andyborris
Sept 24, 2016 15:17:35 GMT
I ask because the new mechanical temp gauge is saying the water in the top hose is at 99c, yet I can place my hand on it comfortably, or are silicone hoses that good at heat insulation?
Car is a Triumph with a BMW M52 engine fitted, engine has 88c (fully open) thermostat fitted, a MK2 Golf GTI aluminum rad (supposed to be up-rated!).
The fan control is in the bottom hose, which feels barely lukewarm (not much warmer than a babies bath!), when the fan is running. Fans switch point is 90c.
I've got a “point & shoot” thermometer, it say's the top hose is at around 70c and the bottom about 60c, but that's on the outside of the hoses.
If the coolant is actually exiting the engine at 99c and dropping to 88c after the fan, is this what I should see with an 88c thermostat? And is it OK?
Or is the gauge another new part, that's not fit for purpose or is it air locks? And how do I tell?
Last Edit: Oct 25, 2016 17:32:20 GMT by andyborris
colnerov
Sept 25, 2016 10:45:24 GMT
Are the heater hoses a similar temperatures?
fad
Sept 25, 2016 11:02:24 GMT
Is it steaming, spitting, and generally misbehaving?
rude
Sept 25, 2016 12:04:33 GMT
You can burn someone's palm of their hand by holding it on there on my 635 top hose after a good run, to extract secret information and get debts paid of course.
EDIT: I don't have an electrostatic fan though.
Last Edit: Sept 25, 2016 12:08:01 GMT by rude
1986 Haunted BMW E24 635CSi 1999 Povo spec BMW E36 1.8i Touring Work Hack 2001 Petrol annihilating Discovery V8 2000 Jaguar S Type 3.0 V6 ~NEW~
Sept 25, 2016 13:05:50 GMT
You can get digital infrared thermometers for £20 now , might be a worthy addition to the toolbox.
Sept 25, 2016 13:55:52 GMT
andyborris
Sept 25, 2016 15:47:14 GMT
Well, checked the temp gauge and it's 10c out at the bottom of the scale, 5c out closer to boiling temp.
This was in a pan of water on a camping stove, used a cooking thermometer to check against and a infrared gun to check the cooking thermometer (the infrared just looked through the water at the pans base and gave a false reading!)
The Aluminum radiator is too hot to touch at top hose entry point, but the exit hose and most of the rest of the rad is lukewarm, bordering on cold!
It's not spitting, steaming or boiling. It does push water out of the header tank as it warms, but that might just be me overfilling, the header is large and 6 inches higher than the rad, but it feeds into the engine at what is the lowest point.
I filled the cooling system via the temp sender hole and the little pipe on the topside of the rad, the one that lets the air escape, so I'm pretty sure that system isn't air locked.
What worries me is that, according to the gauge, the rad fan isn't taking the temp done at all.
It seems to push a lot of air through the rad, the rad isn't hot, apart from around the top hose, the hoses show a 10 to 15 degree difference top to bottom.
Car isn't mot'ed, so can't road test and don't want to mot it till I know it won't boil up at the station!
The heater hoses (not silicone) feel much cooler and one of those comes straight from the back of the cylinder head.
3 questions, which make of gauge is reliable? Is fitting the gauge in the top hose OK? What temp will the coolant be as it passes through a 88c thermostat?
Till I get a reliable temp reading, can't really fix any problems, (if I do have one!).
rude
Sept 25, 2016 16:09:54 GMT
And the thermostat works ok right?
andyborris
Sept 25, 2016 17:21:48 GMT
And the thermostat works ok right? Well that's a good question, no idea is the answer! I suppose taking it out and testing is the next move....perhaps it's just running on the hole I drilled in the stat to aid air lock removal....?
Sept 25, 2016 22:41:47 GMT
Are you running the right thermostat? At the very least it should have a foot at the bottom of it. Failure to have that could cause warmer running. FWIW the factory BMW 'stat goes to 92 degrees and is a Wahler item: I'll have to check how a Golf rad compares to a M52 item. I am sure mine was pretty thick... How many heater hoses do you have? I recall my E36 having around 3 in a strange setup...
Last Edit: Sept 25, 2016 22:43:04 GMT by ChasR
andyborris
Sept 29, 2016 15:47:44 GMT
Quick recap, couldn't understand why the new temp gauge showed 98c, yet most of the rad and bottom hose was cold, even the top hose was still touchable.
Following advice on here (thanks), I pulled the thermostat and checked it.
It works, but opens at, (you've guessed!) 98c!
So this where I say WTF! After buying 2 unreliable not opening at the 88c they should, aftermarket stats, I pay 3 times what a Eurocarpart stat cost at the BMW stealer, to get the genuine thing.
I tested it before fitting, it opened at 88c, only now it doesn't, it opens at 98c! That's after 2 years of sitting in a dry engine, not being used. I always thought that stats worked or didn't?
Still hopefully this demonstrates that the cooling system can cope, it run at 98c and didn't get too hot.....or am I deluding myself?
I've got the standard 2 hose heater, hot feed from the back of the head, cold return to the metal pipe that runs along the engine into the water pump, this pipe also draws coolant from the header tank. Air bleed into header tank from rad top and header tank is at least 6 inches higher than the rad and engine.
So 82c or 88c stat? I want it to be fully open at 88c, past experience has shown the temp listed is the "start to" open, not the fully open temp!
rude
Sept 29, 2016 16:40:51 GMT
From what I'm reading around the web, the M52 operates best at above 90 degrees which it is supposed to do for efficient running. Your fan switch is in the bottom hose to prevent the fan running constantly as the coolant has passed through the rad and has been cooled from airflow through the rad. If standing idle and the pumped water through the rad reaches 90 degrees then the fan will activate. (if that is what temperature the switch is activated at) You say it pushes water from the header tank, it would be worth investigating to find your system pressure is ok and to make sure you have the appropriate cap.
