ivangt6
Club RR Member Number: 132
Range Rover Classicivangt6
@ivangt6
Club Retro Rides Member 132
Feb 15, 2018 23:07:36 GMT
The 8mm plastic coated copper pipe used for LPG makes a good fuel line, solder an olive on to form the pipe restraining ridge on the end. I'll look into that. I have 8mm microbore copper pipe from b&q. Pretty sure I saw olives on the rack next to the pipe. Just need a blow torch.
1979 Mini 1000 1972 Triumph GT6 2007 VW Golf GTi 1979 VW T25 Leisuredrive 1988 Range Rover Vogue SE
ivangt6
@ivangt6
Feb 17, 2018 22:44:29 GMT
Quick update on todays events Started off by drilling out the sheared bolt in the tailgate and then fitted it And fitted the rear view mirror Then went on to stonechipping all 4 wheel wells, under and inside the sills and under the new footwells and bodymounts Also painted the LH footwell on the inside in satin black and also the rear arches inside the doors Next up, I undersealed the RH front inner wing area and the boot floor And then made up the new fuel lines and made the brake lines from front to rear. Just the rear axle brake lines to do now Oh, I shutzed inside and under the battery tray too More re-assembly tomorrow Cheers
ivangt6
@ivangt6
Feb 18, 2018 19:16:44 GMT
Evening fellas Couple of jobs struck off the list today I only got a few hours down there but got the brake lines that run along the back axle replaced and then the whole system flushed and bled. After that I wire brushed the underside and rear axle which was a horrendously filthy job and then Shutzed the complete underside and rear axle. The front axle has a special anti-corrosion system using a mix of engine oil and power steering fluid which over time forms a rust preventative barrier, so it didn't need anything. Mot much to see, just a fresh coat of shutz which sort of hides the new brake lines. I must remember to cable tie the brake lines to the axle.. With the brake lines done and the underseal done, I can now start reassembly. I did try and get the engine started but it wouldn't fire. Not sure if its that low on fuel or if one of the many earths currently disconnected has something to do with the engine. A fair bit of fuel did come out when I removed the fuel lines and it was on empty with the fuel light on when I bought it. Couldn't hear the fuel pump prime though. So having wasted time faffing about with the engine I went and fitted the RH wing, headlight and indicator And that's about it Really need to get the tyres changed over now
ivangt6
@ivangt6
Late night update for anybody still awake. I've been really bad at getting down to the motor club recently but yesterday and tonight's efforts bring me to over 150 man hours spent on the Range Rover so far and around £1400 including what I bought it for. This means I'm still around £500 in profit from the sale of the Discovery. This might work out well...whats the worst that can happen? Progress from last couple of days "New tyres" fitted and balanced Wing,bonnet,grill etc fitted after fitting the filler strips in the windscreen rubber Boot floor panel stripped, painted and riveted in. Need some longer rivets for the front and rear corners And some new little reinforcement plates made which get riveted through.... ....here. Just waiting on longer rivets Front bumper stripped to bare metal and rust treated. This is very pitted but I will reuse it and give it a skim of filler. It will do for now And RH sill trim fitted Needed to change the oil so I had to start it. It turned out it wouldn't start the other day because the ignition relay wasn't fitted and the injection loom was disconnected. That sorted and... Made it to the lift and got its oil change Then took it for a little test drive. Quite a short one bearing in mind it as no fuel in it and the fuel it has is years old I tell you what, It bloody shifts! It feels a lot faster and lighter than my old Discovery somehow despite having a smaller engine and an auto box I really need to put the new exhaust on.
Last Edit: Feb 26, 2018 0:45:51 GMT by ivangt6
Yup, awake. But then it is 8:45 in the morning!
