Adey
Club RR Member Number: 171
Last Edit: Nov 12, 2017 5:20:30 GMT by Adey
Adey
Adey
Adey
Last Edit: Nov 9, 2017 12:57:12 GMT by Adey
Adey
Adey
just incase anyone else wants one, they are the honda s2k filter, cheap as chips and filter for a good 240bhp. huge too!
Adey
I found a fog light blank in the boot so used some tiger seal to hold it in place, hides the pipework some more but need to find a drivers side one to match. With a little help from Sparkysparks (he has a 172 clio mk1 on here i think) sending me some wiring diagrams I was able to re pin and trace all the correct wiring and add some where needed, still need to work on the temperature side of things but the wiring and dash side of it work fine so I think the sensor might be goosed. Rev counter now works fine so the dash was fully re fitted. I also re fixed some of the dash location fixings, not overly interesting but getting there now. Still some wiring to finish tidying in the bay but the bulk of what I wanted to get sorted is there.
Adey
Last Edit: Nov 9, 2017 12:59:26 GMT by Adey
Adey
Adey
Adey
Adey
With all that i managed to get some oil lines made up and the turbo on, it needed a custom downpipe knocking up but all is well
Adey
Adey
Adey
Last Edit: Nov 9, 2017 13:02:57 GMT by Adey
Adey
obligatory RR sticker added
Last Edit: Nov 9, 2017 16:00:24 GMT by Adey
Nice work! I am restoring a genuine Dimma Clio, slowly getting there. Cracking little cars but they do love to rust!!
Adey
bauderline do you have a link to the work? I'm mad for the renaults and havent seen a dimma in years
Adey
Popped the new header tank on even though everything else looks a mess. Marked up the downpipe for welding whilst there, hopefully itll be the last time i need to remove it. I have been donated some second hand exhaust wrap so ill do that too before fitting.
Adey
