fact that the backing singer was singing so hard that her voice cracked up at one point and they left it in the mix. Utterly fabulous. And something current... If you haven't listened properly to 'The Radio 1 Live Lounge' doing 'Times Like These' then find some headphones and let it wash over you. Totally different to the Foo Fighters version which I don't even remember. In this current time where people have been dying by the thousand this version just reduces me to tears. It restores my faith that music is actually in safe hands. The kids done good. James
bstardchild
Club RR Member Number: 71
Jun 29, 2020 23:34:53 GMT
Anyway, music. I have a USB stick that plays in the MR2 and that was in the amp at the time (it still is 'cos I'm not using the car). It has some of my favourite records of the late 70s to early 90s on it. Appropriate for the car you see. Now for every record that you like there'll be a load you hate. I have a fairly odd and varied taste in music and I keep surprising myself. For example I loath and detest jazz. And then a 'dinner jazz' record by somebody called 'The Holly Cole Trio' turned up and I fell in love with it. Then I listened again to Swing Out Sister which I loved back in the day and realised it has a heavy jazz influence. So you can't trust me and music. I like all sorts - even stuff I admit to not liking. The stick... Someone, Somewhere in Summertime. Possibly the best Simple Minds record ever. Abacab Genesis. Actually I just rediscovered Paperlate by Genesis. It's fabulous and is never played. Another one I rediscovered... Tears for Fears - Pale Shelter. Possibly the best Tears for Fears record and a brilliant tutorial on what an 80s pop record should sound like. Some Talk Talk. How does Bon Jovi - Dead or Alive grab you? Frankie gots to Cricklewood? Or somewhere like that. Two Tribes. Hated it at the time. But now... Hell, could Trevor Horn make a record, or what!? A few bits of Fleetwood Mac. But then there is Birmingham by Amanda Marshall (which most of you will never have heard of) because it has lyrics that that are full of hope and the future. Level 42 - Leaving me now - because it has lyrics that are just so sad. Simply Red. That man can sing like nobody else. Live To Tell by Madonna. Because it's fabulous even though I'm no Madonna fan. And to leave you with a couple that are out of period... I hate the Stones. But Gimmie Shelter. Oh wow. Stunning. Has a rough feeling of early Motown stuff. The fact that the backing singer was singing so hard that her voice cracked up at one point and they left it in the mix. Utterly fabulous. And something current... If you haven't listened properly to 'The Radio 1 Live Lounge' doing 'Times Like These' then find some headphones and let it wash over you. Totally different to the Foo Fighters version which I don't even remember. In this current time where people have been dying by the thousand this version just reduces me to tears. It restores my faith that music is actually in safe hands. The kids done good. James I have a sneaky feeling we were twins separated at birth
Jun 30, 2020 11:39:02 GMT
I have a sneaky feeling we were twins separated at birth My long lost big brother! I knew we'd find each other again.
Possibly Triplets?
Paperlate was on an EP I think (remember them?) Agree it's a great track.
Any Level 42 track turned up loud enough the image in my door mirrors on my Dolomite used to blur was required listening back in the day. Had a tape of them doing Radio 1 in concert which is long since lost on which they did a cracking job of leaving me now.
Sean
Triplets - Hurray! And here was me thinking I was an orphan.
Interestingly, since I wrote that list I've heard a couple of those records on Radio 2 despite not hearing them for ages. I think Radio 2's music scheduling computer might read this forum.
Last Edit: Jul 5, 2020 8:18:17 GMT by Sweetpea
CaptainSlog
Club RR Member Number: 180
The level 42 led me to this:
Love this place!
Oops, sorry!
The level 42 led me to this: ! at 48 seconds, now i cant get that image out of my head
Jul 10, 2020 19:02:47 GMT
But it's nice when it turns out they can actually sing!
Jul 10, 2020 22:27:56 GMT
I know I’ve had a rant about environmentally friendly products that don’t actually work before. But I can’t remember how many rants I’ve had. The last time was when all the picture rail fell off the wall in Mrs Sweetpea’s office because I’d used ‘Save The Planet’ adhesive that turned out to be not sticky. But I can’t remember if I’ve had a rant about ‘green’ cars. Well if I haven’t, stand by, ‘cos it’s damn well comin’… You see part of my problem is that my other car is a very environmentally friendly hybrid. It sips petrol as if it was poison to its little mechanical bits. Well that’s the idea. In reality it’s more thirsty than my previous non hybrid and is a good deal less fun to drive. I mean it’s a bl00dy great SUV thing that apparently weighs most of two tons but I’d sort of expected that the hybridness would offset the weight a bit. I was wrong. What’s the point of all the hybrid stuff when it’d be better off with a decent AdBlue diesel in it? (So nothing by those lying b’stards at Volkswagen then.) Anyway, that’s not the topic for tonight. Hydrogen is the topic for tonight. It’s been touted as the clean fuel of the future. Lets face it, the only emission is water. Doesn’t get much better than that! And so London has a few hydrogen fuel cell buses and I’ve seen a few Toyota taxis using hydrogen as fuel. What’s not to like? Well my brain won’t let it rest there. Where does the hydrogen come from? The only way I know is electrolysis of water. Pass a current through water and you get hydrogen from one terminal and oxygen from the other. But my gut feeling is that, as an industrial process, it’s hopelessly inefficient and wouldn’t scale up well. Maybe this is why hydrogen hasn’t taken off as a fuel. Last night I was watching some stuff about rocket engines (what else) and I accidentally found out where 95% of industrially produced hydrogen actually comes from. The process is called ‘steam reforming of natural gas’. You’ll like this… What you do is this. You take natural gas (CH4 - carbon and hydrogen) and steam (H2O - hydrogen and oxygen) and pass it over a catalyst. I’m going to gloss over the details because I failed chemistry when I was a kiddie but what comes out is hydrogen and carbon dioxide. Sh1t loads of carbon dioxide. Ten times more CO2 than you get hydrogen. So that clean fuel that only emits water from the exhaust secretly emits shed loads of CO2 that they forgot to mention and… AND… And this is the bit that really REALLY winds me up me. Natural gas is a bl00dy FOSSIL FUEL for Gods sake. I bl00dy hate it when people don’t tell me the truth. en.wikipedia.org/wiki/Hydrogen_production
Jul 11, 2020 19:39:57 GMT
A few years ago I was breifly involved in a project to make hydrogen from solar energy, idea was a warehouse roof could be covered in solar cells and all day generate hydrogen which could then be used on the companies vans, at the time they were using petrol engines fitted with superchargers, at the time It just didn't add up financialy.
The idea with phevs is that 90% of journies are less than 20 miles so if you always plug it in you do most of your mileage on electric and only the occasional long journey on petrol. Problem is there are very few places away from home to charge them and realistically the only way we can generate enough electricity is nuclear which in it's self nedds millions of tons of concrete (about the most co2 intensive product there is to produce). The only real answer in to consume less.