Why do you want it to be fully open at only 88 degrees? That's not the M52's operating temperature so the stat opening at around 98 or whatever means it is probably working correctly. If the coolant in the bottom hose reached over 90 and there was no fan coming on, then I'd start worrying. Likewise if the coolant reaches over boiling in the top but very cool in most of the rad it would suggest a circulation issue as the coolant is failing to circulate either by a blockage or failed water pump. I haven't seen you post that the fan does come on after long idling and /or the water is circulating under normal operating conditions? If you're after some enthusiastic driving aids then a competition stat can be got that opens at 70 but then the MPG suffers.
andyborris
Sept 29, 2016 17:51:50 GMT
Unfortunately, the cooling system is still at the testing stage.
I'm assuming that the water is circulating correctly, even though the Golf rad has the top hose inlet on the opposite side to the BMW rad, the Golf has both top and bottom on the same side of the rad.
The new gauge seems to be fairly accurate, esp. at the higher end of it's range.
The water pump is quite new and with metal impellers.
I picked on 88c because that's the recommended stat on the E30 Zone M52 engine swap Wicki, that's where I've stolen most of the knowledge from. The stat in the car was an 88c one, so opening at 98c is bit disappointing!
I'm going to bin the adjustable controller and use a 95c to 90c switch, mounted in the bottom hose, the temp gauge is in the top hose.
If the 98c stat was working properly and controlling the temp, then the cooling system should cope, when the fan was running the temp stabilized at 98c, the stats open point.
The fan wasn't switching off however, but that's a different issue, hopefully cured by the switch change.
If I use the recommended stat, which is a 92c one, how will a 95/90 fan behave, will it be running all the time because the stat is keeping the temp at 92c?
My brain hurts..........
rude
Sept 29, 2016 21:24:20 GMT
If the fan switch is after the radiator like you say then the coolant would have dropped temp circulating through the radiator and will not activate it during normal use, obviously so long as the rad is capable of cooling a big enough volume of coolant before it exits. If it's idling for long enough with no direct air travel through the rad then once 90+ degree coolant travels through the rad, the fan switch will activate. It will only deactivate once air has passed through the radiator or the fan has cooled the coolant sufficiently enough for the temperature of the coolant to be less than 90 degrees or whatever switch you have installed. The already hot engine will be taking care of the thermostat side of things, acting like a giant kettle and heating the coolant back up again and keeping the thermostat open. The stat only controls the flow of coolant until operating temperature is achieved by the engine, it closes to allow the engine to reach operating temperature as quickly as possible. Once that bit is done it's pretty much in an open state for the remainder of the operating period. Unless you live in the darkest depths of Russia. Putting a lower grade thermostat in will make the engine run cooler during normal operation, this will effect the engines efficiency but will gain tiny amounts of power. Just having a thermostat will allow the engine to reach operating temperature but it will get hotter and hotter as it has no regulation, a radiator is a basic regulator and a fan switch is a fail safe.
colnerov
Sept 29, 2016 23:08:18 GMT
If the fan switch is after the radiator like you say then the coolant would have dropped temp circulating through the radiator and will not activate it during normal use, obviously so long as the rad is capable of cooling a big enough volume of coolant before it exits. If it's idling for long enough with no direct air travel through the rad then once 90+ degree coolant travels through the rad, the fan switch will activate. It will only deactivate once air has passed through the radiator or the fan has cooled the coolant sufficiently enough for the temperature of the coolant to be less than 90 degrees or whatever switch you have installed. The already hot engine will be taking care of the thermostat side of things, acting like a giant kettle and heating the coolant back up again and keeping the thermostat open. The stat only controls the flow of coolant until operating temperature is achieved by the engine, it closes to allow the engine to reach operating temperature as quickly as possible. Once that bit is done it's pretty much in an open state for the remainder of the operating period. Unless you live in the darkest depths of Russia. Putting a lower grade thermostat in will make the engine run cooler during normal operation, this will effect the engines efficiency but will gain tiny amounts of power. Just having a thermostat will allow the engine to reach operating temperature but it will get hotter and hotter as it has no regulation, a radiator is a basic regulator and a fan switch is a fail safe. Hi, That's absolutely bang on, the stat stops the engine operating too cold and the rad/fan stops it operating too hot. Colin
andyborris
Sept 30, 2016 6:34:40 GMT
I still can't my head around how the stat changed it's operating temp....is this a normal fail mode, I thought they just stopped working!
Sept 30, 2016 8:57:44 GMT
If you have room you could stick a viscous fan on the M52 and not worry about the electric fan? Just a thought
andyborris
Sept 30, 2016 15:02:44 GMT
If you have room you could stick a viscous fan on the M52 and not worry about the electric fan? Just a thought No room I'm afraid, but would be nice, engine came with one too. Which reminds me, must get viscous fan on Ebay.....help pay for all the bit's I'm buying now!
Sept 30, 2016 15:51:38 GMT
Are you sure it's the 'stat and not your test method/measuring device? At 98ºC in a saucepan the water will actually be starting to boil.
The Wahler units (Audi use em too, and yes, stupidly expensive) are about the best and usually last at least 5 or 6 years. All the ones I've had fail have gone the other way and either open too soon or don't fully close. My TDI doesn't generate much waste heat so in the winter even a small gap in the thermostat means it doesn't warm up properly.
Nick
Sept 30, 2016 16:34:00 GMT
But under pressure, the boiling point will be raised, probably to around 115°C ish...
