Ed
Nov 22, 2004 15:18:25 GMT
greetings picked this up at the weekend.....for £100 ;D need to get the lowering stick out to get it closer to mother earth. but I'm having trouble finding springs that are affordable gsf don't do 'em, neither do ecp...... any help guys please....or any ideas how to lower cheaply I'm looking for a 60mm front/40mm rear maybe?
Nov 22, 2004 15:21:22 GMT
I might be wrong, but don't Golf springs fit?
If I am wrong, try getting hold of the Passat GT ones - I believe these were about 30 - 40mm lower than std Passat's.
Ed
Nov 22, 2004 15:21:33 GMT
oh to have as sexy as this
Nov 22, 2004 15:24:37 GMT
ermm, would one of these help? ;D
Nov 22, 2004 15:56:06 GMT
Ed
Nov 22, 2004 16:09:53 GMT
cheers rainking and iRocco I'm confused though 35i stretches over two models 88-92 and 92-96.....i don't know which mine falls into? the former or the latter? and nickb......maybe....if it comes to that ;D
racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
Nov 22, 2004 16:12:07 GMT
whip em out and adjust them with an angle grinder!! free lowering springs to your own custom height!! (just don't go over any jumps they might fall out!!)
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Nov 22, 2004 16:34:01 GMT
Why not simply put something very heavy in the back? ;D
This space available to rent. Reach literally dozens of people. Cheap rates!
Nov 22, 2004 16:53:46 GMT
Call me a fascist if you must, but why even do that? It looks dead smart to me, why curse word up the suspension?
Nov 22, 2004 17:32:12 GMT
Fascist! ;D ;D ;D Sorry, couldn't resist, it's been almost minutes since I said anything political on this forum! Besides you told me to! ;D ;D ;D ;D
Seriously though, it looks Ok, but if you want to lower it there are more than a few guys on here who recommend chopping bits off the springs by yourself, and could give you an idea of what's involved. (I'm guessing a grinder and a tape measure mostly!;D ;D)
"He's not the messiah, he's a very naughty boy!"
Ed
Nov 22, 2004 18:02:01 GMT
fascist! ;D why do it? I'm scared illegal immigrants could hide in the arches. sorry, i lower all my cars, its just a way of life
Nov 22, 2004 19:04:53 GMT
The angle grinder is my favourite tool! ;D I'm not sure what set-up those Passats have, I've never chopped McPherson strut-style springs. I'm not really sure how much you can take off those springs... If you go half a coil at a time you can't really go wrong - it's amazing how much lower your car gets with only one coil off! I cut 1 and a half coils off my Merc and it dropped it about 2 inches! There is always coil-over kits for McPherson strut cars. The springs are abot £25-30 each, and you adapt your own struts (it depends how "hands on" you want to get though! ;D). Then you can just lower and raise the height with a C-Spanner.
Nov 22, 2004 21:04:20 GMT
SkoCan
Quando omni flunkus, mortati
Nov 22, 2004 21:26:47 GMT
Hmmm Christmas is just over a month. Should have time to drop a couple hints about one of these Very inexpensive these days ;D
BigWig
Where did you get that for £100! bargain.
model? mileage?
Ed
Where did you get that for £100! bargain. model? mileage? 92 2.0 gl 140,000 miles....bought off my brother, fully serviced , with a bizarre intermittent misfire which happens for the first 5 mins of driving sometimes....but for a ton i don't mind. cruises sweetly and returns 40.8 mpg on the m'way ;D
Ed
Nov 23, 2004 13:47:05 GMT
ive bought some springs ;D ive let some people down and I'm sorry.... should have gone the grinder route but i couldnt do it. they arrive tomorrow!
Nov 23, 2004 13:59:58 GMT
92 2.0 gl 140,000 miles....bought off my brother, fully serviced , with a bizarre intermittent misfire which happens for the first 5 mins of driving sometimes....but for a ton i don't mind. cruises sweetly and returns 40.8 mpg on the m'way ;D Try a coolant temp sender for the missfire, they always play up on VWs. also try a new dizzy cap and rotor if they haven't been replaced for a while.
Nov 23, 2004 14:21:38 GMT
cheers rainking and iRocco I'm confused though 35i stretches over two models 88-92 and 92-96.....i don't know which mine falls into? the former or the latter? and nickb......maybe....if it comes to that ;D yours is Pre-Facelift Ed.... so it's the 88-92 Category..... IMHO the later one 92-96 is the most hideous passat EVER..... Really like the early ones (like yours) Abi (Bugbabe22 (not Polly )) had a 1800 8v GT Pissrat Estate a little while ago... cracking car... went like stink too! ;D
Last Edit: Nov 23, 2004 14:22:08 GMT by rainking
Ed
Nov 23, 2004 16:08:05 GMT
Try a coolant temp sender for the missfire, they always play up on VWs. also try a new dizzy cap and rotor if they haven't been replaced for a while. dizzy cap and rotor done, but not the coolant sender.....it seems like an electrical misfire...not fuel....my brother has kinda being chasing it for a while....the ecu doesnt register when you plug the computer in either.....its a weird one....would like to pull off the injection and go carbs though ;D
