Sept 5, 2016 17:34:22 GMT
I need a head unit for the van. I'm pretty much limited to a single din unit.
Only radio station I listen to is on dab. I can stream from my phone via bluetooth. I have a few cd's.
So, assuming I'm not going to build a full valve/vinyl/electrostatic set up for the van I'm looking at a cd/dab/bluetooth headunit.
Something nice and simple looking.
All I seem to have found that doesnt look like it needs to be in a kitted corsa is the pioneer dehx8700dab and the kenwood kdc bt73dab.
Any others ive not found? Any recomendations? What sort or ariel?
I'm also going to need some speakers. Probably going to have to put some in door pods by my feet but could put 2 little tweeters in pods ontop of the dash I guess. Maybe a similar set up in the back.
I have no idea these days, not looked at this stuff in years. If I want some component speakers, not too terrible, not too expensive, what should I be looking at?
I'm not too bothered about great claims of sound quality. I'm a hi fi geek and there is no way of getting decent audio in a vehicle so as long as there arent big haps in the frequency response and they don't distort by the time they have overcome the background noise of a 70's van then I'm happy. Thanks.
Last Edit: Sept 11, 2016 20:57:46 GMT by VW
Sept 5, 2016 17:40:10 GMT
I also considered some xtrons thing. dab, bluetooth, cd (and dvd) single din, 7" flip out screen. Looks simple enough and would has navigation so wouldnt need to have my sat nav kicking about. Problem is the screen would cover the heater controls then deployed and I'm also assuming it will be a glitchy, unreliable, awkward piece of junk.
Am I wrong?
Despite it being a car, and the odds being against it, you can get a good sound of the car. Some of it does involve cheating via some processing, good installation as well as deadening things in key places.
Anyway,
I'll take a look into the HUs when I get more time, but putting components into a car unamplified is a waste of time and money. It may leave you with a worse result than you anticipated ; My Porsche 944 Turbo sounded horrific with unamplified components. Being a van I'd probably leave the sound from the rear TBH, but in most installs I do. If you have to I'd consider installing a sub of sorts.
Are Coaxials out of the question or amplification of the components? You'll get a good sound from either way, not a dissapointment. The MX-5 I simply improved by correctly installing the speakers as you can see on the thread as an example.
I'm happy to amp the components. But don't want to spend a fortune on amps. I'm also concerned as it will be running of a leisure battery when stationary and I don't know if amps will drain it too quickly. Coaxials arent out of the question but they will be at my feet so not ideal. Thats why I thought id put tweeters on the dash. If I could aim them properly id choose coaxials as they are a point source but its not really doable.
Its a camper so I was going to put speakers in the back and use either the headunit or a seperate control to fade between front and rear. Rear speakers will only really be used when stationary and sat in the back.
I appreciate decent sound is sort of possible but the van is very noisy and driver placement not ideal.
I'm VERY into sound quality at home and I know its never going to be possible to get a system up to my standard of critical listening so there is no point me trying.
So, to sum up, simple looking single din headunit dab/cd/bluetooth/supports hands free. Speakers at my feet in front. Speakers in back will be better placed. Needs to be able to have front/rear balance control. Needs to not drain a leisure battery too quick.
I really don't need anything too fancy
Sept 6, 2016 13:51:01 GMT
I know you say that you are not trying to get great SQ out of the van, but going for components and being worried about placement hints otherwise, hence why I gave the reply I did . Anyway, now that's done and dusted, are you willing to go secondhand. IME, unless you leave amps on for more than an hour or more in the car the battery will generally be OK. I have only once had a battery go flat but I was also running quite a bit of stuff. This included A Genesis 4 Channel (think two of their 2 channels stuck together) A Genesis 2 Channel An Alto Processor A JVC DVD Single DIN Player ; I had no end of issues with a previous Denon. In the above case the Series 3 amplifiers were known for being power hungry! However, you could use something like Genesis' Profile amplifiers which operate on Class G technology, thus are efficient and are slim and compact. Something like a Profile 4 will do the job or just a Profile 2 channel just to amp the front components . Alpine's PDX range of Class D amplifiers are pretty good as well. You should get these for a decent price with a bit of searching secondhand.
Sept 6, 2016 16:13:26 GMT
I'm ok with second hand.
The power thing may still be an issue though, need to be able to camp, have interior lights on, odd bit if tv, maybe a couple of hours of radio.
Budget might be an issue too, might have to do it in stages. £150-£200 max on headunit. Sub £100 on each pair of speakers, cabling I can sort, I guess I could go £100 on an amp but I couldnt get it all at once.
I obviously need a headunit first, I can use the 70's sharp speakers in the front for now and have music. Ill get the rest over a couple of months.
I think coaxials may be best for now. I guess I can run them in the front for now and if I want to go with components in the future I can put the coaxials in the back.
Main questions I have then are...
Are either of the headunits ive suggested better than the other (leaning towards kenwood on looks), any others I should look for? And what sort of makes should I be looking at for speakers, new or used. £50-70 ish, id guess 6", coaxial, to go in a simple door build (not using internal door space, just a small pod).
Ill keep my eyes open for any good second hand deals.
Thanks for all your help, its been 20 years since ive even given a second glance at car audio so ive no idea whats available and worth having.
Sept 6, 2016 16:17:32 GMT
Hang on, genesis amps.
I'm sure half their work force came to work where i used to work, including their factory manager. I'm sure their circuit designer does some work with my old company too.
Are/were they in southend?
If I'm right i think I may know a few people who might be able to help me aquire some of their gear.
