adam73bgt
Club RR Member Number: 58
Soldering a chip into an ECUadam73bgt
@adam73bgt
Club Retro Rides Member 58
Oct 25, 2016 22:06:47 GMT
I've got a chip for my RX7's ECU which I need to fit as I need the car mobile so I can move house I've done a bit of soldering in my time but probably not with anything as valuable as an ECU... So my question is, as a DIY'er, how easily will it be to cock it up? It's desoldering a chip, then soldering a socket in its place, and the new chip is actually just pushed in Is it something I should get someone else to do? Any advice is very appreciated!
Oct 25, 2016 22:19:52 GMT
You will need a solder sucker or wick to remove the solder on the chips legs. don't over heat the tracks or they might lift. Trying to remove the chip without removing the solder might damage the tracks.
Same when soldering back in.
If you can solder competantly and have a good iron with a fine tip you'll be fine.
The most important thing will be removing the solder fully and quickly.
Oct 25, 2016 23:20:27 GMT
If it's thru hole (legs poke through holes in the board), clip them off the old chip first and desolder them one by one. You're way less likely to damage the board that way.
Obv. don't do this if you want to keep the old chip.
Soldering a chip into an ECUChasR
@chasr
Club Retro Rides Member 170
If you need to borrow a good iron let me know. I have (well, I mean my dad's that I seem to have acquired) has a Weller iron from around 30 years ago. It's been a faithful old thing!
One thing normally overlooked is static. Static fries EPROMs. If you have ever bought any new components,you will have noticed they often come in foil and plastic antistatic bags . Best done standing on a tiled floor after you have earthed yourself out by touching something with a good earth,i.e. The kitchen sink.....
Last Edit: Oct 26, 2016 3:55:41 GMT by Deleted
MiataMark
Club RR Member Number: 29
One thing normally overlooked is static. Static fries EPROMs. If you have ever bought any new components,you will have noticed they often come in foil and plastic antistatic bags . Best done standing on a tiled floor after you have earthed yourself out by touching something with a good earth,i.e. The kitchen sink..... Good point, to be doubly safe use an earth strap, a wire connected to an earth (radiator etc) and your body.
adam73bgt
@adam73bgt
Cheers for the replies guys, I've got a semi decent iron and a plunger/sucker thing, so I think I will have a go One thing normally overlooked is static. Static fries EPROMs. If you have ever bought any new components,you will have noticed they often come in foil and plastic antistatic bags . Best done standing on a tiled floor after you have earthed yourself out by touching something with a good earth,i.e. The kitchen sink..... Good shout (except my kitchen sink is plastic... ) I think I've got an anti static wristband somewhere from when I built my PC so could chuck that on if I find it, otherwise I'll ground myself via a radiator or something
Oct 26, 2016 12:10:27 GMT
Jumper cables work well. Red on the hot tap, black on the cold and clip onto earllugs....
Oct 26, 2016 15:05:36 GMT
The key is to not keep the heat on for too long. If you have an adjustable temperature soldering iron then great. Don't bother with suckers, use a desoldering braid, a good one with flux and it will suck the solder straight off the board and leave it nice and clean. Use flux on the socket and the chip legs and it should be simple enough.
Will you be needing to change the chip again in future? If you are, it's worth soldering on a socket instead.
Oct 26, 2016 16:56:20 GMT
If you have doubts i would see if you can find a local electrical repair place , tvs , white goods etc . I have got stuff done by my local one [ resistor in a welder ] and he charged me £5 .
rbs
Oct 28, 2016 19:56:41 GMT
I usually earth myself into the mains. Wire a 13A plug with just the earth pin, attach the wire to your wrist and plug it in.
Oct 28, 2016 20:46:13 GMT
Get you hands on some scrap electronics with similar chips you intend to desolder etc and practice on that 1st.
Post a pic of what you are talking about desoldering and installing too would help.
Oct 28, 2016 20:49:58 GMT
I usually earth myself into the mains. Wire a 13A plug with just the earth pin, attach the wire to your wrist and plug it in. not advisable, if anything else in the house goes to ground you'll become part of the circuit yourself. it is not a pleasant experience!
Last Edit: Oct 28, 2016 20:50:39 GMT by welshpug
rbs
Oct 28, 2016 20:56:01 GMT
That's what BMW have us do. They supplied us with an anti static matt, a 13A plug with a velcro strap and connector for your wrist and another wire to clip onto the matt.
adam73bgt
@adam73bgt
Oct 29, 2016 13:09:57 GMT
Aye very similar sausage , I've not had a chance to pull the ECU out the car just yet, but heres a couple of pics from the installation instructions
Oct 29, 2016 23:02:05 GMT
Id cut the legs with knife, and pull them out one by one. You can then use a wick to clean off the old "sodder..."
The old sodder maybe lead free, so either " suck it off " or wich it off before you put the new chip in...
adam73bgt
@adam73bgt
Oct 30, 2016 23:11:50 GMT
Thank you for all the replies and advice, I took the ECU out the car today and had a go. I cut the legs off to remove the old chip, then used the soldering iron with the plunger/sucker and a small pair of pliers to remove the remnants of solder/wire Then soldered in the socket and the chip pushed in, went pretty smoothly! Thanks again all
Last Edit: Oct 30, 2016 23:12:26 GMT by adam73bgt
