Feb 21, 2017 16:15:56 GMT
I need some longer screws to hold the handles on my winder mechs. I cant work out what they are though.
My pitch gauges say they are either 1.1mm or 24tpi but my calipers measure 0.180" or 4.61mm ish across the threads.
I cant find anything that seems like this.
they are just normal looking button head machine screws about half inch long. I need some about an inch long.
Any ideas?
Feb 21, 2017 16:24:46 GMT
what car are they off ? I'd guess that they are a standard 5mm screw
Feb 21, 2017 16:32:02 GMT
1979 bedford cf.
Feb 21, 2017 16:35:16 GMT
Last Edit: Feb 21, 2017 16:36:13 GMT by colnerov
Feb 21, 2017 16:35:43 GMT
Arent M5 0.8 pitch though? Might possibly be able to bodge m5x1 in but it would be a bodge, might just strip out and they don't seem available anyway.
Feb 21, 2017 16:39:28 GMT
Might well be. Diameter seems a bit large, mine arent worn, but these things never measure exact do they.
Feb 21, 2017 17:10:31 GMT
Let me have a look tomorrow at work. 😊
3/16" BSW might be easier to find than unc. Pitch and diameter the same , just threadform is 55 degree as opposed to unc's 60 degree.
Last Edit: Feb 22, 2017 9:01:16 GMT by Deleted
3/16" BSW might be easier to find than unc. Pitch and diameter the same , just threadform is 55 degree as opposed to unc's 60 degree. Thanks, ill have a look.
Feb 22, 2017 10:40:51 GMT
what car are they off ? I'd guess that they are a standard 5mm screw oops I guessed wrong, I went VW but Bedford could very well be 3/16 BSW or UNC
fad
Feb 22, 2017 14:50:03 GMT
Get something that's about the same, and if it don't fit, turn harder. Or... Drill out the threads in there and re-tap to something more sensible?
Feb 22, 2017 14:55:17 GMT
Get something that's about the same, and if it don't fit, turn harder. Or... Drill out the threads in there and re-tap to something more sensible? This isnt a beetle!! I did think about drilling and tapping though, but the longer screw needs to fit through a spindle adapter I'm making. If I make the center hole any bigger it will weaken the adapter too much.
Darkspeed
Club RR Member Number: 39
Feb 22, 2017 15:04:08 GMT
Could be a 2BA screw - although 3/16 unf unc would be more like.
Last Edit: Feb 22, 2017 15:36:03 GMT by Darkspeed
Feb 22, 2017 15:11:13 GMT
Dimensions seem ok but 2ba pitch is 0.81 apparantly. (According to wikipedia)
Darkspeed
Feb 22, 2017 17:07:15 GMT
fad
Feb 22, 2017 17:46:29 GMT
Glue. Done.
Feb 22, 2017 17:55:17 GMT
Feb 22, 2017 18:23:39 GMT
Because there is no finer feeling than being on holiday in the middle of a field, in driving rain and gale force winds, and realising you cant shut the window because that winder mech you bodged has just let go.
93fxdl
Enter your message here...
Feb 22, 2017 20:52:23 GMT
Feb 22, 2017 21:11:45 GMT
Handy chart. None match exact but 3/16 bsw seems to be closest.
I have redesigned my adapter for the window regulator so I may be able to use the original screws now.