Looks to me like that was 150 hours very well spent. Nearly there now?
ivangt6
@ivangt6
Not far off. Need to change the relay panel on the bulkhead which I've been sort off putting off as it looks like a nightmare to get to. It unscrews from the inside, behind the dash and think I might have to take the aircon fans out to get to them. Other than that it needs the left wing fitted, exhuast fitted, screenwash bottle, radio wiring, dash bulbs, steering box adjustment, carpets and headlining.
I may well take it for an MOT before the headlining and carpets go back in so that the tester can see the welding. The only things I think it might fail on are the track rod end rubber covers are split and the front RH tyre is a little perished. We shall see!
Nearing the light at the end of the tunnel anyway and I'm looking forward to using it
ivangt6
@ivangt6
Feb 28, 2018 18:18:41 GMT
I ended up down the motor club last night as there was nothing on TV as usual I was supposed to be swapping over that relay panel that I keep putting off but decided to bite the bullet and re-cover the headlining. You can see it in the background in this photo. I was hanging down where it wasn't clipped in properly at the back when I bout it and had split at the sides where it had creased. Its also missing the two grab handles, two speakers, the rear courtesy light and I think there's supposed to be something above the rear side windows as there's a small cutout here. All these things are supposed to hold the headlining up. It was brush painted silver which didn't help either and I was sick of looking at it. I used this stuff from ebay www.ebay.co.uk/itm/SUEDETRIM-Van-lining-Headlining-material-Easy-to-fit-Foam-Backed-Faux-Suede/171990605620?ssPageName=STRK%3AMEBIDX%3AIT&var=470874424069&_trksid=p2057872.m2749.l2649I've never done anything like this before so it was a steep learning curve. I had 50 odd little cheapo plastic clamps from the range and a load of large bulldog clips which where more useful. The headlining material didn't stretch much so the trick was to lay too much material down and then shrink it where it creases with a hot air gun. It eventually I got it how I wanted except for a little bit at the front where I put too much heat on it and it went a bit shiny. Luckily that's covered by the sun visor. As usual I was rubbish at taking pics due to using my phone for music but heres a couple of the finished product minus 2 grab handles and the rear courtesy light I need to have another go at cleaning the sun visors as they are still a bit grubby after cleaning. They where disgusting before though Also made a little progres on the front bumper with a skim of filler. just need to do the other side and then it can be painted and put back on the car I'm running out of excuses not to fit that relay panel now..
Feb 28, 2018 19:13:30 GMT
Its coming together at last, you must be able to see the light at the end of the tunnel! don't know much about these but a lot of the underside and rear wheel arches look very similar to the Discovery, I only know as I was laid under a Discovery for a weeks worth of welding!! do they share many parts?
ivangt6
@ivangt6
Feb 28, 2018 20:02:54 GMT
Its coming together at last, you must be able to see the light at the end of the tunnel! don't know much about these but a lot of the underside and rear wheel arches look very similar to the Discovery, I only know as I was laid under a Discovery for a weeks worth of welding!! do they share many parts? Yeah the list is getting shorter now with most of the major time consuming jobs done. I had a disco before this and the steel structure is almost the same, just with different aluminium panels on the outside. Drivetrain and engines are largely the same so parts are still pretty cheap andeasy to come by Hoping to have an mot on it in the next couple of weeks. I need a dog car again!