Sept 6, 2016 22:55:19 GMT
Potentially ; They did deal with quite a few folks in that area, including a now retired John Paul who had a beautiful W124 Coupe with plenty of their gear. Gordon Taylor is indeed a well revered bloke and quite rightly so, and this is coming from someone who was skeptical about Genesis gear from the start! He also fixes amps under the name of the 'Amp Doctor'. Out of the headunits I reckon it will be entirely down to preference. I'd try using them first. I love the sound of Pioneer HUs in some systems but I detest using the damn things! I'd recommend the Alpine CDE-178BT I had as it is such a great HU but the lack of DAB will be a bummer and I can appreciate why you would want that. It did however cost me £90 in near new condition! The idea of Coaxials for now is not a bad one by any means . As with anything, do your homework on the stuff in terms of spec and condition and you should be OK.
gazz81
Sept 7, 2016 14:23:32 GMT
I have heard a lot of good things said about Bassface speakers. For the money they seem to perform very well.
Sept 7, 2016 15:22:58 GMT
Just had a look, cheap enough and silk domes too. I'm not a fan of metal domes normaly, even though my hi fi speakers have massive metal dome tweeters. For £25 for a pair of 5.25 they have to be worth a go!
I'm wondering now about setting up the system so its only amped when the engine is running. I'm sure I could switch the outputs with relays to bypass the amp when the engine isnt running. I wont need it amped when stationary I wouldnt have thought. I might even already have some nice mercury wetted relays.
I'm assuming such a set up doesnt already exist?
Last Edit: Sept 7, 2016 15:24:31 GMT by VW
Sept 7, 2016 15:33:16 GMT
One way to do that would be to put the amp remote wire onto a switch, or to take the feed for the remote wire off the Ignition II position. However, you would lose the speakers up front, on the assumption you have only the two front speakers amplified.
As said however, the Class D, G & T (the latter if you really want to splash the cash) are generally very efficient, far more so than the usual Class AB affairs.
Sept 7, 2016 16:02:09 GMT
Loosing the fronts wouldnt be an issue. When driving id only need/want the fronts in play and amped and when parked id only need/want the rears in play and un amped.
Should be easy enough then.
Sept 11, 2016 20:55:06 GMT
Bit of an update on this.
I seem to have bought a sony head unit. Mex-n6000bd.
Its not very pretty, doesnt fullfill my looks requirement, but its dab, bluetooth, cd and was £35. I think ive also settled on speakers. I'm going to go with Hertz.
The issues with un amped components, is that due to sensitivity? As these hertz are pretty sensitive so was wondering if I'm still best off going with coaxials or comopnents. I'm wondering as these speakers (dcx) are designed as stock replacements so are sensetive and good unamped or amped from what I can see.
I was looking at their spec and they are only rated down to 60hz. I don't know what the db drop off is at that or how quickly it drops below that. There regarded as quite flat.
60hz isnt great (might be for 5 or 6" car speakers though?). There will be entire sections of songs ill be missing. I love a good bass line (real bass lines played by instruments not thump thump electro).
So, is it worth me trying to extend the frequency range down with a sub? Have no idea where I might be able to fit one though. Am I going to be able to get (lets be hopefull and say 20hz but I expect even 40hz will be pushing it) response, evenly, without just a thumping ported box? Can I get low frequency fill in which will give me tone of instrument?
I REALLY don't just want some bass punch. If it shows any signs of just being monotone single frequency honk ill just end up turning it off.
Can I do this, without spending a fortune?
Why am I getting carried away with all this!
Last Edit: Sept 11, 2016 20:59:53 GMT by VW
Rich
Club RR Member Number: 160
Sept 11, 2016 21:02:29 GMT
Sept 11, 2016 22:06:01 GMT
I saw something similar but more expensive (rainbow) on a local shops website. Worth looking at.
Sept 12, 2016 17:25:49 GMT
Of course it is fine to try the Hertz speakers unamped. I was debating buying those for the MX-5 . I'd try the Hertz speakers unamped first. The worst thing is you have basically installed them . Something like the JBL GT4 12" sub sealed is fine (I cannot remember what size box works however, but in a certain ported box the results are very surprising for what is a great VFM sub. New they were barely £50 so they should be quite a bit cheaper now, I reckon you could get one alot cheaper. I can see if a few of my mates have anything. I have a Precision Power 8" which I am looking to sell. Despite it being a very SQ sub it just does not drop at all, you can barely tell the sub is even there on maximum volume! As for amplification, a cheap Class D monoblock should do the job .
Last Edit: Sept 12, 2016 17:28:34 GMT by ChasR
Sept 12, 2016 17:48:44 GMT
My problem with a standard sub install is space. Youd think being a van id be laughing, but every space is in use. Even under the seats will be tricky as the batterys are there.
Ill look at subs again later once ive seen if I can loose a cupboard or something.
I have one more question, sorry.
I need to build some door pockets with speaker pods for the doors. As usual though there is an issue. The whole lot is mounted to a flat metal door. There is no hole into the door cavity and id rather not cut one as good cf doors are rare! So basically the speakers are going to end up in a sealed enclosure barely bigger than the driver. I guess I could keep it open at the bottom or into the pocket if that would help. I'm a little concerned about cancellation etc from the rear wave though. I assume most door builds are open into the door cavity. Are there any rules or considerations as to the volume and porting of car speakers?
Sept 13, 2016 10:40:02 GMT
One thought regarding the worries about power consumption when camping. What sort of camping are you doing? As i wouldnt dare run the set up in my camper on most campsites, as sound travels well across an open field and will wake half the campsite up. I have a bluetooth speaker ( internal battery, charges off usb) or a roberts dab i take with me, which is more than enough for background music while camping, and keeps my batteries free for camping.
Also consider a solar install to keep batteries topped up. Free power!
Sept 13, 2016 10:56:16 GMT
When camping it will just be used as background music but don't really want to carry another radio.
