ed said:
dizzy cap and rotor done, but not the coolant sender.....it seems like an electrical misfire...not fuel....my brother has kinda being chasing it for a while....the ecu doesnt register when you plug the computer in either.....its a weird one....would like to pull off the injection and go carbs though ;D
If it's not registering the computer then there's a possibility that it's an E.C.U fault, quite common on old VW/Audis with the vacum hose equiped E.C.U, as oil finds it's way into the E.C.U housing(mentioned it in another thread recently) but it's also worth checking the condition of the shaft the rotor pushes on to as they're normaly corroded and if it wasn't cleaned completly before putting the new rotor on this can cause ressistance leading to a slight missfire.
hope this helps.