ivangt6
@ivangt6
Well today went badly Running with the theme of avoiding taking out that relay panel like the plague, I thought I'd tackle the last really big job on the car. The exhaust. The old system is rotten from the downpipes to the centre silencer. The rear silencer is newish by the look of it. As I'm sure you're all aware, old exhaust systems are a nightmare to take out and true to form, all the clamps sheared, followed by 2 studs on the RH exhaust manifold to downpipe flange. So the RH manifold had to come out, which wasn't a bad thing as all the the bolts holding it in where loose. I tried welding a nut to the protruding studs but sheared them too. So nothing for it but to drill them out And then ran a tap through to get rid of the remnants So that sorted and manifold cleaned up and back on, I went to fit the new exhaust which is when things went downhill. It turns out there's more than one type of manifold fitted to these v8s and the new exhaust was miles out Its completely unuseable with the manifolds I have Centre silencer is good though which, to be fair, is worth more than I paid for the whole lot. So no real loss. Pretty miffed by this point so thought I'd go for a hoon with no exhaust. Love that V8 noise! Feeling better after that, I ordered 2 new downpipes and the Y shaped piece which came to about £60. Pretty cheap really and I'll have the peace of mind of having a new exhaust throughout. While I was under there I noticed a wire hanging down near the oil filter which turns out to be for the oil pressure sensor. This obviously sets alarm bells ringing. The engine doesn't rattle or smoke and there's very little blow by with the oil cap off. I did notice that the sensor has the connector snapped off so hopefully its a case of a broken sensor rather than a deliberate attempt of hiding an unhealthy engine. I have noticed, with the ignition on I only get 2 lights on the dash. I'm pretty sure all of the lights are supposed to flash up for a couple of seconds so there's definitely some further investigation required. Hopefully its just some blown bulbs.
You've done a fantastic job on this so far. And I have workshop envy...
Looking forward to the next (Bookmarked) installment.
ivangt6
@ivangt6
Mar 10, 2018 21:33:35 GMT
You've done a fantastic job on this so far. And I have workshop envy... Looking forward to the next (Bookmarked) installment. Cheers mrbounce!
ivangt6
@ivangt6
Mar 10, 2018 21:44:29 GMT
I had some brave pills today and went and tackled that bulkhead relay panel I've been putting off This is it It has 8 bolts holding it in from the inside which are behind all the aircon gubbins and two aircon fans. You cant take just the fans or the aircon gubbins out without taking the whole dash out as it all screws in from the inside. So access is a very small, scratchy b*****d gap between the sound deadening and the bulkhead 4 hours of upside down swearing in the footwell resulted in this no prizes for guessing which one the replacement is And back in with a lick of sealant. One of the most annoying jobs I've ever done on a car Whilst there I found that one of the aircon drain hoses was kinked just before it goes through the bulkhead due to a t-piece being put in the wrong way. It looks like its been like this from the factory and when taken off to relocate it, water spilled out everywhere. This must have been getting the LH floor wet from new, possibly why the LH floor was worse than the right. My new exhaust has arrived as well and compared with what came off looks like its the right one for the job Which is a job for tomorrow. And the to do list gets a bit shorter More tomorrow
ivangt6
@ivangt6
Mar 11, 2018 22:33:32 GMT
So today's Range Rover related nonsense 1st job to tackle was the exhaust. I bought an exhaust diverter valve kit a couple of weeks ago in the hope of being able to knock something up to give me the option of selecting between a silenced and unsilenced exhaust note. And so I set about cutting up my brand new exhaust But its worth it for the instant increase up to 20+ BHP! This is probably the worst thing I've ever done to a car lol Are you ready? It sort of works. It doesn't however close fully and allows some blow-by which is a shame because it does everything else pretty well. I really need to add some pipe to make it a side exit instead of the little stubby exit it comes with. I probably should have just fitted the new exhaust Anyway, that crime committed, I went on to the million and one niffnaff jobs left to do on this thing Washer bottle, air filter and coil fitted. Spark plugs replaced, belts tightened, washer hose replaced etc LH wing and indicator fitted. LH sill trim too Front bumper painted Some boot carpet and trim going back in All of this stuff takes more time than I thought it would. There's a lot of electrics that need bringing back to life too. The passenger window doesn't go down and the rest are slow for example. Generally everything needs some attention and a bit of use I do quite like the radio it has. I have no idea if it works as all the cables are cut and the plug on the car side of the wiring harness is covered in some unidentified goo which has rotted all the terminals I only have a week left in the Uk before I have to go abroad with work and its now not looking likely that its not going to get an MOT before then, but we shall see
ivangt6
@ivangt6
Mar 15, 2018 23:41:53 GMT
Spent another day on the car, putting seats and trim back in, sorting sunroof, tailgate wiring, fixing seat switches etc etc and gave it a wash I don't normally name my cars but SWMBO has christened it Big Dom And you don't mess with Big Dom There is a darkness inside of him. It wants to get out, it wants to walk around. It wants some walkin around money. And it wants to buy some shoes. And it wants to walk up to the people and say hey Big Dom don't play no s**t, you feel me? Big Dom never been about that, Big Dom never been about playin no s**t! Love the sound of this thing. I need to extend the diverter valve pipe to a side exit, just in front of the rear LH wheel Sadly its going to have to wait a while for an MOT now as I'll be away for a bit, but I'd rather give it a good few runs with me driving it before I'd trust it with the other half driving without me there. So thats it for now. GT6 patiently waiting
Love the sound of this thing. I need to extend the diverter valve pipe to a side exit, just in front of the rear LH wheel Hmm, you've got me thinking now!
