Hi there, having a little clear out of some things due to the central heating system packing up.
First up is a Sealey 150 Mightymig gas/gasless welder, this has had little use and is in full working order. The torch has been uprated (shuts the gas flow once the trigger is released), it comes with an auto fade mask, Bedford Battery Argon mix cylinder (empty but can be taken back to Beds Battery and exchanged for a refill which I think is around £30) hi-lo gas regs & flow meter, a new spool of fluxcore wire for gasless (0.8mm spool for gas welder already inside), some replacement Sealey tips, replacement shroud, various clamps and a magnet. Please see the photo's below;
Looking for £180 for the lot ono. SOLD
Next up is a pair of Blackrock safety rigger boots, these are oil & flame resistant. Purchased to do a day course last year so used just once, they're a size 8 but more like a 9 to be honest. Still boxed.
Asking for a £8 SOLD
Next up is some NOS service parts, there's a QH thermostat, some points & condensor (most late 60's to early 70's Ford), some Lucas bulbs, genuine Ford Dyno brushes (believed to be for an Anglia), genuine Ford stop/tail bul, Motorcraft (Ford) flasher relay & a 'Karri-Pak' set of points for a 105 Anglia.
Asking for £15 for the lot
Lastly is a selection of tools, included is a 2 leg hub puller, a pair of spring compressors, 2 old skool oil filter removal tools, 3 clamps and an old greasegun.
Asking for £20 for the lot SOLD
All prices are plus postage, the welder would need to be collected due to weight & size. I'm based in Milton Keynes (J13/14 of the MI and close to the A5), any questions? Please ask away, thank you.
