Apr 12, 2019 18:25:53 GMT
Onwards with the profiles & prep on the door apertures Then applied a second skim where required Also made a start on the offside sill Sid called in for a quick look and then went on security / goods received duty Bonnet now sorted Has is the offside front wing So now getting ever closer - I will undertake the door repairs next week & I ordered the paint today
Apr 12, 2019 18:43:28 GMT
paint......!!!!
its getting close boys (& girls just to be pc)
Apr 12, 2019 19:59:01 GMT
Chris-How much paint, primer, thinners etc do you order for a job like this to ensure that you have a good supply in case of problems, but not have too much left at the end. I appreciate that thinners etc can be carried forward to the next job.
keyring
Club RR Member Number: 47
Apr 12, 2019 21:38:05 GMT
Not been online for a few days, but certainly making headway through all the sanding and filling, paint can’t be far away now
Apr 13, 2019 11:08:02 GMT
Chris-How much paint, primer, thinners etc do you order for a job like this to ensure that you have a good supply in case of problems, but not have too much left at the end. I appreciate that thinners etc can be carried forward to the next job. It all depends on what paints you using - Solvent based paints will use much more thinners than a 2 pack paint but on the other hand solvent based paints don't utilise a hardener My planned quantities for the Corsair are has follows: Polyester primer (2 pack) - 4 litres Sealing primer (2 pack) - 3 litres Final colour coat (2 pack) - 4.5 litres - this actually becomes 7.4 litres in volume once you have added the hardener & thinners to the paint You need to allow for the engine bay, boot enclosure, door apertures (doors), door apertures (bodyshell), underside of bonnet & boot, 5 wheel rims, other minor painted parts, vents, hinges etc & all external panels of the bodyshell The internal floorpan, bulkhead, dashboard areas are unseen once the car is refitted - non the less these will get a coat of satin black
Apr 13, 2019 11:09:31 GMT
Not been online for a few days, but certainly making headway through all the sanding and filling, paint can’t be far away now Next few weeks will see the car back into colour
fer4l
Testing
Club RR Member Number: 73
Apr 13, 2019 16:46:14 GMT
Going to be the purdiest Corsair ever! Cheers Matt
Apr 16, 2019 19:58:50 GMT
With the Javelin demoted to outside and some workshop space freed up I can look at the final panel repairs on the offside doors Rear one first Its much easier just to reskin the lower section of the door Although it looks like it was just each end that was effected by rust Until you turn it over and look at the deep rust pits eating the skin from the inside out A few small sections let in on the door frame where rust had effected the area Repair section made up & trail fitted Requires some further adjustment in the morning prior to refitting it to the car to check for clearance against the sill
Last Edit: Apr 16, 2019 20:00:39 GMT by Deleted
Apr 17, 2019 18:59:43 GMT
Last Edit: Apr 17, 2019 19:03:09 GMT by Deleted
Apr 17, 2019 19:54:18 GMT
Awesome as always When you weld the new panel in, you’ve said about tacking and letting it cool so as not to distort the panels. Do you need to do anything when grinding, or does the heat not build up as much?
Apr 17, 2019 20:22:31 GMT
Awesome as always When you weld the new panel in, you’ve said about tacking and letting it cool so as not to distort the panels. Do you need to do anything when grinding, or does the heat not build up as much? John - Good point - you can do has much damage with the grinder has you can with the welding - same rules apply - if you keep the angle grinder moving though and don't stay on one spot and avoid digging the wheel in you can to a great extent just keep moving with it - airline and a blow gun works effectively at cooling areas down too
Apr 17, 2019 20:54:29 GMT
Chris- How do you keep a straight line when slitting the bottom section? Just a very steady hand or some kind of guide/jig?
i don't know if its a thing, but my grinder has an air pump and blows air out of the tip of the casing. i often use it to un-steam my goggles!
Chris- How do you keep a straight line when slitting the bottom section? Just a very steady hand or some kind of guide/jig? Mainly freehand for me following a marked line - masking tape works has a line too but a piece a angle iron and a clamp at each end to run the face of the cutting disc against if you need it to be super straight
Apr 18, 2019 12:59:30 GMT
i don't know if its a thing, but my grinder has an air pump and blows air out of the tip of the casing. i often use it to un-steam my goggles! whaaaaaaat. is it a swiss army grinder??
Apr 18, 2019 19:51:13 GMT
Back on with the repair section Which now could be tacked up Then the flange closed up tight with the hammer & dolly Then a trial fit of the door (fronts are a pig to hang but the rears are a doddle) Then back off to complete the tacking up Dressed back & cleaned up Then refitted to the bodyshell and checked Then repeat the process for the rear door Which is now ready for rehanging
Apr 18, 2019 22:30:26 GMT
lovely workmanship
Apr 20, 2019 21:44:33 GMT
Found time to hang the rear door Outer gapping is reasonable and requires minimal work Gapping between the two doors is pretty hideous
Nearly there then! can you see the light at the end of the tunnel or is it just a man with a torch?!!
Nearly there then! can you see the light at the end of the tunnel or is it just a man with a torch?!! Its normally a bloke with a high intensity search lamp switched on at full beam, the bloke is a banksman for the fleet of skip lorries behind him with the additional work load on them
Last Edit: Apr 21, 2019 8:40:50 GMT by Deleted