ivangt6
@ivangt6
Love the sound of this thing. I need to extend the diverter valve pipe to a side exit, just in front of the rear LH wheel Hmm, you've got me thinking now! Not sure what the garage will think of it for the MOT. Might have to blank it off for that!
Love the sound of this thing. I need to extend the diverter valve pipe to a side exit, just in front of the rear LH wheel Hmm, got me thinking now!
ivangt6
@ivangt6
Jun 21, 2018 23:24:39 GMT
Well I'm back in the country now so full steam ahead with the range rover. When I left, all I needed to pass an mot where to fix the washers, fix the various exhaust leaks and extend the side exit and fit some road legal tyres. So I bought some Discovery 2 wheels with decent tyres and some modular Steel wheels. Id been after some black ones but these silver ones came up cheap so That done I unblocked the washers which went well and then took the RH exhaust manifold off which is where the problems started. Once off, I cleaned up the head and manifold and went to fit the new gaskets. Stupidly I attached the manifold to the downpipe first and then attempted to bolt the manifold to the head. It turns out my downpipe isn't quite at the right angle which put stress on all the bolts I was doing up and being an alloy head, the head lost on one bolt hole. Yep I've been an utter T**T and partially crossthreaded it Couple days later, browsing ebay with a beer, as you do (how I bought the camper...), I stumble across an early discovery with a some decent bits attached to it that COULD be useful on the Range Rover. It was going cheap at £500 so i set myself a limit of £650 and ended up accidentally winning at £725 I really should ban myself from ebay So here's my latest financial mistake And What can I say, Its a reasonably cheap disco with all the usual faults. Rusty inner wings, crunchy gearbox, steering slop, bad paint etc. However, there are some good bits. Its a hotwire 3.5 V8 on a manual box, 7 seater and the headliner is mint which is unheard of. It also still has the original centre console bag, boot cover, bull bar and roof rack. It also has some mods. A nearly new full stainless sports exhaust from rimmers, a nearly new and working LPG kit, 2"lift kit with dampers, black modular steel wheels with new tyres and a K&N air filter. Oh and polybushes all round and heavy duty steering arms. Now this is strictly a turn and burn. The exhaust and LPG kit will be going onto the Range rover along with the wheels but not the tyres. I want the smaller tyres fitted to the range rover on the black wheels, which is a bit of a faf really. Then I'm going to sell the bull bar, roof rack, silver wheels and big tyres, led light bar and 2"lift kit. Then it should just be a case of slapping on the standard wheels and exhaust, getting hold of some cheap standard springs and dampers and tarting it up a bit, mot'ing it and flogging it on. It has a few faults that need rectifying. It runs curse word on petrol, possibly MAF related, and possibly due to oil from the K&N, not sure yet. drivers seat base is ripped, LH swivel seal is shot and I might weld up the inner wings to give it a clean MOT sheet. I'm not sure what to do about the gearbox yet, it only crunches into 4th. I can either ignore it, try swapping out the ATF oil for gearbox oil or bite the bullet and spend £150 on a gearbox rebuild kit. Oh and I got a stonchip in the windscreen on the way back from the seller, right in the drivers view. So new windscreen as well. I've just removed the bull bar and roof rack this evening, so they'll be up for sale soon and I've also sorted the key fob which wasn't working You might just be able to see the cracks in the solder going along the battery holder legs. This had happened all the way round and the battery was loose. Just needed heating up with a soldering iron and a midge of fresh solder Love a cheap fix What else.. The paint on the LH side is horrendous. I think somebody has blown over it with a rattle can at some point. I've T-cut a patch and it looks like I can hopefully cut through it to the original paint underneath, fingers crossed. To that end I'm currently looking at getting myself a rotary polisher. Its about time I got one really. The only delay to progress on this might be our forthcoming trip to Snowdonia in Wales. The disco is very much MOT'd, taxed, insured and cheap to drive being on LPG. So there's pressure from the woman of the house to use this instead of the Range Rover. We shall see More soon Cheers! Ivan
ivangt6
@ivangt6
Hi Little evening update of where I'm getting with the Disco so far First off it took us from Norfolk to the Yorkshire Dales and back (400 miles) this weekend just gone which has shown up what needs work and what doesn't. To be fair I, despite it not having aircon, I enjoyed every second of it. It didn't miss a beat, the exhaust sounds great and there's very little road noise or creaks or rattles. I've been through the electrical side of EFI system to try and work out why it runs so stupidly rich on petrol. The MAF meter is showing correct voltages at ignition on and at idle, I can't test it under load but it runs rich at idle anyway so happy that's OK. The fuel temp and coolant temp sensors are showing around the right resistance and their plugs, which are the same pattern, are on the correct sensors. next I checked the throttle potentiometer. This is in the wrong position, showing a voltage that apparently is too low for the ECU to recognise. This goes some why to explain why the idle control valve is causing the revs to hang when you take it out of gear but it doesn't explain why its so rich. I need to rat file out the mounting holes on the throttle pot to adjust it so have left it for now. Next to check was the lambda sensors and soon found out it only has one fitted. Looks like sensor on the left would have interfered with the clutch slave cylinder on the stainless manifolds so they just plugged it with a bolt. The exhaust must be for a face-lift disco with the R380 gearbox or an auto Here's the empty plug for the lambda sensor I think if the ECU sees no value from the lambda sensor it presumes it wants more fuel, hence the rich running. I've ordered a new standard exhaust and lambda sensor which will hopefully cure it. The next obvious fault, which was mentioned on its last MOT was one of the headlight reflectors has gone all yellow. It looked horrible and had to go. One new old stock headlight later... And I got round to removing the roof rack and bull bar, which meant I could move the numberplate back to its proper position. I also found the grill badge in the boot. I will get round to painting those bumpers. Starting to get there Next on my to do list is fix the rear door lock One of the screws holding the latch on has sheared. And the light at the bottom of the door doesn't work This car just needs some general attention really. Its got good service history but also a lot of fairly easy to fix faults. It seems the previous owner was more interested in spending a lot of money on a lift kit wheels, exhaust etc instead of fixing it I'm not usually too keen on beige interiors, but I really like this one apart form the tear in the drivers seat. Its very comfortable. Again, it just needs a bit of a clean and a few odd little bits fixing. I'd love to come across an original radio for it. No idea what that would be though There's actually a few different colours going on in the material. I didn't notice at first, its quite subtle. It reminds me of tweed a little bit. Christ I'm boring! By far the biggest issue this car has though is the paint, particularly the LH side This is the bit I managed to T-cut through. I'm hoping to get through it to original paint with my rotary polisher. Wish me luck! And that brings about up to date. The trip to wales is coming up soon. Once that is out the way, the lift kit, wheels, exhaust, LPG and K&N air filter are finding their way onto the Range Rover and this will be put back to how it was originally and sold. Anyone fancy an early Disco?
